Do I need to change controller when switching from SLA to L ion?
Senior member
Quoted: 943 Post(s)
Liked 659 Times
Basically, the title says it. Looking to upgrade the battery pack from 36v 7ah SLA to something in the 15 to 20 ah Lithium ion pack.
Will my controller from the SLA pack work or do I need to change that as well?
The SLAs have served well, but I think they are getting near the end of their service life. Not holding a charge as long as they used to.
Thanks
Thanks
Quoted: 883 Post(s)
Liked 824 Times
Dan,
If you don't receive an answer here, you might try the Endless Sphere site. Dogman Dan, in particular, is very helpful, and will respond to private emails.
As to the original question. Generally speaking, depends on the new battery voltage. So long as the new battery voltage range is similar enough to your old battery voltage range (discharge curve from fresh off the charger to low voltage cut off) it shouldn't be any sort of an issue. Some controllers have a programmed low voltage cutoff(LVC), obviously I wouldn't know if yours does or what that it is if the controller does have an LVC, but this could be something that needs adjusting (assuming you can). All controllers have parts inside of them that can tolerate a maximum voltage, going beyond this voltage will result in basically a broken controller.
