Good summer jerseys
Good summer jerseys
I am looking for some jerseys for this Summer and found the high-end Summer jersey brands thread, but I am looking for some good cheaper ones .
I normally prefer solid light colors jerseys and had a pair of Spotti ones, but there are very few colors and none on my size on Amazon.
Then, I found the Bpbtti brand for 15 bucks and got one to try it out.
Any good jersey on cheaper side you recommend?
For my shorts, I am very happy with the Santic ones.
Quoted: 2432 Post(s)
Liked 641 Times
The stuff this company makes have pretty good reviews. If you go on their instagram they have better pictures than on the website.
https://www.theblackbibs.com/
I've been wearing these retro jerseys from an Austrialian seller on Ebay, and pretty happy with them! I have worn one of them for 2 seasons now, and the quality and fabric hold up well.
https://www.ebay.com/sch/cycling-ret...1&_ipg=&_from=
Honestly I cannot see myself spending $100+ on a jersey when the cheaper ones work well enough.
On more "mainstream products", I believe Louis Garneau has a pretty good price / performance ratio. They make quality stuff for reasonable prices.
Do you wear black jerseys in the summer?
Hello all,
I am in the market for a new cycling jersey for the summer, and I was wondering:
Black looks cool, but it does absorb more heat from the sun. I see a lot of brands make summer jerseys in dark colors, which makes me wonder:
Would you wear a black jersey in the summer?
I see lots of people wear dark jerseys in the summer. Do you like them? Why?
Cheers!
Cheers!
Quoted: 20810 Post(s)
Liked 9,456 Times
Hello all,
Cheers!
Cheers!
Quoted: 84 Post(s)
Liked 5 Times
Unless you need the back pockets (which I think is totally unnecessary for 1-2 hour workout rides) Dri-fit tight fitting combine workout tops from Nike, UA, Reebok, etc are 10-15$ all day every day. I've been asked several times "Where did you get that jersey?" and had to point out the logo and tell them it was a combine workout top.
Liked 641 Times
Hello all,
Cheers!
Cheers!
Bikes: 2011 Cannondale CAAD10-4
Quoted: 12 Post(s)
The black robes worn by Bedouin differ from a bike jersey in one important way: they're thick. That thickness insulates the wearer from the outer layer of the robes, which heat up because black absorbs heat (not just infrared, but also radiation in the visible spectrum--that's why it's black). This works if you're relatively sedentary, in 120°F heat. But if you're active, then the insulation will prevent your body from cooling via sweating, by preventing the sweat from evaporating, which is an endothermic reaction. (NB: if you touch a white object in full sun, you'll note that it's much cooler than a black object of similar material, which is due to the fact that white objects reflect both infrared and visible-wave radiation, which is why it's white.)
Having said that, a black jersey should feel just as cool as a white jersey in the same riding conditions, assuming that you're sweating and that the two jerseys are adequately facilitating the evaporation of said sweat. But just standing around, looking cool after a ride? Black will heat you up much more quickly.
Liked 641 Times
It's entirely true. Of all the research and studies done on the subject, not a single one found that you're hotter wearing black vs white. As a matter of fact, it was found that if you wear black, you cool down faster after getting out of the heat.
Quoted: 12 Post(s)
Compelling citations. I'm sure that those studies explain why every solar heating device is black (increased absorption of thermal radiation results in increased conduction to whatever is on the other side), and why white (and similar) are such a favored colors for dwellings in sunny desert environments (increased reflection of thermal radiation results in less absorbed heat to be radiated or conducted inward), or why a well-insulated ice chest stays so cool for so long (increased insulation results in slower conduction of absorbed heat into the interior). I suppose they'll also explain how the visible color of "white" is not due to complete rejection of all visible-wavelength electromagnetic radiation, and how "black" is not due to complete absorption of same. Probably also how the laws of conservation of mass and energy don't apply in this situation, and how faster cooling under black clothing certainly isn't due to the increased temperature gradient that can result from... increased heat absorption.
In the context of cycling:
- Black jersey, standing around on a hot, sunny day: The jersey, by virtue of it's black color, will absorb thermal radiation from the sun. Part of this will be radiated back off the jersey; this is why it feels warm to the touch compared to a white jersey. Part of that absorbed radiation, however, will be thermally conducted through to the wearer. This will cause the wearer's body temperature to rise, and may result in sweating. You will feel hot.
