Just exploded three latex tubes
Update: changed the rim tape to Scotch 8898 and no more exploding latex tubes.
Installed a set of michelin air comp latex tubes a week ago on a bike with no spoke holes (campagnolo zonda wheelset) and had no issue. Put some chalk powder on them, half inflated, seated the tire and pumped up to 100psi. Went for a ride no problem.
Just tried to install a pair of vittoria latex tubes on a different carbon rim with hard plastic rim tape. Tire was loose enough that I didn't need tire levers to install. Same procedure as above. Between 60 and 80 psi each time BANG like a gunshot. Nearly deafened my toddlers who wanted nothing more than to help dad pump up his bike tires.
Inspected the hole in the tube...two large holes in the tube. Felt around the rim tape and new tires as of 20km ago to find sharp bits. Nothing. Tried the next tube. Same result. Switched to a Michelin latex tube thinking those Italians don't know what they are doing and bang! Three tubes, a pile of money and some ringing ears. One hole, two holes and three holes in the tubes all in different spots on the rim.
Threw the old butyl tube on there and it pumped up without complaint just as it had been before trying to change the tube. I have changed hundreds of tubes in my lifetime and other than a few tire lever induced holes I have never blown up three tubes in a row before.
What am I doing wrong? Maybe incompatible rim tape? Seems like the holes are on the interior and sides of the tube.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
What about different spots on the tire? Are you moving the tire relative to the rim when the tubes are removed or does the tire stay on the rim when you swap the tube?
Switch tires front to rear and repeat. Does the problem follow the rim or the tire?
Different rim tape on front vs rear? Try changing rim tape?
Quoted: 1438 Post(s)
Liked 1,092 Times
IME tubes only explode with a loud report when they are not constrained by the tire, like when they get trapped under the rim. Perhaps your tire-changing technique needs refinement.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
To me, one clue might be that you didn't need tire irons to put the tire on. Correct tire size? New-to-you brand or model of tire? Could the tire have not seated?
Quoted: 659 Post(s)
Liked 7 Times
Agreed. Somehow a portion of the tube got outside the tire where it then instantly expanded and blew up. I'd suspect that either part of the tube was pinched between the tire bead and the rim and worked its way out when you pumped or part of the tire bead wasn't seated properly in the rim and momentarily lifted up allowing part of the tube to escape. In the latter case the tire bead frequently pops back into the rim once the tube has exploded. The fact that you found the tire to be a relatively loose fit on this rim makes this second possibility more likely.
Quoted: 4205 Post(s)
Liked 3,864 Times
I helped a club rider and customer last weekend wit his 5th flat of the weekend... He was really frustrated in not finding the causes. He and others looked many times for a bit of something in the tire that wasn't found before. Like many non experienced he (and the others) didn't fully understand all that can happen to a tire/tube/rimstrip/rim system to fully understand what was really going on.
By looking at the last flat tube I could see that the hole was on the rim side of the tube. First lesson is then to find the hole in the tube and how it interfaces with the tire/rim. The tube had slight bulges/indications where the spoke access holes in the rim were and the hole lined up with these. Then we looked at the rim strip and found it to be snaking side to side within the rim's base. having off from center spokes meant these access holes were also along one side of the rim and that the rim strip wasn't fully covering these rim spoke holes. The tube would chafe against the edge of the spoke access holes that were slightly not fully covered and abrade, causing the flats.
So what he learned was to seek the location of the hole within the tubes arrangement WRT the rim and tire. Then look at that aspect for a failure and the relative reason for a failure t that location. This is not rocket science but does need a certain amount of logic and systematic thinking. Of course when you've seen thousands of flats over decades this is second nature. When I teach flat repairing it is this logic I try to get across.
