Show us your gravel/cross bike...
#4902
Bikes: Ritchey Swiss Cross | Teesdale Kona Hot | Haro Extreme | Specialized Stumpjumper Comp | Cannondale F1000 | Shogun 1000 | Cannondale M500 | Norco Charger | Marin Muirwoods 29er | Hiawatha 3sp | Shogun Kaze | Breezer Lightning
Quoted: 374 Post(s)
Liked 441 Times
I guess I'm not used to a touring based framed, as I find the rear a bit harsh, even compared to my Tange 2 road bike with 28mm tires. Riding seated transmitted more bumps than I ever remember. The weight is 23lbs 15oz with pedals so its acceptable so its not too piggish.
Perhaps "pig" was a bit harsh.
Trek 750 gravel conversion
Likes For zen_:
#4905
Thank you both, its a nice bike and I'm digging it so far.
#4906
Quoted: 374 Post(s)
Liked 441 Times
#4907
So, Sora R3000 levers with TRP 8.4 mini V's. I was expecting a lot more bite to be honest after hearing all the "on/off" stories. I don't feel that to be the case at all; these don't have the same bite as proper long Vs, the pad to rim distance is very tight, and the fender clearance on the 38s is a bit tight - all well documented. Braking is much better than with calipers on the hoods but not what I was expecting. Overall, they're adequate if the drawbacks are tolerable. Quality control was a bit lacking as one pad holder's allen head was not broached properly. I also think they are overpriced for what they are but oh well. My background is with MTBs so have been on cantis in the 90s, switched to V's in 95 and then discs in 99. I haven't taken this thing off road yet
On one bike I have Sensah shifters/brakes pulling 80mm mini v-brakes, and on the other I have Claris shifters/brakes pulling 84mm mini v-brakes - both feel alright to me. If you can set the pads close to the rim (like 1.5 mm away), the pull and bite feel should be pretty great. If it's not, maybe you have to lose the fenders to set the pads a tiny bit closer?
#4908
Quoted: 6774 Post(s)
Liked 1,371 Times
My spouse has an All-City Macho Man. It has 700c wheels and mini-V brakes (made by Paul) and Shimano 105 levers. I haven't ridden her bike extensively but my impression is excellent. She is happy with the brakes, and she has very weak hands. She thinks the brakes on my bike "don't work" because she can't work them.
#4909
Quoted: 374 Post(s)
Liked 441 Times
After another day of commuting, it seems like the pads took a bit to wear in. It doesn't help that I've been wearing 2 layers of gloves this whole time. Braking is good.
#4912
I like speed
#4913
Thanks!
See the post above, it shows the biplane handlebars. It's pretty comfortable and I got used to it quickly.
#4914
Lurker
Found a new 2017 Bombtrack Hook 2 steel frame and built it up with some new wheels and my older 6700 triple groupset + mech discs. One ride down done, and I am enjoying the wider rubber compared to my road bikes. Nice and comfortable. Not the lightest bike though @11kg.
Likes For esarhaddon:
#4915
Likes For woodcraft:
#4917
Lurker
The blue was probably more than half of the reason I purchased the frame when I saw it. Measuring the weights before I built the bike up, the bare frame was 2.35 kg(!), the fork is 0.53 kg and the wheels themselves are 2.01 kg, so it all adds up pretty quickly!
