Peugeot PH12 Centenary
I was planning to experiment: 1x, ti carbon hubs, custom carbon downtube shifter, sram red rear derailleur/crankset, carbon bars, carbon fork, 24h/18h alloy narrow wheels. 11 speed red casette. Or something like that.
I've just had my mind blown this morning.
For whatever reason looking at this bike, the 54cm frame 'label' didn't sit well with my eyes.
To get it off my mind I got the measuring tape out and, conveniently, the crank bolt cover has a slit right in the middle, measured again: c-c it is a 57cm seat tube and 56cm top tube. How tf did I measure this frame so wrong the first time?
So, took the measuring tape to my Giant, which has a 53cm sticker on it but I was always under the impression it is a 54cm frame.
Result: 50cm seat tube and 52cm top tube c-c.
It measures 53cm to the seat clamp.
That's not the part that blew my mind though.
I swapped the clipless pedals from my Giant to the Peugeot, got on it and this is the bit that blew my mind: I've NEVER sat on a bike in a more comfortable position, in the drops, in my life!!! I rode better saddles though, this saddle is horrific to ride.
I've never thought of my Giant, or any other bikes I've owned in the past in the same size, as too small for my size and was never a problem, but sometimes felt a bit crammed on it, mainly while sprinting hard, it felt like it would tip over if I lean too much into it.
I'm 5'10", maybe 5'11" on a good day, 83cm inseam, maybe 84cm if I loose the few lbs added during lockdown.
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,594 Times
Just a reminder, buying or selling offers are not allowed in the regular forums.
Forum Moderator
Liked 6,594 Times
Quoted: 796 Post(s)
Liked 522 Times
I am of similar size about 5' 11" but with the legs of my 5' 8" brothers and a loooong torso. When I got back into biking in 2000, I spent a decade on a 54cm Cannondale before I realized it was too small I now ride a 57/58 cm in C&V and have never looked back, I tried a 56 last year and it just didn't feel right. And Steel is much more comfortable over the crumbling roads in my area than Aluminum
Forum Moderator
Liked 6,594 Times
Well, time for a change.
Quoted: 796 Post(s)
Liked 522 Times
I actually ride mainly on the tops and hoods but I do find with a bigger frame that riding in the drops is more comfortable when I do it.
Trying to upload some pics here but it will not go past 90% on the first one, done it a few times now, same result. What's going on?
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
Picture file size too large is my guess, so it's timing out(?).
So, this is where I'm at with this bike.
I received the Benotto bar tape ordered but it's not translucent like the old tape. It's some sort of solid pvc textured tape.
I've decided to reuse the old tape, cleaned it and retaped the bars the best I could with the amount of tape available.
I ran the internal brake and gear cables, just dangling there for now. Should finish it this weekend.
Haven't touched the hubs yet as I don't think it's worth it for me to take the wheels apart, so they are still in the state pictured previously.
This bike could do with a deep clean now and I need to remove the tape residue left on the chainstays as well
Also this is the pump that came with the bike, not very knowledgeable about pumps but is this a generic pump or is there a chance to be the original one supplied with the bike?
So today I sorted the cables, adjusted derailleurs, shortened chain etc. All the bits and bobs.
The bike is ready for a deep clean and some t-cut.
I have to say that adjusting friction shifting derailleurs is a walk in the park compared to indexed ones. Take the slack out of cables, adjust limits and done. 👍
All in all about 5 minutes, out of which 3 minutes spent looking for 8mm and 10mm wrench.
The frewheet block thing it's loud af on the stand. It has plenty of grease, enough preload from the lockring it's just...loud, not the usual paw ticking noise, it's like road noise, I reckon it's coming from the axles but I'll have to take it apart again to double check.
Other than that I will call it done, happy days. 🍺
Quoted: 1639 Post(s)
Liked 829 Times
the only "quiet", non-sealed bearing, 80's French hubs and freewheels and I ever owned are the ones from Maillard's 700 series, which was their top of the line model built with much better tolerances and quality than their mid model hubs and freewheels.
IIRC, Maillard did issue a 700 series version of the Helicomatic hubs. Maybe you can check those out and see if they are better than the ones that came with your Peugeot Centennial bike.
BTW, that French Zefal made pump has the Motobecane "M" logo on it.........Maybe it needs a nice Peugeot Centennial decal (seen them sold at Ebay) over the "M" to look "right" on the bike?
I suspect that the loudness of the freewheel can be partly attributed to the smaller diameter than usual ball bearings used in it. A lot of French freewheels and hubs from that time also just did not have the best quality bearing races, unless they are top of the line models. I still remember being frustrated in the 80's of being unable to adjust my hubs and freewheels to eliminate the rumble and noise coming from the Maillard rear huband freewheels on my mid level model Peugeots with Helicomatic rear hubs.
I have never noticed it on older bikes as when I buy an older bike is mostly for the frame and fork, and usually discard wheels and drivetrain in favor of modern components.
Thanks for jumping in sir, saved me some hassle.
Chombi1 I can see your reply in my email inbox but can't see it in here. Unless you deleted it or edited your previous reply. I'm not really looking to accessorize this bike, as it will go up for sale as soon as I find some free time to clean it.
I've been looking for a specific frame for a long time and managed to find it in my size. I'll start a new thread for it soon.
So I finally managed to wash the bike yay.
The weather in UK has been pretty bad so couldn't take the bike out for some nice pictures but, it is officially done.
Turned out great. I'll try to take some pictures indoors but probably won't do it justice.
I will start a thread as soon as I can take some pictures, for the frame I just got.
Liked 1,295 Times
Good job.
This bike is a GREAT example IMO of just how well that Peugeot addressed the needs and desires of buyers looking for a budget racer.
I would be kind of thrilled to find a bike just like this one for sale locally.
thank you sir. hope to post some pictures of it done very soon, just waitin' on sunshine.
