Upgrades for a cheap folder?
Hello everybody, I'm a newb so bear with me...
I bought my first folding bike about 2 months ago, basically the cheapest 6 speed folder on Amazon. I got it basically new off craigslist for $70. I can't complain about its performance for the price, but there are a few things about it that I'd like to upgrade and I was wondering if you guys thought it would be worth it.
The front wheel has a small dent that causes it to wobble and lightly hit the brake. I have been riding it like that since I bought it. Is this worth getting fixed/replaced?
The handlebars on this thing are probably the cheapest part. Here is a link so you can see what I'm talking about... https://www.amazon.com/Folding-Bicycl...pr_product_top They are basically just an aluminum T clamped in the stem. They are very loose and squeak like crazy the entire time I'm riding. I'm not sure what kind of handlebars or handle bar stem I need to buy to replace the crappy thing I have. Any ideas?
Also, what is your opinion of suspension seat posts?
Kthx. Kbye.
Kthx. Kbye.
The Recumbent Quant
Hi,
A couple of comments:
* If you keep the frame but basically upgrade everything else, that will be more expensive overall then buying a higher end bike. If you've enjoyed the bike, then maybe you should just consider it a stepping stone to a nicer folding bike. This is what I'd probably recommend.
* If you can't afford a higher end bike, then it might not be crazy to upgrade a couple pieces. If, for example, nothing you can easily do fixes the stem being loose, then it's almost certainly not worth putting more money into this bike.
As far as your stem, I'd guess that either it's an easy adjustment or you basically need it replaced. From the picture, it looks like you can't swap out the handlebars without replacing parts.
Have you had the bike tuned up? You can do it yourself (I might start at the Park Tool website).
Your wheel sounds out of true. If you are patient, it is possible to true a wheel yourself. You could also take it to an LBS, but they might(?) charge you more than an (equivalent cheap) new wheel would cost.
Good luck and ask more questions!
Charles
Charles
to adjust for the rider's weight, and have some setback.. but they cost a couple hundred bucks.
Telescopic spring posts are mostly zero setback .. those come cheaper, down to $30.
but are for big wheel bikes, so may not go in place of a long folding bike seatpost
you might do to get a saddle with springs under it..
Quoted: 5 Post(s)
Regarding suspension seatposts while building a budget-minded cheap folder, your best bet might be a low priced suspension seat to use on the stock seatpost.
Something along these lines... https://www.amazon.com/The-Executive-...f=pd_sim_sg_44
Quoted: 317 Post(s)
All the cheapo bikes I have wrenched on have needed the front hub and rear greased and adjusted. Also brakes (V-brakes) greased.
To OP: Your info about handlebar being loose is not enough to tell us what is wrong. Desribe it more accurate and post a video on youtube if you can. It can be as simple as tightening a bolt or two. When something is loose you may destroy it further by using it so it is best if you can have it sorted out.
Search youtube, look for a local bike coop, search the forums for old threads about the sme issue or ask again.
The Recumbent Quant
I use a Cloud-9 Suspension seat on my folder and it is a big improvement over the stock seat.
(Not my picture)
The Recumbent Quant
TO the OP: Try truing the one you have...
Bikes: Bianchi hybrid. Dunelt 3-sp. Raleigh basket case. Wanting a Roadster.
There are two ways to look at it. This is a starter bike and you are going to replace it with something nicer real soon now, and you are going to have to make do with this bike for awhile.
Let's take the second one first. Many upgrades can be cheap, but make a real difference in the preformance of the bicycle. For instance I just bought a rear derailleur for my cheap folding bike. I did not go out and by an expensive one, the bike is not worth that, but I got a Tourney TX55, two or three grades better than what came on the bike for $10 from an on line seller. I just replaced the tires, about the cheapest tires I ever saw, with some not too expensive, but a lot better than it had for about $16 each. These make a real difference in the performance of the bicycle, without costing too much. Still most of the folks here are going to sneer at it, some of them are going to sneer at anything that costs less than $3000, so don't worry about it, just enjoy your bike.
Now the first. Suppose you know you are going to keep this bike for only a year, then upgrade it to an upper mid-range bike. So what happens if you put even better wheels and tires on this one than what comes on that upper mid-range bike. If they are the same size, you swap them to the new bike. In the mean time you have a bike that performs very well, because you are using an upgrade to the new bike on it. What you are doing here is pre-upgrading your intended bike by buying the parts before you buy the new bike and using them on the old bike in the meanwhile. A not exactly that, but amounting to the same thing, I took the Brooks B66 saddle from my commuter and put it on my cheap folder. A $150 saddle on a $266 dollar bike? Silly? Maybe, but darn comfortable to ride.
The point I am trying to make here is that there are all kinds of ways to get from where you are today to where you want to be next year, two years from now, or five years from now. Yes, you could just save your money until you have enough for what you want, or you can over load your credit card, or you could be riding while you are getting there without hurting yourself financially.
I will never have the 70' North Sea Style Trawler Yacht I want, but I have had a lot of fun with my canoe over the years.
I appreciate all of your replies, they have given me some good information. I'll start by saying the very first thing I did to this bike was buy a memory foam suspension seat because it was absolutely unridable with the original seat, ha. This small upgrade made a big difference and I'm not too concerned about getting a suspension seat post, but I didn't even think about regular seat posts being shorter than folding bike posts. So thanks for that info... Also, I think I will try to true the wheel myself because the dent is small and I think I could straighten it with a wrench. Is there some other tool that would make that task easier? Is it easy to put the inner tube and tire back on the wheel once you've repaired the wheel? Sorry, I know nothing about this stuff. The handlebars aren't really loose, they're just flimsy pieces of crap They are fine if you push them all the way down but if you clamp them up high for the upright riding position I prefer, they are squeaky and seem weak. I don't know how else to describe it, but would it even be possible to put standard handlebars on this thing? How would I find out what diameter stem to get?
Quoted: 317 Post(s)
Bikes: Montague MX, Brompton S6L, Origami Crane, Dahon S1
There is one more point to be taken into consideration: the opportunity to learn. Personally, I NEVER would have learned what I have about bicycle mechanics if I had just saved up money and asked a LBS for a bike they thought would fill my needs.
master of bottom licks
Quoted: 111 Post(s)
...The handlebars on this thing are probably the cheapest part. Here is a link so you can see what I'm talking about... https://www.amazon.com/Folding-Bicycl...pr_product_top They are basically just an aluminum T clamped in the stem. They are very loose and squeak like crazy the entire time I'm riding. I'm not sure what kind of handlebars or handle bar stem I need to buy to replace the crappy thing I have. Any ideas?...
I don't like them and find them to be nothing more than a novelty... YMMV.
Bikes: Too many....................
Quoted: 11 Post(s)
Liked 11 Times
I would make sure my rims had a good tape liner instead of the rubber and good set of tires and tubes.
Speed Uno
Dawes Kingpin 2speed
Speed Uno
