80mm 45 degree stem
80mm 45 degree stem
Old 03-03-22, 05:16 PM
TheFort
Quoted: 54 Post(s)
Liked 6 Times in 6 Posts
80mm 45 degree stem
Hey guys,
I'm having a hard time finding an 80mm 45 degree stem. I'm somewhat new to biking, so my question are: (1) does anyone make this stem and (2) do you know of anywhere it's in stock? I can find 80mm 35 and 90mm 45 everywhere, but I can't find 80/45!
Thank you
TheFort is offline
Old 03-03-22, 07:51 PM
Kedosto
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times in 190 Posts
Those are on the shelf right underneath the hen’s teeth.
Kedosto is offline
Likes For Kedosto:
Old 03-03-22, 08:33 PM
PDKL45
PDKL45's Avatar
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times in 115 Posts
You're going to struggle to find an 80 mm stem at 45 degrees.
Why not just go for one of the Ergotec 90 mm stems? A few of these would work just fine.
Products - Ergotec
PDKL45 is offline
Likes For PDKL45:
Old 03-03-22, 08:45 PM
TheFort
Quoted: 54 Post(s)
Products - Ergotec
I will look at them, but I have a short torso and very long legs. I really think I need the 80mm. Right now I'm on 80mm 35 degrees per the bike fitter's recommendation, and it's just a little off - could use a few mm of reach reduction and a few mm of stack.
TheFort is offline
Old 03-03-22, 09:21 PM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
Are you already using a steerer extension?
If not, you might want to consider one instead of need a 45* rise.
I would guess and 80/45 probably has the same reach as a 70mm without that much rise.
John
70sSanO is offline
Old 03-03-22, 09:37 PM
TheFort
Quoted: 54 Post(s)
John
I asked about that, but they said it's a carbon steerer that's actually attached to the fork.
Is it just impossible to manufacture an 80/45 due to the angle or something?
TheFort is offline
Old 03-03-22, 09:41 PM
Troul
Troul's Avatar
Liked 2,979 Times in 1,920 Posts
might be possible to change the bars out to something with a slight rise built into them & fit it with the appropriate stem from there?
-Oh Hey!
Troul is offline
Likes For Troul:
Old 03-03-22, 10:12 PM
PDKL45
PDKL45's Avatar
Quoted: 233 Post(s)
Soma Condor 2 fits the bill and would probably be better for a carbon steerer.
Condor 2 Handlebar | SOMA Fabrications
PDKL45 is offline
Likes For PDKL45:
Old 03-03-22, 10:26 PM
70sSanO
70sSanO's Avatar
I did a quick search and You can get a 75mm 40 degree (Profile Design) or an 80mm 40 degree (Satori).
John
70sSanO is offline
Old 03-03-22, 10:37 PM
ColonelSanders
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 312 Times in 220 Posts
Originally Posted by TheFort
Hey guys,
Thank you
What about 80mm 40 degree stem?
Procraft SL 31.8 Stem 40° comes in lengths of 60mm, 70mm, 80mm, 90mm, 100mm, 110mm, 120mm and 130mm
ColonelSanders is offline
Likes For ColonelSanders:
Old 03-03-22, 10:41 PM
TheFort
Quoted: 54 Post(s)
Great, thank you. I'll put it on my watch list.
It looks like it reduces reach 6mm and raises stack 4mm when compared to my 80mm 35 on the bike now. I just need a little more comfort, so this might do the trick.
TheFort is offline
Old 03-03-22, 10:58 PM
Kedosto
Quoted: 564 Post(s)
Why not just go for one of the Ergotec…?
Products - Ergotec
That’s one of the wildest collections of stems I’ve ever seen.
I can’t help but think there’s a significant bike fit problem here. I’ve never seen an outlier part installed on a bike that wasn’t some kind of work around for an improper fit. I don’t know the details, but this one seems odd.
Kedosto is offline
Likes For Kedosto:
Old 03-03-22, 11:04 PM
MarcusT
MarcusT's Avatar
Quoted: 766 Post(s)
Liked 617 Times in 344 Posts
Ritchey makes a an adjustable 90mm stem which can go to 55 degrees. Remember the sharper the angle (upward) the closer the stem will be.
Also remember that 80 mm@ 45 my not be the perfect setting.
