Cannondale Trail 6 Tubeless Conversion
Old 03-04-21, 10:45 PM
milesf
Quoted: 13 Post(s)
Hey,
I am pretty new to mountain biking and I was wondering if any of you guys knew if it was possible to convert a 2020 Cannondale Trail 6 to tubeless without completely replacing the rims and tires and if not, how much the materials to do it would cost.
Thanks!
milesf is offline
Old 03-05-21, 08:48 AM
carlosponti
Bikes: '90 Raleigh Technium Prestige, '90 Fuji Thrill - Gone, '18 Fuji Nevada 1.7 29er, '19 Fezzari Abajo Peak
Quoted: 38 Post(s)
Liked 29 Times in 20 Posts
there is a lot of context you left out, what tires? what year is the bike? I converted a fuji nevada wheels to tubeless however it meant switching tires. Tires should be tubeless ready before going down this road. Tubeless tires have more rubber on the sidewalls to prevent sealant from weeping. non tubeless tires will weep for a bit which some people are fine with. Rims you have to do a ghetto conversion by using gorilla tape and run a couple of layers but also at the same time take a bit of work to get the bead to seat. tubeless ready rims are easier to seat. My current bike has tubeless ready rims and tires with proper rim tape and is much easier to get setup. Also unless you are facing constant punctures there really isn't a reason to go tubeless. Its possible to ride and do well without running tubeless.
tldr: yes you probably can but will be a bunch of work. I've done it but I would rather have tubeless ready tires and rims. unless you are getting constant punctures stick with tubes.
carlosponti is offline
Old 03-07-21, 09:56 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 2267 Post(s)
Liked 941 Times in 621 Posts
But I thought you were done trying to turn this bike into a fancier one?
None of the half-measures are as secure as the real thing. The best conversion was Stan's, used to make conversion kits that used a rubber strip to fill in the channel and make the tubeless shape, but...
https://www.bicycleretailer.com/indu...r#.YEWdKGhKiUk
Genesis 49:16-17
Darth Lefty is offline
Old 03-07-21, 11:30 PM
milesf
Quoted: 13 Post(s)
Thanks! I guess the idea of constant punctures is kinda abstract, I've had to change out my tube twice this month so idk if that's a lot (I ride about three times a week for 2-4 hours each). The main reason that I wanted to do it was just so that I could run lower pressures since I have been having some problems with getting a good amount of grip. Also, right now I'm literally just running all of the stock parts from the 2021 version (WTB Ranger Comp tires, 29x2.25)
milesf is offline
Old 03-08-21, 08:48 AM
metz1295
metz1295's Avatar
Bikes: '97 Cannondale M500; '14 Specialized Secteur Compact; '21 Trek Roscoe 7
Quoted: 22 Post(s)
Liked 13 Times in 10 Posts
Originally Posted by milesf View Post
Hey,
Thanks!
Look up the specs on Canondale's website. 2020 models should still be listed. If the specs for tires and rims specifically say 'Tubeless Ready' then your conversion will be easy. If not, you'll probably have to invest in rims and tires. If you're still not sure, just ask your LBS.
metz1295 is offline
Old 03-10-21, 06:34 AM
Kapusta
Cyclochondriac
Quoted: 1844 Post(s)
Liked 1,145 Times in 674 Posts
Tell us exactly what kind of rims and tires you have.
Do your WTB tires say “TCS” on them somewhere?
Kapusta is offline
Old 03-10-21, 06:46 AM
metz1295
metz1295's Avatar
Quoted: 22 Post(s)
Since they didn't list anything, I assume it has original equipment. This link is the 2020 model.
https://www.cannondale.com/en/bikes/...ku=c26600m10xs
Other Cannondale models specifically say tubeless ready for rims and tires. I think he will have to invest $$$ if he wants to make the switch to tubeless.
metz1295 is offline
Old 03-10-21, 07:04 AM
Kapusta
Cyclochondriac
Thats cool, But I do not assume anything, and I am not going to run around the Internet looking up what is supposed to be stock on his bike (which sometimes is not accurate, anyway) when he can just read what’s on the rim and tire and post it himself.
Kapusta is offline
