Sansin sealed bearings
Old 03-04-21, 09:37 PM
Special_k44
Quoted: 11 Post(s)
Liked 3 Times in 2 Posts
Can someone tell me if these hubs are true sealed cartridge style bearings or if I can service them. Just bought the bike, they feel good, but Id like to service them If they are serviceable.
also, is there a way to determine rim width so I can determine if the tires I want will fit, without taking the tires off?
thanks everyone
Special_k44 is offline
Old 03-04-21, 10:24 PM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 732 Post(s)
Liked 305 Times in 251 Posts
they DO look to be pressed-in sealed cartridge bearings. If you are determined to service them check out the "easy" step-by-step wiki made by miamijim, it's "easy" cause you can leave them in place whilst you clean and re-pack with grease of your choice. Even replace a rubber (coated) seal if it's trashed. But if the bearings are actually bad then the servicing is still possible but involves pressing out and in, you need at the least an assortment of "anvils" like deep sockets and a large vise or arbor-press. Let's see if I can actually find the miamijim post...Found it here ya go, start with post#11
https://www.bikeforums.net/classic-v...t-replace.html
unworthy1 is offline
Old 03-05-21, 01:39 AM
polymorphself
Quoted: 497 Post(s)
Liked 472 Times in 235 Posts
I just overhauled a pair of these. Just pop the seal out with your finger or a tool, but be careful not to damage the rubber. Pops right back in place after greasing the bearings.
They arent sealed in the way youd think it means.
polymorphself is offline
Old 03-05-21, 07:46 AM
Special_k44
Quoted: 11 Post(s)
Thanks for the link to the other thread. Super helpful
