Finding right tool to remove old Suntour BB
Bikes: Rodriguez Adventure Touring, Rodriguez Tandem, Trek Mtn Bike
I have an old bike I’m trying to get running and it has a Suntour bottom bracket. I’ve tried to upload a picture of it but since I’m a new member it appears I’m not able to. Does anyone have a suggestion for finding the needed tool?
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I don't know about a Suntour BB but I would be surprised if a Sugino BB tool would not work.
Real cyclists use toe clips.
jimmuller
jimmuller
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Assuming you mean the SunTour cartridge bottom bracket, this is the tool. They aren't common but they do turn up on occasion on eBay. An established bike shop or co-op might also have one.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
I bought one on eBay for $17 a few months ago. There were a few at $35.
It seems there's never any around, then there's like 20 of them.
Do you NEED to remove it? In other words, are you changing the crankset or are the bearings shot? There's no real maintenance you can do on it- if it's fine- it's fine. Just leave it.
Commence to jigglin’ huh?!?!
If the cups aren't stuck, an adjustable pin spanner, used carefully, works just fine.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
I use the same method while arriving at my final adjustment of the adjustable cup on a cup/cone bb, since it settles the treads more securely in the typically-contaminated threads in the shell.
In the case of these Suntour bb's, which I have used, I would want the cups to be quite tight against the cartridge.
I remember these bottom brackets, along with the long-cage version of the Superbe rear derailer, being a couple of parts found on Cannondale's best touring bike but almost nowhere else.
I had an extra one of these tools, but modified it for use on the bulky-looking Suntour cartridge bearing hubs with the external lugs/splines.
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
I used an adjustable pin spanner for years on one of these, which worked fine.. I ended up getting the Suntour TA230 tool, when I saw one for like 10 bucks on eBay and just because. The discontinued yellow Park pin spanner also works on these.
Thanks for all the responses! JohnDThompson, the tool you suggest looks like the one to remove the lockring, but maybe not the bottom bracket itself. See the attached image that shows the BB with the lockring removed. Is a different tool required to take the next step?
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
John showed the correct tool, the Suntour TA230 tool. The left side in his picture slots inside the bottom bracket cup and is used to turn it.
Liked 1,699 Times
the 3 "teeth" on the left side of the wrench fit into any of the inside notches that are on the BB cup.
Let me know if you need a pic.
mkeller234
Classic & Vintage
8
12-01-20 09:39 PM
Classtime
Classic & Vintage
5
05-28-18 08:31 PM
boneshaker78
Bicycle Mechanics
13
09-19-16 11:49 AM
