Cones of front hub loosening weekly
The cones of my front wheel's hubs have been getting loose about every week. I built the wheel with a new hub in 2015, re-packed it a year ago. It rotates freely; as near as I can tell by eyeing it (not professionally) it looks okay. Is this a sign of wear?
Really Old Senior Member
What brand/model?
IF a conventional cone type, you aren't tightening the LOCK NUT.properly.
Quoted: 453 Post(s)
Liked 104 Times
If it's coming loose weekly, what damage has been done? maybe worth inspecting the cones/races before doing it up tightly?
Likes For jimc101:
Quoted: 581 Post(s)
Liked 921 Times
It's either an assembly error (not tightening locknut properly) or the bearing surfaces are damaged or deteriorating. Disassembly and inspection of the bearing cones and cups is required to determine which.
I suppose it could also be a broken axle, but that is not too common on front hubs and you likely would have noticed immediately upon inspection, although a QR skewer can somewhat hold an axle together and hide that it is broken.
Quoted: 836 Post(s)
Liked 1,061 Times
As mentioned check your locknuts and probably a good idea to undo all the threaded parts and check for any damaged or stripped threads, inner and outer. What make & model are your hubs so we know what type of axle setup you have.
