Help IDing Lemond Spine Frame
Picked up an early (mid?) 2000’s Lemond on Craigslist for $200, Carbon/white "spine" frame, Brev M wheels, cracked tires, hipster flat bars, etc etc etc.
I'll be keeping it single speed, just a toy for around town. Added some FSA Adventure bars, I'm used to the 12* flare from my Salsa commuter.
I've found the PDFs of the old Lemond catalogs, but I can't find anything about a bike without a model name. The only marking is "Custom" in script on the left side, right side is blank. Decals and script are under the clearcoat. I believe it is a 53, based mostly on wheelbase measurement. Feels about like my 54 Salsa.
Ever seen one of these without a model, just “Custom”?
Can't post images or links yet... White on the Reynolds half, carbon on top. Nothing from the original kit to know what level it may have started life as.
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
The Versaille was white/carbon. I am assuming the metal part is steel. If it is not, then it is either aluminum (Buenos Aires) or titanium (I believe it was called Tete de Course) and has been repainted.
I have a Zurich, which is steel/carbon and is blue.
They all had the model name on the top tube, so yours may indeed be "custom"
Also, made in the USA with a flag. I assumed it was steel but may be something else? Definitely no model on it anywhere, just “custom” on the left side.
SE Wis
Quoted: 2744 Post(s)
Liked 3,390 Times
Quoted: 67 Post(s)
Liked 67 Times
True Temper Platinum is steel. (see if a magnet sticks to it).
Likely was a Versaille. Originally came with 9 speed Ultegra. Last made in 2006, I believe.
Definitely steel. The internet says LeMond transitioned from Reynolds 853 to True Temper OX Platinum some time in 2004.
Looks just like a Versailles, but all the spine bikes look the same I guess. Paint is pure white, “LeMond” logos are white with black. All the Versailles’ on google have dark blue logos.
The search continues. Maybe that “custom” actually means something. Email sent to trek with the serial number, maybe they can come up with something.
Maybe I’m at 10 posts? Bar tape was my daughters choice, it’s slick and may not last long. More parts on the way, I’m piecing this together as I go.
Heard back from Trek, it was indeed a "custom" ordered bike.
"Alright, so after some digging, I have a little more info for you here. In 2005 (I only have a spec manual and not a catalog for ‘04,) our LeMond catalog has a customization program advertised. Essentially, you chose your frame between either the titanium or steel option, then you build from there, much like our Project One program we have now. All of the photos of the frames available in the catalog don’t have a name designation on the top tube like the rest of the bikes in the lineup due to the fact that the bike models were differentiated via componentry. Eg: The Maillot Jaune came stock with Shimano Dura-Ace 10 speed, where the same frame was used for the Versailles, but came stock with an Ultegra/105 9 speed mix."
The frames were all the same between models, whether steel or titanium. The components made up the actual model. The serial number from my bike does not come up on their system, it truly is a mystery. May actually be a 1/1 white over carbon bike.
The rep from Trek was very polite, nice to know you can reach out and speak to a real person.
Quoted: 1856 Post(s)
Liked 664 Times
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
Heard back from Trek, it was indeed a "custom" ordered bike...
Give the 2001 spec manual a read..you'll see how it worked..
A point of clarification..in reference to the years 2000+..the statement "The frames were all the same between models, whether steel or titanium" isn't true in a broad sense. Within some model-clusters I think it's a fair statement that models were differentiated by components alone. The Trek-Lemond catalogs(tech catalogs on the vintage trek website) indicate(for example) the Maillot Jaune and Zurich models had "853 Pro" ovalized downtubes(vertical on top and horizontal on the bottom) vs the Buenos Aires (and others) had "853 Designer Select" round downtubes. The chain & seat stays on some models were 525 or 725 while the main triangle was 853. The steel vs titanium frames were essentially the same, though there were differences between them..they were not identical.
Understood. I believe he was speaking specifically about the "Spine" bikes.
Trying to determine the size I referenced the size chart from the catalog. Many of the measurements are similar between 51, 53W and 53, wheelbase seemed to be the one determining factor, although 1mm across a 970mm span is pretty hard to see.
Rode the bike a bit last night, looking forward to 170 cranks and proper pedals, I've clipped the pavement a few too many times.
