Weight training and bike in the same day?
Meow!
Bikes: Trek 2100 Road Bike, Full DA10, Cervelo P2K TT bike, Full DA10, Giant Boulder Steel Commuter
Hello all again,
I just back from the gym (yes I know it is late) and I was thinking something. Can weight training (upper and lower body) be combined with endurance training (E2, M1, F1, etc) in the same day? Right after each other? Split (one in the morning, one at night)? Would that be overtraining for one day? Of course this all assumes that you do active recovery after the workout, recovery drink, food, etc.
I am applying for local PDs and I have no choice to work out anarobic weight training for upper body strength. I usually do 3 sets of leg presses, leg extention and leg curls when I do my weight training. I do weight training 3 times a week upper and try to only do lower body 2 times a week. Other than the power benifits I would also like to have more defined muscles in the legs... intimidation... .
What do you all think, is a short endurance run bad after weight training?
Thanks
Thanks
Just your average club rider... :)
Stegosaurus
Bikes: 2004 Giant OCR-3
In terms of your progress in bulking up, and increasing your strength, endurance training post-workout is very bad. But as long as you recover with a few hours rest, and a good bit of food heavy on protein and calories, then you're fine. Its not too much of a tradeoff then.
Might I suggest though, getting off the machines for lower body, and starting to squat and deadlift? You'll get more powerful overall this way, in addition to seeing better progress in your legs.
We debated this exhaustively some months ago. Do a search in this forum. I was in the thread alot, so use my username if you can't find it. It was one of the first threads I got into.
Meow!
I have read the posts on that. My main concern is my upper body at this point which endurance training should not hurt. For the lower body I might drop the weight training to once per week and dp most of the work on the bike in that respect. Most of the stuff I have read says no to anarobic strength training after base 1. I guess you want to build kean quick muscles in the legs and not big bulky ones...
Interval trainign I supose...
I would think that if you do endurance training first then anarobic after you may be better... any ideas?
Guest
Posts: n/a
Quoted: Post(s)
Yes, you can do both... but make sure you're not doing high intensity work for your cycling.
Also, from what the recent seminars have been preaching, you should do the weights BEFORE you do the cardiovascular. You will definitely compromise the amount of weight your muscles should be able to withstand if you do the cardio first, but the studies done I've read about say that the cardiovascular will not be as adversely affected as weight training if you do the weights first. A couple of seminars I attended even said weight training would be beneficial to the cardio because the lactate buildup in the muscles would be used for energy to drive the Kreb's cycle. With the excess lactate in the blood before commencing cardio, you should be able to sustain a longer endurance training session.
All this is contingent on the fact that you are NOT doing anaerobic work... your intensity would have to be low enough so that the lactate accumulation in the blood is able to be recycled through Krebs. Krebs is limited when you exercise in such a high intensity that you accumulate even more lactate in the blood.
Beyond that, I don't know if I could give much more information. You really need to coordinate your training program with someone who has knowledge of what your abilities are and can coordinate your weight training and cardiovascular routine.
Koffee
Koffee
Meow!
I am going to start working with a personal trainer that was recomended by some people who I ride with. I think Koffee makes alot of since, since I already do cardio and weight training the same days in the gym (crosstraining by running). I hope that when I start working with a trainer I can start working on getting a plan together that will allow for weight loss, muscle growth in upper and lower body and muscle endurance in my lower body...
Guest
Posts: n/a
Quoted: Post(s)
If you work with a personal trainer and you want to discuss cycling, make sure they have enough knowledge to discuss cycling. Otherwise, you may find yourself in some troubl with your training later on.
Definitely, though... I recommend a personal trainer for your strength training.
Koffee
Koffee
Stegosaurus
Just remember: cardio melts muscles. Most especially if they're actively recovering from a hard workout. So you've got to juggle things a bit. If you can split it up across the day, then do. Absolutely do cardio after lifting, if you must do both in the same session. But since you're pretty dedicated and have the time... I recommend that you don't do them together.
I can't stress enough how much you need to squat and dealift heavy, for overall power and development. As in upper body too. I have no idea how that would affect your cardio periodization, though.
Guest
Posts: n/a
Quoted: Post(s)
It affects it. Weight training is recommended during the lower intensity cycle of your periodization program. Less by the time you get to doing focussing on higher intensity. That doesn't mean you should stop... period. It just means you should cut back. Personal trainers will know how to cut back to where you can still maintain muscle mass and not lose the gains yo've made.
Koffee
Koffee
Bikes: Specialized MTB
How much practical difference does all this make for the average schmuck who just wants to be a little more fit? Sometimes it's difficult to schedule everything optimally, and sometimes I just like to be spontaneous. Maybe I'm out riding my bike, and I suddenly decide to scoot home and do a bunch of squats. Am I going to either harm my body, or get significantly less benefit for my efforts. I am willing to work hard, but I won't stick with all this fitness stuff if I can't have fun and be spontaneous sometimes. What wisdom from the gurus and pundits of physical fitness?
Guest
Posts: n/a
Quoted: Post(s)
For the average schmuck, just make sure you're getting in enough dailly physical activity and eat right. You should be ok. But if (for instance) spontaneous to you means you lift once every 10 days, and you ride two days and take off 4, then ride two more days, you won't see very much in the results. You should try to be a little more consistent with your exercise, and always be spot on with your nutrition.
Koffee
Koffee
So say we all.
Bikes: Gary Fischer Wahoo, upgraded Specialized Allez
"All this is contingent on the fact that you are NOT doing anaerobic work... your intensity would have to be low enough so that the lactate accumulation in the blood is able to be recycled through Krebs."
The moral of this story is that Koffee can beat us at a bike race OR at scrabble.
Seriously, where do you find this out? I used to lift weights regularly until I dated a runner, then switched almost entirely to cardio sports. I try to keep myself well-educated about fitness but there's apparently another level of knowledge entirely. As a grad student, there's no way I can afford a personal trainer. Besides the seminars you mentioned, where do you get your info?
I'm guessing it's not from the magazines with the blonde chick and the guy with the six-pack and the headline "Better abs in 10 minutes a day".
Guest
Posts: n/a
Quoted: Post(s)
You would really have to attend a few of the fitness conventions and go to the different seminars in the area (or out of the area in my case, since I've attended conventions worldwide). Besides that, do lots and lots of reading. Then you have to teach or just apply the knowledge so you can put it all together. Once you know how to put it all together, you can train others.
Those fitness magazines like Men's Health, Shape, Prevention, etc. just give nothing. It's like being a professional cyclist trying to glean imformation about cycling from Bicycling Magazine.
Koffee
Koffee
Koffee
