Re-breaking-in a used leather saddle
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 27 Times
I have my grandfather's 1961 B17 Competition (predecessor to the Professional), and it's very much in rideable condition. However, after having the alignment checked out on my bike's frame, and a couple tweaks made, I found that I seem to be putting most of my weight onto a bit of a high spot with my left sit bone, and I'm wondering if there's a good way to fix this.
One thought I had was to move that saddle to a bike that gets used more frequently, but on shorter rides, and see if that helps - the bike it's on now is the "impractical fast bike", which sees fairly infrequent use.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
Check to make sure a rail is not bent so as to raise one side. Or both rails unequally.
I find on some of my worn leather saddles broken in by others, that it takes a long ride to suit me. In other words, the first 10 miles of every ride feels not quite right, but by mile 11 it's all good.
edit: I've had others that were just too hard, even when the appearance would lead one to believe otherwise.
Quoted: 981 Post(s)
Liked 1,844 Times
In case you haven't done so already, oil the saddle from the inside with neatsfoot or some other compound suitable for leather. Old leather should not just be worn in by force - there are almost certainly brittle fibers inside that will simply break rather than soften under pressure.
Quoted: 1639 Post(s)
Liked 829 Times
Once dry rot sets in, there's really no way to reverse it, and althiugh you might be able to massage it back to some semblance if suppleness, it might be just a matter if a few miles before it starts tearing apart like damp cardboard at the rivets or nose....
I also suspect that leather on saddles have a finite life span, being organic and vulerable to the elements....
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
Possibly it's the leather having been stretched on the left side, but it could be that the cantle plate on the left side is bent too far downward (rolled towards the front), meaning that the rear of the rail needs bending back to move the cantle rearward, which would stretch the leather back out on the left side. I'd take the tension completely out, soften the leather, then work on the left rail.
Quoted: 248 Post(s)
Liked 27 Times
It's worth noting that I've got probably 200ish miles on this saddle. Oddly, this is the first time I've found it uncomfortable in this way, and all I can think of is that it has to do with having had the frame and fork alignment worked on.
Here's what it looked like when I first got my hands on it a couple summers ago, after sitting in a box in my grandparents' basement for who knows how long:
Quoted: 981 Post(s)
Liked 1,844 Times
Oil and waxing compounds can do a marvelous job on old leather, and should be considered mandatory to use especially on pieces that undergo stress like a bicycle saddle. I've got some rather rough looking old saddles and have been riding them for quite a while after taking the time to renovate the leather.
-Gregory
Bikes: Too many, but sometimes not enough.
Quoted: 225 Post(s)
Liked 18 Times
That contrasts with plenty of Brooks Pros that I've seen give 30-40 years of hard service. I suspect that if you refresh the oils with Proofhide or other dressings once a year or so, you can get a long life from the leather. Leave it somewhere very dry for decades, not so much.
Quoted: 981 Post(s)
Liked 1,844 Times
I find old Brooks leather to be a crapshoot. I've bought probably 5-6 old (1970s) Brooks Pros from eBay, all in visually "good" condition. All were quite hard and obviously dry. After one or two treatments with leather dressing, all appeared to be good to go, with some flexibility restored. In use, some went thousands of miles with only minor surface cracking, while others developed significant cracking and splits in only hundreds of miles. I suspect that storage without some sort of periodic dressing damaged the fibers in ways that are hard to discern visually.
-Gregory
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I am reluctant to mention this, because I don't know whether it is a good idea for such an old saddle... but water will temporarily soften a saddle. If you know what part of your saddle is bothering you, you could make it wet before a ride. Start making it wet a couple hours earlier, and get the area in question pretty wet. Don't use so much water that you soak anything out of the saddle (if you soak it in water, you will turn the water brown; I don't know what's coming out of the leather, but it should stay in the leather). Let it sit so the water permeates all the fibers as well as possible. You may want to add another spoonful of water after a little while. Keep a plastic bag over it so it can't dry out.
When the leather is wet, take it for a short ride, maybe a mile; then look at what you've done. If you don't see any change, ride another mile. Repeat as necessary. If you've made a small dent in the area that was bothering you, that's probably enough; let the saddle dry. The dent will remain. When the leather dries again, it will be as hard as before, and possibly a little harder, but (with luck) a little more comfortable.
I would have no hesitation doing this to a new saddle. With a 50+ year old saddle, I'd be more cautious. That probably wouldn't stop me.
www.rhmsaddles.com.
www.rhmsaddles.com.
multimodal commuter
Liked 574 Times
Quoted: 248 Post(s)
Liked 27 Times
What are your guys' thoughts on swapping saddles with another bike that gets used more frequently for short commutes? (About a mile and a half each way)
multimodal commuter
Liked 574 Times
But about your B17 Competition, as you say, it's the predecessor of the Professional and it's now something you don't see every day. I would consider it something of an antique, an item that may have more collector value than utilitarian value. It might be worth more to someone who's restoring a 1960 bike (that won't get ridden much) than to you. It may actually be rather fragile; if so, you won't know it until it tears in half.
www.rhmsaddles.com.
www.rhmsaddles.com.
... Don't use so much water that you soak anything out of the saddle (if you soak it in water, you will turn the water brown; I don't know what's coming out of the leather, but it should stay in the leather).
Tanning (leather)
Vegetable tanning uses tannins (a class of polyphenol astringent chemicals), which occur naturally in the bark and leaves of many plants. Tannins bind to the collagen proteins in the hide and coat them, causing them to become less water-soluble and more resistant to bacterial attack. The process also causes the hide to become more flexible. The primary barks processed in bark mills and used in modern times are chestnut, oak, redoul, tanoak, hemlock, quebracho, mangrove, wattle (acacia; see catechol), and myrobalans from Terminalia spp., such as Terminalia chebula. Hides are stretched on frames and immersed for several weeks in vats of increasing concentrations of tannin. Vegetable-tanned hide is not very flexible and is used for luggage, furniture, footwear, belts, and other clothing accessories.
Quoted: 981 Post(s)
Liked 1,844 Times
Almost certainly so, unless if the leather is also stained or old - it could be dye or dirt as well in that case.
It's important not to get vegetable tanned leather wet very often (or mostly any other traditionally-tanned leather) precisely because it will slowly dissipate the physical bonds made between the leather fibers and the tanning solutions. For the same reason it's important not to let it get too dry. Leather is tricky stuff.
-Gregory
-Gregory
Tourer
VO sells an oil that I have used on an old Brooks Pro that was dried and hard. It has softened up some and is fairly comfortable. But I still prefer the B-17. The leather on old Brooks seems a lot better than what you find now.
Quoted: 887 Post(s)
Liked 335 Times
My understanding is that neats foot oil comes in two grades; one is pure foot oil, the other is a blend of foot oil and petroleum distillates. Correct me if I am wrong.
TallRider
Bicycle Mechanics
4
09-20-19 02:56 PM
woahdae
Touring
26
03-07-15 06:14 AM