- Black jersey, riding on a hot, sunny day: Same absorption of thermal radiation as before, with subsequent re-radiation and transfer to the wearer. However, as the wearer sweats, the jersey will (if it's well-designed, at least), absorb that sweat and, while still in contact with the body, see it evaporated. That's an endothermic reaction that causes your skin to cool. The same thing can happen with a loose garment, assuming sufficient transfer of air to the outside (but who likes a flappy jersey?).
- White jersey, standing around: Unlike black, white rejects all electromagnetic radiation in the visible spectrum, reflecting it back into the atmosphere. As a result, it heats up much less than black does, not having any retained energy to radiate back into the atmosphere. So now, our hypothetical rider is cooler, because his jersey has less absorbed energy that can be conducted through to the skin.
- White jersey, riding: Our rider will probably stop sweating sooner in the white jersey, because there was less retained heat within the jersey itself. However, evaporative cooling (in a dry climate, at least) is so efficient as to make the effective difference with the black jersey marginal, at best. As relative humidity increases, however, evaporative cooling becomes less effective, and the effect of riding becomes more like the effect of standing still.
Kit doesn't match
I recall @Lazyass bringing up the Bedouin example previously, which I thought was interesting, so I did some reading about it. As you might guess, the reasons why they wear black is complicated by cultural norms and other non-environmental factors. That said, it seems that because they wear their garments loosely, color has little effect on the amount of heat they gain.
I thought this provided a pretty good summary of the issue: Clothing colour and heat stress | The Thermal Environment
Liked 641 Times
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Black absorbs and radiates heat faster. It is why rims on real race cars are flat black.
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
Quoted: 647 Post(s)
Liked 136 Times
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
*I did come across these, but can't say I'd wear them
like we used to say
Voler jerseys are fairly inexpensive in their basic style, and made in USA.
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 29 Times
Hmmm, Team Sky seemed to do pretty well wearing black jerseys.
However, they've gone to white jerseys this year. Froome wins Giro d'Italia.
I never had much luck with the cheap jerseys. Even less with cheap shorts. But comfort is relative so
The thread title was "Good summer jerseys" so I'll recommend Castelli inferno or their Free AR.
Liked 9,456 Times
I've come across black ones here and there, but I would bet that the biggest reason is marketing/perception. Most of these things are going to hang on a peg or be viewed online and, for the most part, they have to sell themselves. If you're the producer of a product, why fight an uphill battle relying primarily on, let's face it, frequently under-trained LBS sales people? From the LBS perspective, why give up peg space to low-ticket items that, more often than not, would require customer hand-holding when a lower maintenance option exists?
Non omnino gravis
I'll throw a vote out for the Canari Optic Nova. The fit is... decent. A little long in the front. But they are thin (Canari claims a 30+ UPF, but I've gotten a bib tan right through the jersey) without being see-through, and you can buy yourself a whole drawer full of them-- because they run $15-25 apiece on Amazon, depending on the color and size. I have three of them, and they all get worn regularly through the summer. If you like horridly bright colors, you're in luck there too. The Killer Yellow and Glow Stick Green are an assault on the eyes. And hey-- it's a $20 jersey. Most of my T-shirts cost more. If they lasted through one summer I'd call it a bargain.
I picked up a Sugoi Climber's Jersey on eBay for 15 bucks, and it is nearly as cool as not wearing a shirt. But it is also about as opaque as not wearing a shirt. My chest looks like when a bearded bank robber stretches a nylon over his head. No one should have to see that.
I have only a few black jerseys (I think.. 3?) but they get worn year-round. I don't notice being any hotter in them than in any other color-- I have a blue Castelli jersey that is one of the warmer short-sleeve jerseys I own. It basically only comes out in spring and fall. As I've previously said in similar threads, the construction of the jersey is far more important than the color. A jersey made to be cool will be cool even if it's black. I wish that Sugoi was black.
- Soli Deo Gloria -
Liked 736 Times
Here are some leftover 2014 garments on clearance at Backcountry.com
https://www.backcountry.com/rc/2014-...ce&page=1&nf=1
Jarrett2
12
08-06-15 07:08 PM
fatbiker
14
07-12-12 05:32 PM
prendrefeu
Road Cycling
19
06-19-11 06:10 AM