MarcusT is offline
Likes For MarcusT:
Old 03-03-22, 11:14 PM
TheFort
Quoted: 54 Post(s)
As I mentioned above, super long legs and a short torso. I have a 34.5" inseam and I'm 5'9. That's the outlier!
To add to the problem, I want to be in a recreational/touring position rather than a race position.
TheFort is offline
Likes For TheFort:
Old 03-04-22, 12:04 AM
wesmamyke
Quoted: 196 Post(s)
Liked 86 Times in 76 Posts
Have you tried the stem comparison tool? When you start getting into high rise stems it's helpful, the reach numbers are often different than what I thought I was getting. Also after 45degrees extra length can just be bonus stack height.
Stem Comparison Tool | yojimg.net
wesmamyke is offline
Likes For wesmamyke:
Old 03-04-22, 10:39 AM
TheFort
Quoted: 54 Post(s)
Yeah I have seen that. It's very interesting. A 90mm 45 degree stem actually has less reach(-7mm) and more stack (+16mm) than my 80mm 35 degree stem, which is counter-intuitive. I might try a 90/45 since that's about what I need in terms of reach reduction and stack addition.
TheFort is offline
Likes For TheFort:
Old 03-04-22, 10:51 AM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times in 7,209 Posts
...it's too late this time, because you already have the bike. But this anatomical configuration (longer legs and shorter torso), was the reason for the design and sale of the old "women's specific" bike frames. Like the ones made and sold by Terry. Just as an FYI for the future. I think you can still find those around used, but the new ones are all custom. If you're going to spend the money on a custom frame, any builder will fit it to your unique anatomy.
A lot more practical to figure out your stem workaround.
I know you've probably tried this with the fitter, but I'll ask anyway. Is the saddle all the way forward and are you using a zero setback seat post ?
3alarmer is offline
Likes For 3alarmer:
Old 03-04-22, 10:57 AM
Leisesturm
Quoted: 2496 Post(s)
Liked 739 Times in 523 Posts
They are ugly, and also heavy, but an adjustable stem would do what the o.p. wants. I do concur, however, with any opinion that suggests that there really is more than one way to skin this particular cat. The laser focus on an 80mm/45deg is hindering any thinking outside the box.
Leisesturm is offline
Old 03-04-22, 11:03 AM
TheFort
Quoted: 54 Post(s)
The seatpost the bike came with had a 20mm offset. So i just changed that out yesterday for an inline/zero offset post. I've only done one ride in that configuration, but it was pretty good. The saddle is now in the middle of the rails instead of on the back end, too, which is probably safer. I could move it forward a little, but I don't want to get ahead of the pedals.
If I ever get another bike it will be custom now that I know my anatomical shortcomings better.
TheFort is offline
Old 03-04-22, 11:24 AM
Craptacular8
Craptacular8's Avatar
Quoted: 185 Post(s)
Liked 36 Times in 31 Posts
This stem from VO would meet that latter requirement. https://velo-orange.com/collections/...py-stem-31-8mm
Craptacular8 is offline
Likes For Craptacular8:
Old 03-04-22, 12:58 PM
wesmamyke
Quoted: 196 Post(s)
I've played that game, don't compromise saddle position for reach. Get the saddle right first, then do whatever needs to happen to get the reach right.
Old 03-04-22, 01:03 PM
soyabean
soyabean's Avatar
Quoted: 540 Post(s)
Liked 416 Times in 274 Posts
Why not an adjustable stem? Weight issues?
If not, I've installed plenty of them for clients, and they love it.
Most suburban folks buy mountain bikes because they look good and status, but ultimately just want to ride upright like a commuter hybrid bike.
soyabean is offline
Old 03-04-22, 02:00 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
I've used those high angle stems for years. Most drop bar bikes come with the handlebars lower than I want them.
tyrion is offline
Likes For tyrion:
Old 03-04-22, 11:52 PM
PDKL45
PDKL45's Avatar
Quoted: 233 Post(s)
That stem is basically identical to an Ergotec High Charisma as, per my link above.
PDKL45 is offline
Old 03-05-22, 07:24 AM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 646 Post(s)
Liked 1,044 Times in 667 Posts
If you switch to touring bars, you will handle all of the fit issues without breaking a sweat. Now, there would be different brake levers and shifters needed, assuming you have brifters now.
Otto
ofajen is offline
Likes For ofajen:
