Front derailleur
Front derailleur
Old 04-10-19, 05:00 PM
Rgbraun1
Front derailleur
New here and new to road biking. Bought a used road bike in very good shape but the “nub” that catches the spring is broken off. What can i replace it with, the derailuer that is. The one on there now is a (gonna write everything I see) Shimano Tiagra 31.8 FD 4408 9 speed.
Thabks for your help
Rgbraun1 is offline
Old 04-10-19, 05:32 PM
rhenning
Quoted: 331 Post(s)
Liked 57 Times in 39 Posts
Take all your info and shop a bike shop or E-Bay with it. That way you know it will work. Roger
rhenning is online now
Old 04-10-19, 06:33 PM
KCT1986
Quoted: 40 Post(s)
Liked 11 Times in 11 Posts
Welcome to the forum!
Few questions for you to clear-up and hopefully others will be along to help you.
Is the # 4408 or 4403?
Overall does the bike seem to have mostly Tiagra parts? Shifters, crankset, rear derailleur? So we can judge if this bike is mostly a complete OEM build.
Triple crankset?
Nine cogs in the rear?
KCT1986 is offline
Old 04-10-19, 07:45 PM
Rgbraun1
More info
it is 4403. Sure looked like a 4408. Rear deraileur is a 105 and the shifters are Tiagera Flight Deck 9 speed.
Rgbraun1 is offline
Old 04-10-19, 08:13 PM
HillRider
Quoted: 1499 Post(s)
Liked 317 Times in 251 Posts
It seems you have a Tiagra 9-speed triple front derailleur with a 31.8 mm (1-1/4") diameter clamp. They aren't that expensive if you find a direct replacement but a 1-1/4" clamp isn't all that common. You may do better to find a 1-1/4" diameter accessory clamp and use a "braze-on" front derailleur. You could use a 9-speed triple front derailleur from the 105 group too and it would be a FD-5503.
HillRider is offline
Old 04-10-19, 09:37 PM
KCT1986
Quoted: 40 Post(s)
The next series Tiagra, FD-4503 for triple was also still 9 speed and should be fine.
Another upgrade would be FD-6503, Ultegra level.
Newer 105 & Ultegra (x600) series are 10 speed. Since I don't use a triple crankset, not sure how a 10 speed FD would work on a 9 speed. Maybe someone who uses this combo will share their experiences.
MTB FD have different chain cage shape for optimum shifting for smaller chainrings (42t-46t) and not road rings (50t-53t).
KCT1986 is offline
Old 04-10-19, 09:55 PM
Rgbraun1
I can’t seemnto find any of the suggested replacements new. Several used, beat up ones. Also, thanks for the great info. Learning a lot.
Rgbraun1 is offline
Old 04-11-19, 08:46 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '71 Jeunet 640, '79 Peugeot PXN10LE, '87 Centurion Ironman Expert, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022
Quoted: 1049 Post(s)
Liked 756 Times in 424 Posts
I see a new old stock FD-5504 that would be a suitable replacement.
Phil_gretz is offline
cjones109
Bicycle Mechanics
5
09-23-18 11:40 PM
frogman
Bicycle Mechanics
10
09-09-18 04:28 PM
Rkman
Road Cycling
15
05-06-18 12:41 AM
steinrr
Bicycle Mechanics
11
12-07-11 07:47 PM
