correct lube for hub rubber seals?
Old 03-04-21, 08:16 PM
Symox
Bikes: '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 121 Post(s)
Liked 48 Times in 36 Posts
My hubs have rubber seals. If I use a bicycle grease it seems to drag. If I use WD-40 it spins freely. What is the preferred lube to use (I assume WD-40 is not a good long term solution).
Thanks!
Symox is offline
Old 03-04-21, 08:19 PM
Crankycrank
Quoted: 367 Post(s)
Liked 225 Times in 173 Posts
Use the same grease used for the bearings. WD-40 is a solvent and will dissolve the bearing grease. If your seals are new they will loosen up over time. Dragging seals are normal to some extent and are not noticeable when riding and keep your bearings/grease clean and long lasting.
Crankycrank is offline
Likes For Crankycrank:
Old 03-04-21, 08:23 PM
Bigbus
Very Senior Member
Bigbus's Avatar
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 324 Post(s)
Liked 231 Times in 172 Posts
Do not use WD40. Unless you're using the regular oil and not the penetrating stuff. If the seals hold oil I would put in some straight 30 wgt, My truck has rubber seals and I put in straight 30 wt, not grease. But grease is the preferred lube for most hubs because it doesn't leak out or wash out like oil. Caveat here-I'm no expert. But I'm sure there'll be a few of them posting here soon. haha
WoW! You're fast Cranky, I was still typing...
Bigbus is offline
Likes For Bigbus:
Old 03-04-21, 09:47 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 589 Post(s)
Liked 676 Times in 389 Posts
Grease.
cxwrench is offline
Likes For cxwrench:
Old 03-05-21, 01:04 AM
Symox
Quoted: 121 Post(s)
Grease it is
Thanks for the replies
Symox is offline
