Size 8 helmet - probably XL or XXL
My helmet is over 30 years old and I want to replace it.
I wear a size 8 hat.
I've started chasing a MIPs helmet at a REI, but would like advice on brands and where to purchase. Amazon doesn't have a good filter for this.
Thx
Thx
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times
I have the same hat size. So far the biggest bicycle helmet I have come across is 63 cm which is about 7 1/2, from Specialized and crazy expensive. 65 will fit me and may be loose even. 64 probably fits but may be tight. 63 is probably too small but might be able to squeeze in depending on the design and tolerances.
SuperGimp
I would purchase one where you can try it on - different helmets fit differently (round vs oblong).
I have a 7 3/4 noggin and I'm comfy in a Giro Large.
I would advise getting out there and trying on some helmets first. Depending on the shape of your skull, some brands may fit a lot better than others. It is definitely the case for myself.
Bikes: '12 Giant Sedona, '15 Specialized Crave
I had the same problem. If you want a road style helmet look at the Bell Kingfisher. This was my first helmet. If you want a more mountain style look at the Bell Stoker. Both of mine came off Amazon and they both fit me well.
Quoted: 2604 Post(s)
Liked 1,933 Times
Assuming American hat sizes, a size 8 is about 64 cm. For most helmets, that would translate to XXL. All the reputable helmet manufactures have sizing charts on their websites.
got the climbing bug
Bikes: one for everything
Quoted: 632 Post(s)
Liked 912 Times
You should be fine on a Giro XL with size 8 ball cap. They are pretty adjustable as well unless you have an afro, then it may be bit challenging
Rule #10 // It never gets easier, you just go faster.
Absolutely hated the Large Brooks Harrier helmet on long ride cos of the shape. The sides absolutely press onto the skull...
