Do I need this chain guide?
Thread Killer
Quoted: 3147 Post(s)
Liked 1,712 Times
Folks,
I’m perplexed by this chain guide thingy which came on my bike. It seems like it cannot be positioned to really do anything, so I’m wondering if I cannot just pull it off without concern.
It’s a 1 x 10 setup, with a guarded 40t chainring and 11-42t cluster.
I have the guide/keeper positioned as close to the guard as I can get it, aligned so that it doesn’t rub in any gear, but the trailing end is dropped as low as it can go, in hopes it might catch some chain if it decides to come off and do something to retain it. Could it be installed improperly?
It strikes me as a really clunky piece of kit if not an utterly useless one; I’ve seen some pretty discreet chainkeepers— if that is, in fact, what this thing is— but this huge piece looks like a fixed derailleur. I tied to spice it up with some anodized bolts, but visually I’d rather be rid of it, so if it’s superfluous or there are better options, any insight would be appreciated.
As you can see in the pic, it’s well proud of the chain and not capturing it at all. The guide channel is not wide enough to overlap both the ring guard and chainring, so it cannot be lowered, and the guide plates are to thick to slip between the ring guard and chainring, so it cannot be lowered to capture more chain for that reason, too.
Really, I cannot get my mind around this piece; is it only effective when in the
40/42 combo? I don’t get it. Please help!
Thanks!
Thanks!
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
The chain guide is likely there to prevent a dropped chain. When you shift in the rear, a wave propagates up to the front and may lift the chain off the ring.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,694 Times
If you don't have a clutch rear derailleur, you'll want to keep that on there or the chain will likely drop occasionally while shifting gears or riding on bumpy ground/pavement.
Unless you have a narrow-wide chainring and a clutch derailleur, you need some means to keep the chain on it.
If you don't like the guide, you could do something more discreet, like putting a chainguard on both sides of the ring. My Dahon folding bike has the chainring "sandwitched" between 2 chainguards and it works. Sometimes I hear a metal "clank" when shifting and it's the chain hitting the metal guard, so they seem to do their job.
Thread Killer
Liked 1,712 Times
I didn’t realize that simply shifting would cause chain drop. I thought it took bumps or shocks to do that, especially across the upper run, where the chain is under tension...or are you saying the wave travels backwards, across the bottom and lifts the chain from the underside of the chainring? Such a chainguide would seem to be in the wrong place for a mechanism like that.
Thread Killer
Liked 1,712 Times
it’s a Deore Shadow Plus, so it is clutched; you think the guide is superfluous, then?
Thread Killer
Liked 1,712 Times
I’ve payed attention to it but cannot hear any contact between chain and guide in any gear. It came preinstalled on the bike, and when going over it out of the box, it seemed positioned so high that there was no way it could have contacted the chain, so I brought down, in as close as I could to the chainring and without any rub in any gear.
This is my first 1x setup, so I’m not familiar with problems specific
to that kind of setup, but I see lots of 1x bikes without such a guide and wonder what the difference is that this bike needs one. Given it seems unlikely it could even do anything, I’d really prefer to remove it if it is indeed unnecessary.
Thread Killer
Liked 1,712 Times
Oh, I get vinyl transfer decals made for most
of my rigs! There are lots of online shops who make them, and I like https://www.customvinyllettering.net/.
Here are a few of the others:
I dunno if if the ring is “narrow-wide,” but the RD is clutched (Deore Shadow+).
r
Thread Killer
Liked 1,712 Times
Thread Killer
Liked 1,712 Times
I guess I'll just take it off and see how it goes.
Thanks for the help!
Take it off then. You shouldn't need it.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
It costs you nothing to remove it and just how it works. I have a fatbike with a non-clutched rear derailler and a "poor man's" 1x drivetrain -- I took the large ring off the crankset and I'm using only the small ring. I removed the front derailleur entirely, I don't have a chain device, and the chain ring is not a narrow-wide design. Despite that, I haven't dropped a chain yet. I couldn't say that it'd never happen, but it's been fine so far. You could remove it and see how you make out. It'll cost you nothing but time...and perhaps some greasy fingers if you do drop the chain once or twice.
Likes For hokiefyd:
Likes For Amt0571:
Quoted: 840 Post(s)
Liked 336 Times
Is there any other reason for a chain guide?
Quoted: 1062 Post(s)
Liked 665 Times
I was dropping the chain on my Diamondback 1x9 all the time. It had a chain guide too. Of course Murphy's Law dictated that it only happened at the most embarrassing moments. Switching to a narrow-wide ring was like night and day -- no drops since then.
Quoted: 194 Post(s)
Liked 204 Times
My 1974 Carlton never had one, but it was only 1x5, and the only time was when I did something stupid with a badly worn chain. My brother's 2x5 would, if the lever wasn't quite in place.
The chain guide isn't meant to work with that style of bash gaurd so you might remove one or the other. The chain guide is pointless as currently setup. If you don't have a narrow wide chainring I'd loose the bash and keep the chain guide, even on a gravel/road bike that could be useful. The bash is pointless unless you are actually mtn biking.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
Take it or leave it probably not a bad thing but with a clutch and a NW you should be fine. Heck my NW with a non-clutched derailleur (old XT 8 speed) works just fine and dandy and I haven't yet dropped a chain (at least not that I can remember)
I do like the pink bolt on it so I would vote to keep but only for that bolt.
Likes For veganbikes:
Thread Killer
Liked 1,712 Times
