1x11 or 2x11 - gravel/road plus bike recommendation
Quoted: 50 Post(s)
Hello, I have Planet XLS CX bike and make some changes now. Used it for many purporses, but now want to make "final" configuration
Variant A: 1x11s
- 42T crankset (maybe XT, maybe GRX)
- 11-34T cassete (HG800) for flats and 11-42/11-40T (XT) for mountains
- RD: GRX RX810
Variant B: 2x11s
- FC-R460 48/34T crankset
- RD: Ultegra RX800 / GRX RX812
What do you think, what will be best option?
I like simplicity, so 1x is very attractive.
Both uses the same cassete on flats (11-34), but even if I will decide to use 11-40/42 on 1x configuration, it's no problem - first six cogs are the same, with 2T differences between each so... It's still more than ok.
- I do not plan to race anymore (I started few times before),
- I do not plan to attack Strava KOMs, because probably I will remove my Strava account.
- I also do not plan to ride very long trip (200 km or more) often - maybe 1 or 2 times per year, no more. Usually I will ride flats, about 40-70 km on roads (many low quality), gravels. If solo or in small group - probably faster than slower. Sometimes with big group, but then much slower. Also will be 2-3 times per year in the mountains, I need 1:1 or close to it then.
- I will use Gravelkings SS 700x35c tires.
Variant A: 1x11s
- RD: GRX RX810
Variant B: 2x11s
By no means an expert but there's nothing wrong with going bigger than 1:1 if you want to go up hills with poor surface quality.
I use a 38 narrow-wide ring and an 11-40 cassette on my fun retro-mod gravel bike. That was in a very hilly environment with snow around. Close ratios don't matter too much to me on the rough stuff, so I'd go bigger rather than smaller on the back if I were you. Especially if you want to carry stuff on the bike like camping gear or 10 beers. Or both.
You're overthinking this. Just get a nice bike with wide tires and go ride. It's not a moon launch, you know...
Likes For Helldorado:
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
I've never found 2x to be complex or difficult, so each time this is asked, I say 2x. I just don't find anything wrong with it and the upsides are tighter gearing and wider range. That then works best for me since probably 40% of my riding is on pavement(getting to and from gravel). Tight spacing with larger crank is nice on pavement and wide range is nice for gravel.
There is no right or wrong- just assess how you will ride(you have) and decide which works best for you in those scenarios. There are benefits and drawbacks.
Quoted: 1088 Post(s)
Liked 1,025 Times
I like my 2x for cross. I'm not fit enough to use that 48t on an actual cross course and while I haven't been on a true cross course I've been riding a number of easier mtb courses and enjoying the 32/11-34. While with 27c tires I've found the 48t to be fast enough for everyday riding and training. It might be in an actual cross race that I could need to shift to the 48 but I've noticed that 11 and 12 speed don't seem to mind cross chaining as much as 8, 9 or 10 did for short distances and an 34/11 is reasonably quick for the short sections of pavement I've ridden in the local races. At the same time I can ride any road around here and never need to leave the large ring, same with any of the bike paths. Kind of dual function but I like it.
Randomhead
Liked 3,698 Times
I have been 1x curious for quite some time, but never felt like I could get the top gear and low gear that I wanted. But now the industry really wants everyone (except people buying low-end hybrids) to be on 1x. I can't see that trend being reversed any time soon, and the current difficulties have accelerated it. Even fairly low-end bikes are coming with 1x now.
I think the hybrids will be next. A lot of people that buy them are not very experienced and probably will do better with 1x. But it's hard to make narrow wide chainrings out of sheet metal.
Sunshine
Liked 7,491 Times
I ride with 30-40 teens a few times a week for 5 months each year and they use entry Trek 3x7 hybrids.
It takes a lot of riding for the first timers to understand gearing and use it properly.
Wide range 1x would be much simpler for the entry rider.
Likes For mstateglfr:
Quoted: 3240 Post(s)
Liked 2,086 Times
I always found it curious that Shimano did a great job with Di2 shifting to the point where shifting the front is automatic. They obviously feel that 2X is still desired and useful.
@the OP. I would think that your 1x choice of a 42 front and 34 rear is not going to give you much low gearing for hills. I’m of the opinion that 2X is the best choice on a gravel if there’s any chance of time on asphalt.
1x is great for specialized purposes but for a road/gravel bike I'd want and have 2x.
I wanted a fairly tight cassette for road riding so I could find a comfortable cadence no matter the speeds so 11-32. For the gravel riding I needed some climbing gearing so 46/30 crankset. For me it has been a pretty good compromise but if I were building it now I'd go for a GRX 48/31 crankset and get a bit more top end back, not that it really matters. 11-34 cassette just on my gravel wheelset wouldn't be a bad idea either, some crazy gravel climbs around here.
Quoted: 50 Post(s)
I'm not sure, but probably I can't install GRX 48/31. I use CX70 top pull front derailleur because it's feature of that Planet X frame. It had 105 5700 FD down pull in original and something like "roller", but it didn't work great so I replaced that by top pull FD.
That CX70 can work fine with RX600 46/30 and changed chain line, but... will work with bigger difference (17T on 48/31)? I afraid no, and then I will have to mount roller again and change also FD to GRX - without guarantee of success
Quoted: 166 Post(s)
Liked 252 Times
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
1x is good for solo riding, or for more casual rides.
2x is good for a bike that is going to be ridden in a group, where you can't always choose the pace, and good for a bike that is both ridden fast on the road (i.e. slicks) and grind up a gravel climb.
