Best RIDING tire in 700x32? (with some puncture resistance)
I have 700x28 Pasela TG's and have not had a flat in about 500 miles. But they feel numb and I'm searching for more comfort. Most searches on the forum deal with puncture resistance and not feel.
My commute is only 4 miles each way on pavement and I don't think its too hazardous (probably because I have yet to experience a flat) - occasional glass, post-rain gravel, etc.
I get that the Marathon Plus and Armadillos are probably more puncture resistant, but I'm looking for something more responsive with feel.
I'm thinking:
Bontrager Racelite Hardcase
Continental Contacts
Pasela TG's in 700x32 (I'm not sure whether my current distaste for them is because of the size or the tire)
Am I off base on this list? Is there something else I should look into?
I'm thinking:
Pro Paper Plane Pilot
What is this "feel" you're referring to? Responsiveness? road feel? what?
I think the thicker the tire is the more vague and numb feel it will be. You can always try tubeless.
My current tires just feel hard. I'm looking to soak up more of the bumps and vibration from grated pavement. I don't ride aggressive, but get going pretty fast at times.
-I've never ridden tubeless (and don't know much about it), but based on your "smile," I'll have to take a pass
Map maker
Bikes: Ventana El Ciclon, Walt Works 29er, Specialized Enduro (fixed up for my son).
I like the Michelin City Road Tire they have a strip of something in them to help puncture resistance AND they have a nice reflective sidewall stripe.
here is the 700 x 47 for $9.99
https://www.nashbar.com/bikes/Product...1_10000_200524
I just picked uped the 700 x 40 for $3.99
here is the 700 x 32 for regular price - which is cheap mind you just not on sale
https://www.nashbar.com/bikes//Produc...0052_163841_-1___
smooth riding, fast rolling and great grip IMHO
universal cycles has them for $21.00
https://www.universalcycles.com/shopp...8&category=592
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
I'm thinking:
I'm thinking:
The Pasela TG 32mm folding bead is only 330g. At a 95psi top rating, they're plenty plush while still maintaining a strong feel to the sidewall, even on a narrower (14mm i.d.) rim like an Open Pro. Put them on a wide (17mm i.d.) rim like a VO Diagonale or Sun CR18 and you can drop the pressure by 5 - 7 psi to soak up more road chatter without suffering from any additional sidewall deformation.
If you want the best feeling tire you can get, then pony up the $$ for a pair of Grand Bois Cypres 30mm. Without switching to handmade silk tubulars, you won't find a smoother riding tire. On the down side, the Cypres is a bit fragile, and if you have to dodge a lot of stuff I won't suggest them. On a 4 mile commute, unless you're riding through some horrible downtown glass strewn wastelands, you might get away with using them.
A better option, although not as plush as the GB Cypres is the Jack Brown Blue Label. A little wider at 33mm, but it has a stronger casing due to the kevlar puncture-resistant belt. The JB Green Label is the same tire w/o the belting.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
Cat 4 roadkill
I'm surprised nobody has asked this already: have you tried fiddling with your tire pressure? I don't know much about commute-specific tires, but I do know that there's a huge difference between a race tire at 120 psi and a race tire at 100 psi.
Bikes: Surly LHT, 94 Cannondale track bike, 80's Cannondale track bike, 60's Raleigh 5 speed, 1888 Eldridge wood wheel track bike and my old 76 DG BMX from when I was a kid.
I have had the best luck with cheep michelins that I got just to get by. I learned later that the more you pay for a tire the more it was intended for racing and they tend to get thinner. I live in Detroit and ride every day-all year long and cant kill my michelin city tires that cost $20 or so ea.
Quoted: 5 Post(s)
Liked 7 Times
The Pasela TGs are fiends for rattling pebbles up into your fenders. Noisy and annoying, but not a massive drawback to the design.
- Mandi M.
- Mandi M.
Freewheelin' Fred
Bikes: Surly Cross Check
I love my Marathon Supremes. Good flat protection and a very responsive ride. Marathon Racers are pretty nice too, but they only come in 30 or 35.
aka Phil Jungels
Nope, they also come in 32s..... the Supremes, that is.
Quoted: 137 Post(s)
Liked 81 Times
just get fatter Paselas, they're very nice riding tires IMHO. Marathon Racers are nice riding tires but pricier and I don't think as puncture resistant. I've got 35mm Paselas. If I pump the front tire up to max pressure it's hard, if I pump it up to a sufficient pressure it's like a barcolounger. A fatter Pasela and closer attention to appropriate pressure is all you need.
As mentioned above what pressures are you using on the 28mm paselas and how heavy are you?
Flying Under the Radar
Bikes: 10' SuperiorLite SL Club | 06' Giant FCR3 | 2010 GT Avalanche 3.0 Disc
For straight road riding. Bontrager Race Lite Hardcase.
