Frozen cable? (literally)
On my last two cold rides my right brake lever will just not move. When brought in the house after it frees up. The only thing I've been using on it with any regularity is wd40. I'm guessing there is a little water in the cable that is freezing. The bike is in my house when not riding. Is there a solution other than replacing the cable? I was thinking maybe a solvent of some kind, but I don't want to make thing worse. Any advice appreciated.
Quitting in an adverse situation leaves no alternative except death
Quoted: 1572 Post(s)
Liked 643 Times
Have you tried pulling the inner wire and blowing out the cable housing?
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Most likely moisture condensed inside the cable housings when you brought the bike into the warm house after a cold ride (and WD-40 evaporate pretty quick so it doesn't last long enough to repel it) so when you go back out it all freezes up.
Try pulling the cables and lubing them lightly with chain lube or something else that will last.
Today, I believe my jurisdiction ends here...
la vache fantôme
Originally Posted by concernicus
does anyone know what the freezing point of wd-40 is?
I've found tri flow in the cable housing to work well, and if you can get ahold of an air gun and blast it, that will remove the water.
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
Bikes: Peugeot Hybrid, Minelli Hybrid
There are spray lubricants that contain silicon, which will provide lubrication after the solvents have evaporated.