Now having said all that when one uses the most fragile stuff this all becomes even more vital. There's a reason why latex tubes are not common place. The marketing of their ability to lesson weight and soften the ride is small compared to the likelihood of frustrating flats. Andy
AndrewRStewart
AndrewRStewart
aire díthrub
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times
but what are the chances that he was somewhat careless, with three latex tubes and suddenly, not so careless with the original butyl tube that he said pumped up fine? Just three spots of bad luck in a row? The basic numbers here don’t work in favour of bad installation practices. I don’t use latex tubes for a variety of reasons, but I know a lot of people who have had similar experiences as the OP. I don’t know what went wrong here, but my gut instinct based on what we do know, says it wasn’t installer error.
Right pink - toward rim, 12 o'clock position
green toward tire bead 9 o'clock position
left pink toward tire. 3 o'clock position.
Right pink and green both have stippling of some kind next to the holes. Left pink seems clean.
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
Only going on the photo you provided, evidence would suggest two faulty tubes and maybe one that was punctured by the rim? Quite a lot of possible variables though.
Mechanic/Tourist
I see nothing that definitively shows tube faults. To me, the one on the right is typical of what happens when the tire bead lifts off the rim - a mounting problem. The multiple dimples and holes in the middle one are quite odd, but I see some of the same effect on the right tube. Could it be caused by rim protector with sharp edges? The left looks to me like the result of the tube being caught under the bead, another mounting problem. It is odd. When you say "half inflated" I assume you mean the tire. It's not clear if you inflated the tubes enough to give them shape before installation - especially critical with latex.
I see nothing that definitively shows tube faults. To me, the one on the right is typical of what happens when the tire bead lifts off the rim - a mounting problem. The multiple dimples and holes in the middle one are quite odd, but I see some of the same effect on the right tube. Could it be caused by rim protector with sharp edges? The left looks to me like the result of the tube being caught under the bead, another mounting problem. It is odd. When you say "half inflated" it's no clear if you inflated the tubes enough to give them shape before installation - especially critical with latex.
The tire itself seats fine with the butyl tube and I have changed it out a couple times now. Just the latex...
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I inflate the tube to give it some shape when I put it in the tire and to mount the first bead and center the tube in the rim. But after the second bead is most of the way on, I almost always need to completely deflate the tube to finish mounting, certainly on a road bike. Then, if I'm not familiar with tire and rim, I inflate a few pumps, and visually check around both beads, squeezing the bead together, to make sure the tube is not pinched in there. Then I will inflate slowly and check that the bead is seating properly and evenly. Disconnect the pump and spin the wheel in your hands, looking for high and low spots on the bead.
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
seems to me a lot of folks are overlooking the fact that he stated that he was able to mount the tire and inflate a butyl tube without incident. While this doesn’t rule anything out, it does at least point to the high probability that his ability to properly install a tube and seat a tire is adequate.
Tire and wheel in question with inflated butyl tube.
Are some rim strips incompatible with latex tubes?
Quoted: 1163 Post(s)
Liked 442 Times
BTW - you are not the 1st person who burned through multiple latex tubes before getting on to not blow out upon inflation. Lots of good tips here should help. Could you name the brand of plastic rim tape and or take a picture showing the rim tape on the rim?
Liked 442 Times
Liked 341 Times
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
what rim tape are you using? A fabric rim tape like velox or a polyurethane tape (I use panaracer poly-lite) would be a good choice. Thicker tapes could create a bead seating issue though, depending on your rim/tire combo
It is a thicker piece of blue plastic rim tape. I will get some scotch 8898 and see if that helps.
I sacrificed one of the tubes to make some patches. They seem to be holding up ok so far.
Quoted: 1975 Post(s)
Liked 232 Times
Those look like tubes that were pinched between the rim and the bead. Even if the tire and tube go on smoothly the tube can be pinched when inflating, especially if the tire fits on loosely. It gets trapped at the bottom between the bead and the rim. With latex tubes this is a common failure. I always inflate to ~30psi and run a lever along the perimeter of the bead to check and make sure the tube is fully inside of the tire. Not an issue with the thicker butyl tubes as they don't get trapped in the same way