Really, its a matter of if the cadence gaps matter to you.
2x is pretty simple (and on my bike was lighter). Simplicity wise, I have less chain/cassette wear on 2x, because I'm not spending much time in small cogs (<14t). Sprinting or doing hard accelerations on small chain rings is going to cost you over time with maintenance/wear. And the tight ratios on a shimano 2x just shift so tight and quick. But, if you are not spending a lot of time hammering at 25+mph, that stuff is not an issue.
1x does look nice and clean.
Likes For chas58:
Quoted: 1461 Post(s)
Liked 1,485 Times
Chas58 pretty much nailed it.
I'm a 1x fan and have two drop bar gravel/cx bikes with 1x drivetrains, but it is definitely more specific and more limited than 2x. As a blanket statement, 2x is going to give you more range and more flexibility, with tighter gear spacings. I like 1x for the simplicity, clean aesthetic, and elimination of a component that I don't really need for the type of riding/terrain I'm doing. It's one less thing to maintain and get clogged up with mud, one less part to replace if broken, and one less shift to think about when CX racing. I run either a 40 or 42T front, paired with an 11-32 or 11-34 cassette. It's so flat here that 90% of the time I'm only using 3-4 gears when I'm out riding, and if there is a climb or a downhill, it's over in a matter of seconds. The gear jumps on those cassettes are perfectly acceptable to me.
That said, if I made 2-3 trips to the mountains every year and/or did rides with significant climbing and descending, I'd likely choose 2x for a gravel bike. I would definitely want 2x on a dedicated road bike, or really any bike that I would use in fast group rides. (I have done some fast group road rides on my 1x CX bike and it's fine, but not ideal).
FWIW - The Shimano GRX 800 front derailleur only weighs 95g. In comparison, those large rear cassettes often add more weight than you save by removing the FD and a chain ring.
Likes For msu2001la:
Variant A: 1x11s
- RD: GRX RX810
Variant B: 2x11s
Variant A: 1x11s
- RD: GRX RX810
Variant B: 2x11s
I was going through the motions when I first built my gravel bike. I decided to go with a 1x11 setup and got the Easton EC90SL cranks that way I can easily swap chainrings. Check out my bike here...
You can read my parts list on my build here... https://www.manualpedal.com/gravel-b...ibis-hakka-mx/
Personally, I like the 1x11 setup and I'm running a 40T currently and I have a 42T ring as well which I haven't swapped yet. I'm not as fast as I am on my road bike but that's what my road bike is for. In terms of racing, I plan on racing my gravel bike next season hopefully if COVID permits. I will put the 42T ring on it for that.
Sunshine
Liked 7,491 Times
So then they get a bigger cassette and the jumps are larger, which they may not like.
You know this though...right?
I'm going to disagree with most of the other posts, the ones that suggested an 11-34 cassette. I run a 10-42 cassette with a 46/30 crankset on my road/gravel bike. My dedicated gravel only bike is 1x, a 30T chain ring and a 11-46 cassette, with 29x3 tires. Not much top end, but it is not necessary on gravel. My Gf's gravel bike is 27.5 x 2.1, with 1x, 32T chain ring and a 9-46 cassette. That's for mountain gravel, but I have a 42T chain ring to swap out (with a separate dedicated chain) for flatland riding.
If you want low gears, like for touring or bikepacking, I think you need a minimum of 12 more teeth on your largest cassette cog than your smallest front chain ring, whether you go 1x or 2x.
Sunshine
Liked 7,491 Times
Randomhead
Liked 3,698 Times
I have come to the conclusion that there are two kinds of people -- those that know they need lower gears and people that don't know they need lower gears.
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
This for sure- entry hybrids with wide range 1x would be great.
Sunshine
Liked 7,491 Times
Heck, in addition to hybrids, entry level Mountain Bikes would REALLY benefit from 1x! My son as a triple on his (as many of them do), and pretty much the only thing that slows down our rides together is his chain getting sucked! Big fan of 1x here - and I ride my gravel bike around 70% mountain singletrack so it works well for me.
microshift has a 9sp and 10sp 1x drivetrain thats affordable for converting older or more entry level mtbs to 1x. Its what I used for the most recent switch.
1x9 is so much easier for an 8 or 9yo to conceptualize than 3x7, which is what's on 90% of kids mtbs.
I cant see changing my gravel bike to 1x. Maybe if companies stop investing in 2x I will feel like there is no other option, but hopefully thats long in the future.
I dunno, these manufacturers seem to know what they're doing. My mt bikes are 32/10-50 (XC), 30/10-50 (enduro) and 28/10-42 (fat bike). I was skeptical of GRX 2x but the gearing is pretty perfect. I ride 90% of the time in the big ring, on the flats using 15-19 teeth (middle of the cogs), on many hills using 25-30 and down the hills using 11-13. On the steep ups, having the 31 chain ring is great and I haven't run across a gravel hill I can't grind up in 31/34. So, my experience is that, for gravel, Shimano figured it out.
Likes For xseal:
Liked 415 Times
I was going through the motions when I first built my gravel bike. I decided to go with a 1x11 setup and got the Easton EC90SL cranks that way I can easily swap chainrings. ... In terms of racing, I plan on racing my gravel bike next season hopefully if COVID permits. I will put the 42T ring on it for that.
(and yeah, if you are not racing, doing gravel climbs, and road sprints on the same bike - 1x is great for many people).
Likes For chas58:
