1958 brake on Campy DT levers?
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 984 Post(s)
Liked 634 Times
Had not looked much at the bike (1958 Drysdale) before, but as I am working on it now, had not noticed this. I thought this era, I'd be seeing the downtime levers on a band. But there are 'tabs' brazed on. On a newer bike, the central "barrel" stays with the frame, brazed on, and everything else comes off. On this frame, "gentle" prying does not loosen the backing plate with cable guide, nor the disc that the lever enters on adjacent to it. Could those be integral to the brazed on part, meaning further prying will damage the part? Or by definition will it come off. Getting ready for the oxalic acid bath, I kind want it removed first -- if possible. Never seen on like this before.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
1958 Braze-on Campy DT levers?
Had not looked much at the bike (1958 Drysdale) before, but as I am working on it now, had not noticed this. I thought this era, I'd be seeing the downtube levers on a band. But there are 'tabs' brazed on. On a newer bike, the central "barrel" stays with the frame, brazed on, and everything else comes off. On this frame, "gentle" prying does not loosen the backing plate with cable guide, nor the disc that the lever enters on adjacent to it. Could those be integral to the brazed on part, meaning further prying will damage the part? Or by definition will it come off. Getting ready for the oxalic acid bath, I kind want it removed first -- if possible. Never seen on like this before.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 984 Post(s)
Liked 634 Times
I can take another photo, but with my digital camera's lack of a macro lens, I'm looking at a further-away image to get good focus and not sure it would help. I suspect you are right and this is as disassembled as it gets, so it will need to be masked prior to the powder coating. It's just... odd. I cannot say, but I guess it's possible this is indeed a chopped-up set of banded levers; anyone ever see something like this?
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,478 Times
See this recent thread for a discussion of the same. Seems this was somewhat common.
https://www.bikeforums.net/classic-v...ing-build.html
Brent
Brent
Quoted: 3464 Post(s)
Liked 2,829 Times
They existed.
i have them in a 1958 frame
not the same type as shown here- no “lug” extensions.
the thick washer and backing plate are separate I am pretty sure, perhaps just married to the frame by habit.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
Quoted: 984 Post(s)
Liked 634 Times
