Will you ever go disc?
#301
Quoted: 20810 Post(s)
Liked 9,456 Times
To be clear, you're disagreeing because you consider hydraulic disc and mechanical rim brakes the same so far as servicing? If I have that right, then yes, we disagree.
As I said above, I don't consider maintaining hydraulics as especially difficult, but I do see it as a fair more of a pain then rim brakes.
edited to add: as far as your first point, I actually view hydraulic disc as being easier in terms of servicing because brake pad changes are easier and more involved servicing is less frequent.
#302
Kit doesn't match
Probably because you're more familiar with rim brakes from years of use. My first road bike was 9 years ago and I don't recall my early rim brake servicings to be any less fiddly or complicated.
#303
Yeah it was a nos de rosa nuovo classico. they still make that frame though. mine is only 2-3years nos.
If they somehow would have made that frame available with discs i would have gotten discs. I really dont see any point going caliper over discs. and i never have.
I once tried to convince tommasini to make me a lugged steel road bike with disc mounts but they refused. that would have been kick ass though! I guess they can do it but they just dont want to.
as opposed to everyone else in here i actually strongly prefer mechanical discs. They are pretty much as simple as calipers to work on and have about 80% or so of the modulation/power that hydros have. But when something goes wrong with hydros i can be a 3 hour job, and in some cases you will never be able to fix the problem. Not so with mechs. So i prefer them basically because for me they are less of a hassle to keep going 100%. KISS principle applies.
Also my shimanos freeze up to solids at -25C. BB7 not so much.
I built my first road disc in 2008-9 or so. and then there were no road disc hydro levers at all. So cable it was. and it was a good choice in retrospect.
#304
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times
That's not really the point of disc brakes.
With hydraulic disc brakes you can modulate the braking power better, with very little effort on the lever.
Discs also eliminate rim wear. Some rims cost $1000 each, and some wheelsets are over $6000
https://road.cc/content/review/22033...-c-disc-wheels
I have very recently “upgraded” my 10 year old Edge 500. I think I am safe in the sense that rim wear on expensive wheels will be a problem I’m to experience, considering it is very highly unlikely that I’ll spend $1000 on a single rim.
For the record, I do own a bike with cable actuated hydraulic disc brakes, I just don’t believe I need that much of stopping power on my road bike. That’s all.
#306
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times
Looks like someone is lacking reading comprehension, but whatever. If it makes you feel superior, more power to you. Let’s not converse again until you gain some intellectual “capacity”.
#307
Liked 9,456 Times
Likes For WhyFi:
#308
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times
Perhaps. In my experience, I find the lever travel to lock up to be more on the rim brakes. I’m on my last set of kool stop salmons though, and they do compress more compared to the black Ultegra rubber that came with the group set.
#309
bb7 road gives the exact same lever travel as calipers.
#310
Quoted: 4717 Post(s)
Liked 1,882 Times
If you ever try a long mountain descent, you might one day understand why this is important.
#311
I did. For like 3 weeks. Wasn't for me. Disc brakes are amazing. But I find them equally annoying. I love pulling most parts of my bike apart and throughly cleaning periodically. Having to bleed brakes when you disconnect hoses sucks. Discs also rub. No matter what your experience is, I don't care. They rubbed on all disc bikes I've ridden. I set it up perfectly. They would be dead quiet for couple hours and start rubbing afterwards.
I love the modulation. I love the rain performance. But my best descends are still on my rim brake bike. Handling characteristics of a bike have much more impact on descending than brake performance IMO. So the usual "you descend faster on a disc brake bike" is a bunch of BS.
Anyway.. If the brake rub is completely eliminated, weights significantly reduced and if they come up with a system like after market motorcycle brake lines where you can disconnect cables without introduce air bubbles in to the system, I might check it out again. Also quick bleed system like motorcycles where you undo a bolt, squeeze the brake 3-4 times and tighten (where the squeeze pushes bubbles out but doesn't let air in)
#312
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
I'd like to change my answer, now that I have experience with hydraulic disc brakes. They are fantastic!!
I bought a gravel bike with 105 hyd brakes, they are great offroad, as expected. What really surprised me was when I put on a set of wheels with road tires and took it out on my normal 40 mile loop today. They are confidence inspiring. I can go into curves with more speed, brake later and harder and still have more control. They are absolutely better than the rim brakes on my road bike (direct mount Ultegra), with either alloy wheels or carbon with textured brake tracks, there is no comparison.
I'm sold. My next road bike will have discs.
#313
One important issue in the disc vs rim brake debate: What do the pros use? What the Tour de France riders actually use will drive the market as well as anything else.
No pro team will use something that gives them a disadvantage!
#314
My old bike had 17,000 miles on the same wheels and the rims were not worn down to the wear markers. My disc bike has just over 1,000 miles and there is about 1 mm wear on the disc!
#315
Quoted: 18883 Post(s)
Liked 10,646 Times
That's odd because from what I've heard the possibility of a Chinese throwing rotor keeps these pros up at night in a cold sweat, but also from what I've heard "the industry" has made the choice for everyone, there will only be disc braked bikes by next Tuesday, Obama is going around confiscating people's calipers.
#316
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Not likely. I've got too many rim brake bikes, all with very good stopping power plus I have 55 years of experience riding and stopping in the rain. Got into the habit of slightly dragging the brakes in major wet riding a long time ago anytime I might need to stop.
I change out wheel all the time. I flip fix gear wheels, have several wheels for each dropout width standard with different FW/cassettes and tires and borrow wheels of different bikes. No desire for yet another wheel standard. Love how easy rim brake wheels are to swap. Plus light, cheap and easy to maintain. And it gives me an excuse to do my favorite hobby without going into wheel N+1, replace the rim and rebuild the wheel.
Ben
Ben
#318
Get mechanicals instead. i have bb7 road and bb7 mtn and they are much, much dependable and less finicky than hydros. by like a factor of 100 or so. no S! seriously.
i simply laugh at the idiots insisting on hydros. they dont know jack S. But they will find out how all this works soon enough! hahaha.
#319
Liked 9,456 Times
hydros can be finicky setting them up and adjusting them. basically there is never the same the same friction in 2 or 4 different pistons. so its much much morwe likely to rub on any side/piston. no matter the actual system or maker. they are all affected by this. all hydros work like this. almost impossible to keep them from rubbing over the long run.
Likes For WhyFi:
#320
whyfi.
well he mentioned "discs also rub" which is actually the most common "problem" with discs. hydros that is. because the fluid in the lines and calipers expand with temps and with water/air content (that they may or may not), absorb. I simply explained how i solved that very problem. and its a very elegant solution.
Likes For noodle soup:
#322
Yeah i've only been on discs since 2008, as my only form of transportation, so w t f would i know about discs right, doing only 7-10000km a year or so.
but yes noodle soup i gotta hand it to you, you are obviously better at posting on the internet than me. because you see, i actually have a job. a very demanding one.
#323
Quoted: 1068 Post(s)
Liked 786 Times
Disc brakes RULE Enjoy them on my Roubaix
#324
Liked 1,882 Times
I see you'v been put in Time-Out for 7 days, so I won't hold my breath waiting for you to respond.
#325
Liked 9,456 Times
