Can you help me identify this GIOS?
Hi, I've recently acquired this white GIOS and I'm a bit curious as to what I've actually gotten my hands on. I think it's a repaint and the decals point in all kinds of directions but it has all the characteristics of a 1978 (or earlier) Super Record.
I've studied the GIOS registry and the article on Steel-Vintage about GIOS Super Record (sorry can't post links).
Arguments that it's a pre-1979 Super Torino:
Arguments that it's something else:
As for the tubing, it's my understanding that Aelle seat tube is 26.8mm and did GIOS make anything in Aelle with the GT engraved BB?
So would it be wrong to assume that this is a 1978 or earlier GIOS Torino Super Record with Columbus SL tubing? Or is it just wishful thinking?
- External top tube cable guides
- Engraved GT fork crown
- Engraved GT bottom bracket
- Seat tube takes a 27.2mm post
- Tapered seat stays
- It's white
- Columbus Aelle decal
- GIOS Professional decal on chain stay
Quoted: 4722 Post(s)
Liked 3,039 Times
Welcome to thee forums. I don't know much about Gios but they did make entry level models with hi-tensile steel, so there's no reason to believe they didn't make an Aelle model, though I haven't seen one. Still, as you state, Aelle typically used a 26.8mm post, while 27.2mm is typical of SL. It's always possible that the seat tube had some aggressive reaming, so to increase my confidence I'd be checking the steerer tube. Aelle did not use the Columbus steerer and therefore would not have the dove logo on the outside or the five helical ridges on the inside, at the bottom. Of course, this still isn't infallible, as the fork may have been switched.
Your bicycle appears to have recessed brake mounting, so I wouldn't think it would be pre-1979. Campagnolo catalogue 17a (for 1978 model year) doesn't mention this option for the brakes and the 1977 Gios catalogue shows exposed brake mounts. Regarding brake cable tunnels, the 1981 Gios catalogue still shows them. Of course, that assumes this is a legitimate Gios. It's my understanding that they are a commonly faked brand.
Bianchi Goddess
Quoted: 2935 Post(s)
Liked 2,931 Times
Is it possible they use a SL seattube and Alle for all the other tubing?
Sugar "Kane" Kowalczyk
Quoted: 2588 Post(s)
Liked 4,824 Times
Are the dropouts drilled, and is the driveside rear dropout drilled for a Portacatena? That was also a feature on most Super Records.
Just from the few pics shown, I believe it's a repainted, genine SR from around the late-70s.
DD
DD
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
I doubt any "counterfeiter" would have faked that BB shell cut-out, likewise the forkcrown panto seems legit and the crown the "correct" style, but a shot of the seatcluster would be helpful. Is it a Hatta Swan headset?
As for the brake mounts, I'm not entirely sure what recessed mounting means, however, comparing my mount this one from the registry (www.giostorino.it/images/stories/PDFREGISTROGIOS/rsgiostorino39.pdf), they appear to look the same.
Haven't checked the steerer tube. Going to do that next.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
OP,
It looks like my GIOS SR, if it was repainted that could explain the "upgrades" of the decals etc.
is the seat post campy, what does the seat tube look like?I would not be overly concerned about the lack of the"hole" for the Portacatena, it might be filled or left not being drilled.
White was a later color combo.....only downside is the repaint....on the other hand that means you can ride and enjoy it without being overly compulsive about "condition, my Gios is still my favorite go to.
Best, Ben
Best, Ben
Voltaire
Voltaire
Bikes: yes
Quoted: 59 Post(s)
Liked 81 Times
The key points are was DD said -- the drop outs. Also front and rear drop outs will be Campagnolo. The fork crown looks correct and he seat cluster looks correct, but a closer photo would confirm. I think the Aelle sticker was wrongly used following the repaint.
I've added photos of the seat cluster and the front lugs which I think is also consistent with other super records I've seen. The headset is Hatta Swan but the parts have been replaced when I acquired it. It came with a Shimano Golden Arrow groupset but I opted for Nuevo Record.
Bianchi Goddess
Liked 2,931 Times
Your running the wheel too far back. You should run the wheel further forward to line up the....the ....OH I forget but in general the rear wheel should be further forward. Something to do with the position of the freewheel in relation to the position of the jockey wheel on the RD.
Some dropout adjuster screws would help, if the holes are not plugged.
OP,
Best, Ben
Best, Ben
It's a good point about not being overly compulsive about the condition. It's a great ride and it would be a shame to only have it on display out of concerns about ruining the condition.
my name is Jim
I think this is about a 78 or so Super record that has been repainted and had some later components put on it. All the frame features we have seen are consistent with an earlier Super Record. The fork crown and BB cutouts were changed by 79 so this is earlier than that. Recessed brake mounts didn't show up until 80 or so though so this has been modified to accept them. It should also have a head badge not a decal and the painter may have used the wrong Columbus sticker. I have found the Gios Blue group on Facebook to have some really knowledgeable Gios people.
Flickr Albums
ebay: cicloclassico
70 Pogliaghi ItalCorse, 72 De Rosa, 72 Masi Gran Criterium, 75 Masi Gran Criterium, 77 Melton, 79 Bianchi Super Leggera, 79 Gios Super Record, 81 Picchio Special, 82 Guerciotti Super Record, 82 Colnago Profil CX, 83 Colnago Superissimo, 84 Fuso
Flickr Albums
ebay: cicloclassico
Glyndwr
Classic & Vintage
3
02-08-19 11:44 AM
cpsqlrwn
Classic & Vintage
9
06-24-15 01:04 PM
Johncarlsberg
5
01-01-12 04:56 PM
