Metal bike tires
Metal bike tires
"It’s incredible technology that will soon be available in the coming years for a vehicle that will probably never leave Earth’s atmosphere: your bike. A startup called The Smart Tire Company has announced that it’s creating a metal bicycle tire using NASA’s Nitinol alloy that never needs to be inflated, will never spring a leak, and will probably survive a lot longer than the bike itself."
https://gizmodo.com/nasas-nearly-ind...igh-1846488605
I had to really restrain myself on the title, think of the possibilities.
Quoted: 3370 Post(s)
Liked 5,491 Times
It's hard to imagine metal having a good grip on asphalt while cornering.
Even worse when the road is wet.
You paint on a rubber like coating for grip. Why not do that with something other than metal that would provide a better ride?
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
Oh lord, it’s the tweel again
Genesis 49:16-17
Genesis 49:16-17
Disco Infiltrator
Liked 2,102 Times
I'm really trying to be open minded but there are some howlers.
"Over time the tread will wear out and need to be reapplied, but that maintenance is expected to be a lot cheaper than having to regularly replace a set of tires." Shipping alone kills that. How many thousand miles does the "coating" last?
"We have identified several R&D goals related to dropping our material costs by up to 90%. In addition, there is intense ongoing research at the laboratory stage involving comparable materials that are ~80% cheaper than NiTinol." Spoiler alert - it's steel
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Quoted: 2952 Post(s)
Liked 3,106 Times
Should Be More Popular
Quoted: 22573 Post(s)
Liked 8,919 Times
Quoted: 6177 Post(s)
Liked 4,795 Times
When costs vs performance vs durability graphs cross at the proper places then we'll take a look.
Likes For HTupolev:
Disco Infiltrator
Liked 2,102 Times
I don't want to discount that these are some serious people doing real engineering. Nitinol isn't new - it's the same stuff used for glasses frames. Read the list of applications at that link, it's good stuff. The idea of making a tire for the consumer market is the innovation. In terms of price they are making some visible compromises. Their tire is made only of wire that appears to be laid on the bias ply and only bent a little like a mesh - their buggy wheels have much more complex weave of much more shaped wires. They are working with real industry, not using Kickstarter to "innovate" a couple of microchips together in a little block of plastic.
Genesis 49:16-17
Genesis 49:16-17
Bikes: Shmikes
Quoted: 10148 Post(s)
Liked 5,841 Times
Heavy and expensive: What's not to like?
Quoted: 20808 Post(s)
Liked 9,450 Times
They’re still not here, though, not even for bikes, which is just about the least demanding application for the technology.
Quoted: 590 Post(s)
Liked 445 Times
A solution looking for a problem.
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
Yeah nah, count me out
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Quoted: 1074 Post(s)
Liked 295 Times
Ignoring Covid, I’m an all-year commuter in a place where winter really means something. Due to medical reasons, I really need to avoid flats during winter.
I’d be willing to consider a studded version.
Summer use, meh.
Summer use, meh.
Quoted: 3241 Post(s)
Liked 2,512 Times
So they would be like a tattoo? The same looking tire on your bike forever? Wonderful. You might have some Regerts later on after installing them.
It makes me think of this:
Likes For seypat:
Half way there
Quoted: 985 Post(s)
Liked 879 Times
From the article:
Pretty much says it all.
For cyclists who are happy to spend tens of thousands of dollars on their bikes, ...
