Short Cage Vs Medium Cage
Need some advise on this issue and answers found online seem to make me even more confused...
My chainwheel is on 53/39T and I have options of pairing it with:
1. 12/27T cassette
2. 12/25T cassetteI have a both short Cage and medium cage RD.
Questions:
1. Should I use short cage RD?
2. If short cage is the best option, does it mean medium cage is not usable with either cassettes? and vice-versa?
3. What could possibly happen, if medium cage is used? I mean like the possibilities of slipping OR chain drop OR anything that would lead to malfunction during shifting OR failed function?
1. 12/27T cassette
Questions:
Quoted: 4195 Post(s)
Liked 3,837 Times
I nearly always suggest a rear der with more capacity then what the gear ranges requires. Something "wrong" IMO about using a system at it's max all the time. I don't think your 40K time will suffer with either der choice but those who feel as I do will use the medium cage. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 1438 Post(s)
Liked 1,092 Times
There is a miniscule possibility that the medium cage derailleur will slow the shifting slightly but in the vast majority of cases this is nonexistent or imperceptible.
That's what I read from the internet. Have u tried using medium cage on such drive setup similar to mine?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
For the OP, I'd run the SS just because you don't seem to have any plans to use a larger cassette. If you do decide to do that just swap the derailleurs.
Blamester
If you where going to buy one I would say get the medium.
but you have both so try both. Either one will work but you might like the look of one over the other. Or you may notice a difference in shifting of one over the other. I don't know if one will help the front shift better or not. It might.
But be carefull with chain length. Measure to the longer cage one first. One chain length might work for both
Check the limit screws before you ride them
Cable will stay the same.
Quoted: 645 Post(s)
Liked 797 Times
1. 12/27T cassette
Questions:
1. 12/27T cassette
Questions:
Just gotta be sure on the chain length first...
thanks...
I went with a med cage RD years ago because I wanted the capacity for a 13-29 cassette I occasionally used for climbing, even though my normal cassette (12-23) is within the capacity of a short-cage RD. Never noticed any difference between the med-cage RD and the the short-cage that preceded it.
Quoted: 1943 Post(s)
Liked 2,164 Times
If you “already” have both rear derailleurs, use the short cage now. If you don’t have either, buy a medium cage. This is also assuming that both are the same quality level.
John
John
Liked 3,837 Times
Don't take my personal set ups (a few bikes...) as the path for you. But you did ask. I run triples on my frequently used bikes. I mix brands and have Shiftmates on some of the bikes. All run a long (NOT medium) cage der.
I ride in the Finger Lakes region of NYS and have low gears around 18 to 22 inches (24 or 26 in front and 32 or 34 in back with either 622 or 559 tires). I am nearly 65 and never had much power but love the hills and like to spin (I look forward to a cassette with a 12 or 13T hi cog and no single tooth jumps). Andy
AndrewRStewart
AndrewRStewart
I have both RDs but not the same quality. DA7700 is medium cage RD and a Shimano 600 Tricolor is short cage RD.
Thanks...
Liked 3,837 Times
Shimano does not make much claim for forward system compatibility. IIRC the tricolor is a 9 speed unit from many years ago and might not play as nice with current cog counts. I looked back on the thread and don't see how many rear cogs you are running. Andy
AndrewRStewart
AndrewRStewart
I am running a 9-speeder with 2 options of cassettes (12-25T and 12-37T)
Quoted: 4790 Post(s)
Liked 3,918 Times
I'd toss on the short cage. Run a chain over the big ring and and 27 tooth cog, through the derailleur and and back to itself at and opposite link so the chain is a link or two longer than the derailleur pulled tight. (Don't shorten or connect the chain. Just match the narrow to the wide link.) Mark that link. Now move the chain to the small ring and cog. Match it to that marked link. Is the chain slack within reason? If not, go to the medium cage derailleur. If you think you will ever go to a larger cog, go medium.
If you go to too tight a big-big combo, you are making that nice derailleur older every time you use that combo. And there is risk of bad things happening. (Damaging the derailleur or the dropout or the wheel or the frame or yourself or any combination of the above.) A bit of slack in the small-small is rarely an issue and it is a combination most of us don't use a lot. I much prefer derailleurs that don't care at all if I go big-big.
Liked 3,918 Times
Quoted: 4559 Post(s)
Liked 2,802 Times
1. 12/27T cassette
Questions:
1. 12/27T cassette
Questions:
Liked 2,164 Times
The Shimano 600 is a very nice derailleur, but if you use it and then need to get a cassette with a 32t you could potentially lose the opportunity to use the 7700.
I’m a sucker for Dura Ace and would run the 7700 and not look back.
John
