20 year old wheels safety
Bikes: 1999 Litespeed Tuscany, 2017 Colnago CLX 3.0, 2001 Airborne Lucky Lady,
I was quite the cycling gear head in my early 30s. I had multiple road bikes, a track bike and also a mountain bike. Although a few years back I got a Colnago that I ride, I still have those other bikes. They ride great as I have maintained them and they have really low miles. But the wheels I am beginning to wonder about. My 1999 Litespeed Tuscany has Cane Creek deep dish and my 2000 Airborne mtn bike has a pair of Cane Creek WAM. I ride these bikes infrequently. How can I tell if the wheels are still safe? Or am I being paranoid?
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Good spoke tension and the rims are true and the hubs spin smoothly means they're not going to fall apart.
Good brake track means they're not worn out.
Still be a good idea to do some shakedown rides around the neighborhood before you take them on an epic ride to the boonies.
Really Old Senior Member
If you don't have rim cracks from the nipples and a good brake track & hub, what's to worry about? Nothing's going to fail catastrophically.
Likes For Bill Kapaun:
Quoted: 2604 Post(s)
Liked 1,933 Times
Quoted: 6193 Post(s)
Liked 4,809 Times
If you have doubts or don't trust your own judgement, take them to a shop that has a decent wheel guy and let them tell you. They can check and do basic adjustment to the spokes for usually a pretty nominal fee. Same for bearings in the hub if that's more of a concern for you.
Your checks for old wheels are pretty much the checks you do for new wheels. Are they round and running true. Spokes all there and seem to have similar tension to the others.
Quoted: 194 Post(s)
Liked 204 Times
Twenty year's old!
Wow, like new then!
I do actually have a couple of bikes with 15 year old wheels, but as you are doing regular maintenance you would notice if anything was degrading.
Wow, like new then!
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
The wheels themselves are unlikely to be a problem. I'm still riding the 2nd set of wheels I ever built, back in 1978, and they're holding up fine. The tires, OTOH, should be inspected for cracking and/or casing failure and may need to be replaced.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
No signs of cracking at the spoke holes on the rim? Even spoke tension and true rims? Brake track resists thumbnail pressure? Hubs spin well? Then I'd say ride them.
BTW, I have a set of 50-year old wheels that I'm riding from time to time. They're excellent.
Likes For Phil_gretz:
Quoted: 550 Post(s)
Liked 325 Times
Jobst Brandt states that 0.5mm is the absolute minimum in https://yarchive.net/bike/rim_wear.html, noting hoop stress goes up with tire width and his experience was in the era of narrow tires.
Other people use 1.0mm as the minimum.
Habitual User
Quoted: 4946 Post(s)
Liked 8,085 Times
I have a set of Rolf Vector Pros and Mavic Ksyriums that are 18-20 years old. Both are still very solid.
Quoted: 1819 Post(s)
Liked 1,693 Times
I still have the wheels from my 1973 Raleigh Professional. The rims were replaced about 35 years ago so that I could use clincher tires. I broke the frame of that bike in a race 22 years ago, but the wheels lived on on different frames for another 10 years. Those wheels are now backups for the wheels on my Limongi and I wouldn't hesitate to use them at any time
Thanks so much for the advice. I'm going to keep riding them then!
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
I still cruise around on my BMX Araya's from the 80's. With old wheels just check the seam and make sure the weld or the joint where it's pinned is still good and not cracking or separating. Then the second things is to check the side walls for brake wear. If there is a visible grove along the sidewall then the rim is worn out from braking and should be replaced.
Quoted: 980 Post(s)
Liked 582 Times
Another form of rim wear indicator (see attached) is a single hole milled partially through the rim; as with the groove, when it's gone, the rim is worn out.
Brake wear is less of a "groove" and more of a concavity of the entire side wall.
Rim wear indicator on a new rim.
Quoted: 980 Post(s)
Liked 582 Times
Same rim a few thousand miles later!
Quoted: 601 Post(s)
Liked 779 Times
