Rear rack for road bike?
need a rear rack for road bike. panasonic dx-5000. must play nice with panniers. no mounting points on frame. any suggestions would be appreciated.
thanks
thanks
Quoted: 1188 Post(s)
Liked 1,154 Times
trevtassie, thks for the links, interesting. like that thru hub quick release solution but a bit spendy...hmmmmm
Liked 1,154 Times
What you need to watch out for with QR mount racks is flex in the mounts if they are thin so they can be used with a standard length QR. The rack can get up a real sway when loaded as I found with an Axiom Streamliner rack I fitted. I guess that's why the Tubus kit comes with a longer QR, so the mounting brackets can be thicker. Even the Tubus Disco rack comes with a longer QR.
Quoted: 753 Post(s)
Liked 737 Times
Blackburn used to make an adapter that fit in the open triangle of the drop out. They show up on eBay some times.
https://www.ebay.com/c/1865265376
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I've used rubber-coated "P" clamps successfully with lighter loads. Like for my wife's bike, not for mine.
hey barkeater,, thats a damn good idea. i'm thinking a guy could pull off the same set up with some bolts and flat washers. maybe carriage bolts
andrewclaus, i was thinking about the p-clamps also but was worried about their loading carrying abilities as well...maybe 2 per side somehow ?
The Tubus parts linked in #2 are likely your best bet for jury rigging a rear rack to a road bike. The clamp set in particular is more robust than P-clamps found in a hardware store.
Trailers are often a good alternative to fitting racks and panniers to a bike for which they were not intended. Bob Yak and Burley Nomad are a good starting point for touring-capable cargo bike trailer research.
The streamliner is a good sturdy rack, and the experience we had with it on a small road bike is that it worked very well
your load and mileage I guess can vary.
i appreciate all the suggestions and i am looking into each one....thks guys
hey djb, damn i think that may be it. looks like it checks all the boxes and not too terribly expensive...thks
Quoted: 1324 Post(s)
Liked 927 Times
On my 1980s Columbus SL frame with no rack mounts I used those Blacburn adapters and two plastic coated P-clamps. The P-clamps came with my rear rack. That system worked fine with a lightweight tent, lightweight sleeping bag and closed-cell foam sleeping pad.
Cheers
Cheers
Re p clamps, as a knowledgeable store guy once told me, the main weight of a rack goes down to the bolts at bottom, and p clamps for the horizontal stays really don't take much weight.
Helps of course to have good anti slip rubber under them and for them to fit securely and tighten well, but certainly doable.
No matter what you do, will depend on how much weight you put on rack.
ok, just purchased the axiom streamliner for $35 on ebay. free shipping.
thks guys for all your help
mark
mark
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
image by Stuart Black, on Flickr
Because of the frame and the brake, I only use one mount and one upper rack stay on this bike. It’s never been a problem.
The bike without a load
Untitled by Stuart Black, on Flickr
And with one. The load on the rack isn’t large...it’s mostly freeze-dried food...but where I ride it is very demanding.
The Tubus adapters work for any rack. You don’t need Tubus racks...although they are great racks...to use them.
Stuart Black
Stuart Black
Likes For cyccommute:
i just got off my ship and back to my bike. the axiom streamliner rack was waiting for me. took about 2 minutes to install. probably could have done it faster if i had put my beer down. i think it is going to be perfect for my co canal trip. (time will tell) i can see the point some made in terms of weight with this axle set up. i plan to keep my weight down though. i figure 10 lbs or so for scotch and 10 lbs for food. if that is too much i will carry less food.
thks to all for their help
https://www.tailfin.cc
hey johnj80, i checked out the link you provided. very cool rack. i will look at that rack/pannier set up when ready to upgrade
