Low stack height 1" threaded headsets?
Quoted: 16 Post(s)
Liked 42 Times
I'm currently looking for a low stack height headset for a 1" threaded fork. I did some searching but the last thread was from 5 years ago.
I've found the Tange Passage which is 30.2mm. They're really inexpensive....are these decent? It's just for recreational/city riding.
Anything shorter? I'm currently shopping for used forks and every extra mm counts when you're limited to forks with pre-cut tubes.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
The Tange Passage headset is made in Japan and is very good quality for the price. Nothing fancy, but will definitely last a long time if properly greased and adjusted. You will be hard pressed to find anything that isn't complete junk with a shorter stack.
Brown Jersey Winner
Quoted: 243 Post(s)
Liked 13 Times
while i dont have any actual helpful advice to give you, i would however, like to congratulate you on not only using the search function correctly, but not resurrecting a thread from the previous decade.
I just installed one on one of my Vintage Bike Frames. Not bad for a sub $10 headset, I needed all the help with stack height I could find, it was about the only one I found. I think all Vintage Bikes were cut for a low stack height,
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
That's some short stack there with the tange passage.
If you want fancy with short stack check out the dura ace 7600 headset. It has a pinch more stack at 31mm but dura ace quality with bells and whistles such as titanium nitrite coated races and polycarbonate body.
A bit rare and pricey though.
Quoted: 16 Post(s)
Liked 42 Times
Awesome. Thanks for the help.
It's always a bit shocking when you see it's only $10, made in Japan, and then people mentioning it's actually decent quality.
Bikes: Civilian Le Roi Le Veut, Kazane Track, Ciocc Designer '84, Serotta Colorado AL 25th anniversary, '85 Guerciotti Pista, '84 Trek 660, Volume Credence
The Ritchey Logic threadless headset has only 27mm of stack and is totally fine. I have been using one on my beater for over a year with no issues.
lostarchitect
Bicycle Mechanics
27
11-04-13 12:32 PM
jeffpepperdine
Classic & Vintage
16
01-11-13 05:32 PM
jeffpepperdine
Bicycle Mechanics
6
01-11-13 08:31 AM
