Giro Synthe MIPS owners... what is this padding piece and where does it go?
Bikes: 2021 Litespeed T5 105, 1990 Gios Compact Pro 105
Quoted: 167 Post(s)
Liked 325 Times
Where does this padding piece go? It fell out of the box when I opened it lol.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I goes in the top of the inside.
Quoted: 4559 Post(s)
Liked 2,802 Times
Most helmet pads are secured with Velcro or similar hook and loop fasteners. They're designed to be removable for washing. The pads on both my Bell and POC helmets are currently drying over the tub after washing. They get pretty grungy from salty sweat in summer so I wash 'em at least once a week, sometimes more often. Ditto the straps.
On some helmets the hook part of the Velcro is pretty tiny, smaller than a dime, and may be difficult to see. The loop part is the flip side of the pad itself.
If the hook part of the Velcro is missing you can add your own. Any self-adhesive bit of Velcro tape will do.
On Bell and Giro helmets the MIPS system the pad is just for comfort, not a permanent bit of the MIPS system. The plastic harness with yellow flexible rubbery fasteners makes up the primary part of the MIPS system.
Quoted: 167 Post(s)
Liked 325 Times
I've learned to wash my helmet straps after use to prevent the salt build up on the straps. I also run the shell and all under the shower (inside and out) after every ride.
Quoted: 608 Post(s)
Liked 352 Times
With every new helmet purchase I order the replacement pads while you still can get them. This way I can wash a set and have the replacements ready immediately. I just rotate between the pair. I also order the fit system because those little plastic straps eventually break. It's about $25 for everything. And yes, I have broken these before and replaced them. Not that this has anything to do with the original question, as that was answered. Just useful information for some.
Liked 2,968 Times
worlds smallest sit bone pad would have been my guess.
-Oh Hey!
-Oh Hey!
Quoted: 167 Post(s)
Liked 325 Times
edit: just sent messages to giro, westernbike and competitive cyclist and asked...
Likes For gios:
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
They are $300 each. You save 10% if purchased in pair.
Quoted: 376 Post(s)
Liked 124 Times
Btw I have two Synth helmets, very light, airy, and super comfortable. Built quality, like all Giro helmets, not so great.
