Just picked up Centurion Ironman Dave Scott
Hi guys,
I'm new here, just picked up a centurion ironman dave scott off craigslist for $180 and wondering if it's a good buy and may need more info such as year size and etc.
It seems like late 80s, 58 or 60cm frame?
tange #1 tubing
Serial number (I think it's serial no) KF5 1490
tange #1 tubing
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
If it fits you, that's a great buy. The Ironman experts will be along.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Nice score!
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
thanks folks, anyone can tell me more about centurion ironman dave scott? was it a good bike back in days? what year is mine?
Constant tinkerer
what should be there original derailleur on this bike? mine is Shimano Deore XT and it doesnt seem working well, keeps kicking out of cassette and few other problems, should I get it fix or replace with better one? what would be better option? brand and model? I am an international student here in U.S. so please advise me website where I can buy parts.
Thrifty Bill
Liked 964 Times
Kicking out could be a worn chain or cassette. Not enough info to diagnose over the internet. Derailleurs are pretty robust. Your bike probably came with a Shimano 600 RD, to match the other 600 parts.
Constant tinkerer
XT is essentially the same level as 600, but it's in the MTB group rather than the road group. XT can handle bigger cogs in the rear and has more chain wrap capacity. It's a high level piece, but yours looks pretty gouged. That may be the cause of the skipping but as Bill says it's impossible to diagnose online. Take it to a shop or local bike co-op and have them look at it before you start buying stuff. With that damage, it's likely the derailer or hanger is bent.
Any cassette with the same number of speeds would work, replace the chain if you're replacing the cassette.
Constant tinkerer
Since you have friction shifting, literally any derailer you could bolt on there should work unless you have a cassette/freewheel with teeth larger than ~28. For that you're going to need to stick with a "mountain" rear derailer.
600 doesn't exist in name anymore, the current equivalent is Ultegra but a new one of those will set you back about $80. Same goes for XT (which is still around.) If the derailer truly turns out to be bad, I'd probably just replace it with a new lower-end unit or try to find the correct vintage part.
How about Shimano "Sora RD-3400 SS Rear Derailleur Short Cage 9 Speed"?
I know it's very low end but I'm guessing that will be better than what I have anyway
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
>.> Have you tried looking for older higher end ones in the C&V for sale section yet? Or perhaps trading for one in the ISO/FT thread? I personally wouldn't want a Sora RD anywhere near the rest of that group!
I see what you are saying but I am trying to understand one thing, all derailleurs I found 8-9-10 speed or so, what does it mean? does it mean it supports up to 10 speed or what? mine is 12 speed, 2 gears front, 6 in rear, can I go ahead and buy Shimano 105 5501 8 Speed Rear Short Cage or any other higher-end derailleurs? I m trying to understand what they call as speed, total speed of bike or number of gears in rear cassette.
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
and what I'm saying is, I'd be looking for an older higher end one meant for 5 6 or 7 cogs in the rear
Thrifty Bill
Liked 964 Times
Speed rating is all about the number of cogs you have in the rear, in your case, six. So you need a six speed or better RD.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12777 Post(s)
Liked 7,694 Times
You probably have a freewheel, not a cassette.
Nice ride. Sorry, not an Ironman expert, but wild guess 1985.
I reckon they go for $200-$400 around here. One guy has a newer one up for $300 firm, we'll see how long it stays up.
Quoted: 378 Post(s)
Liked 1,409 Times
1985 model, first year of production.
Tange 1 frame with nice sloped crown fork.
Shimano 600EX was OEM, and I'd find another 600EX rear derailleur for it.
If it's jumping out, probably a worn cassette or chain. However, that may be a freewheel, so double-check.
There are 6-sp 600 freewheels out there, as well as 6-sp UG cassettes out there, so should be easy to find.
Should clean up quite well, and getting the wheels trued and tensioned will be like getting new wheels.
Given a proper cleaning, then repack of the hubs, headset and bottom bracket, then lube and ajust cables and shifters, you'll have a killer ride that is way beyond a $180 bike. Easily one to invest in.
I'm building one now, same year, different color.
I'll put $500 into by the time I'm done.
Won't lose a second of sleep over it.
Thank you guys,
I tool bike to local shop where you only buy parts and DIY, guys over there advised me to replace all cables, tubes then they helped to adjusted existing derailleur, it works fine now, no kicking or other problems but I am still looking original shimano 600 6207 to replace, guys at the shop told me that bike is really special and I should take care of it as it deserves.
brake and derailleur cables + tubes cost me $8 + no labor charge
Now, I am looking original derailleur and shimano 600 pedals.
Thank you again,
Thank you again,
Constant tinkerer
I wouldn't lose sleep over the pedals, but that is your choice. All my road bikes get SPD-SL clipless pedals regardless of age. In addition, I have yet to buy a vintage bike with anything close to the original pedals. Plastic crap pedals are the most common.
uncle uncle
Classic & Vintage
17
01-10-15 12:25 AM
EarlGrey
4
07-23-14 09:40 PM
johnandkristy
2
05-30-10 08:02 PM