For touring, commuting, road, light path riding - Specialized Infinity with armadillo or flackjack. Specialized Nimbus Elite armadillo.
I have not suffered a flat or even a leak in any of the three yet.
Freewheelin' Fred
Yeah, me too. I have 700x32 supremes on one commuter and 700x35 racers on another. Very comfortable tires and no flats in over 5,000 miles (both bikes combined).
+1 on the Supremes, very plush, pretty quick, grippy, very secure feel. Had one puncture so far from a curved piece of valve spring (?) that slipped in over the belt. Was running them at 85 psi, now typically run at 55 front 65 rear. Ride very nice like that, and still not what I would call slow. Bit pricey though. Mine are 700x40, causing problems getting fenders to fit.
aka Phil Jungels
Mr. cost-benefit analysis
Bikes: Surly Crosscheck Single Speed, Novara 9 speed commuter/runabout
I recently bought a Swobo Baxter for commuting. It came wearing Vittoria Ranonneur tires in 700x32. https://www.biketiresdirect.com/pvirn...ur_tire/pp.htm They have a very smooth ride, good grip, and probably corner harder than I'll ever have the nerve to on the Baxter. I haven't had a flat yet - which is good, because the rear has a Shimano internally geared hub. The Randonneurs have a max pressure of only 85 lbs psi, so they're not going to win any races. Then again, that probably has a lot to do with the smooth ride. They're also available in 28 and 35 mm width. One thing you want to avoid is the temptation to over inflate them. Last year I was pumping a set up to 95 psi and the side walls began to crack. So this time around I am keeping more careful attention to inflation.
All the best. DanO
All the best. DanO
Have you guys used Specialized all condition proII, I just put them on my bike, after one of the contis sidewall blew up on the first ride....bad luck i guess... The specialized all condition proII look pretty cool, and reviews are very favorable, fast responsive and safe....
Quoted: 539 Post(s)
Liked 44 Times
You know, I JUST read a blog entry yesterday from someone who compared the Bontrager Racelite Hardcase to his new Schwalbe Supreme's (sorry, unfortunately I don't have the link right now).
He said the he thought the Bontragers rolled a little faster but not by that much, but the Supreme's were a WAY cushier ride.
I'll try to remember to post a link later. I know the Supreme's have a fair amount of flat resistance built in.
Quoted: 5 Post(s)
Liked 7 Times
However, there is an enormous difference in how I feel after 300 - 400k if I use 28mm Conti Gatorskins, 27mm Challenge Paris-Roubaix or 32mm Panaracer Pasela TGs. Now, the OP is asking about a 4 mile commute. Granted, I think you can ride a 4 mile commute on airless crapola tires and still be fine, but he posed a valid question about a difference in tires that many people don't notice with the exception of super-mega-flat-proof tires. The construction, tread compound, flat proofing reinforcement, casing suppleness and tire width all contribute to the feel of a tire. In addition, the same tire will feel different depending on the rim width.
Personally, the difference on a short commuting distance isn't great enough to justify the cost of a high quality super supple tire with a thin road tread (Challenge, Grand Bois, Jack Brown, etc.) It's sort of like the difference between Performance Ultra and Assos FI.Mille bibs; over 10 miles you're probably not going to notice a big difference.
- Mandi M.
- Mandi M.
If you tour and or commute, the difference in tires is HUGE because you see all of the elements all of the time. From Road obstacles to weather, and for these things Choosing the right tire or a good one anyways will help you avoid getting flats, getting hit, falling, repairing tires more often.
Quoted: 7348 Post(s)
Liked 2,465 Times
I have the non-tourguard version of the Pasela, and I adore them. The ride is amazing. I hear the tourguards do a good job at flat protection. We don't have much glass here, so I don't need them.
perpetually frazzled
Bikes: 1977 Bridgestone Kabuki Super Speed; 1979 Raleigh Professional; 1983 Raleigh Rapide mixte; 1974 Peugeot UO-8; 1993 Univega Activa Trail; 1972 Raleigh Sports; 1967 Phillips; 1981 Schwinn World Tourist; 1976 Schwinn LeTour mixte; 1964 Western Flyer
Quoted: 5 Post(s)
Liked 6 Times
Not exactly what you're looking for, but running cheap tires, I just switched the 27X32 Kendas to 27X28 Cheng Shins on my "fast" bike (an '89 Fuji Palisade), and find that dropping the size hasn't increased my speed at all, but has made the bike a whole lot harsher.
Honestly, any 32c tire you get will be more comfy than a 28. Just my experience.
That said, if you have the cash, I'd spring for Grand Bois 32c tires. I'd love to get a set, but at $116 a pair, it's going to be a while in coming, I'm afraid.
