Nexus/Alfine questions
Going to build my spouse a new ride. I have a lovely NOS Fuji S12S frame. 126 rear drop outs.
Her Riv Atlantis is 46/36/26 front, 13/32 rear. Trying to figure how to get a decent range of gears with an IGH. My eyes glaze over looking at charts. Any ideas appreciated
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
What you can do is find out what gears your wife spends the most time in and try to compare that to what a Nexus/Alfine can do.
I'm sure you've seen Sheldon Brown's info on the Nexus/Alfine with the hubs gear ratio shown there. Assuming 8 speed at the moment. https://sheldonbrown.com/nexus8.shtml
To make it simpler, just select a Nexus/Alfine in Mr. Brown's gear ratio calculator. https://sheldonbrown.com/gear-calc.html
I'm the anecdote.
Liked 1,176 Times
Just for example, my Nexus 8 bike came with a 42t chainring and 20t cog.
With the 700x38 tires on that bike, the gear inches were:
1st = 30.2, 2nd = 36.9, 3rd = 42.9, 4th = 48.8, 5th = 57.4, 6th = 70.2, 7th = 81.4, 8th = 92.7
After much riding time, I changed the cog to a 21t because I wanted 6th gear to be similar to my single speed bike's 66.2 gear inches.
1st = 28.8, 2nd = 35.2, 3rd = 40.9, 4th = 46.5, 5th = 54.6, 6th = 66.8, 7th = 77.5, 8th = 88.2
I spend most of my time in 5th, 6th, and 7th gear. Sometimes in 8th if I have a good tailwind. No hills here, so the lowest 4 gears aren't used hardly ever.
Just for the heck of it, I selected the Alfine 11 in Mr. Brown's calculator and, using the same 42/21 sprockets and 700x38 tires, came up with:
1st = 28.8, 2nd = 37.2, 3rd = 42.1, 4th = 48.0, 5th = 54.4, 6th = 62.0, 7th = 70.6, 8th = 79.9, 9th = 91.1, 10th = 103.2, 11th = 117.6
Makes me think I'd change the 21t cog to a 22t or a 23t, if I had an Alfine 11 on that same bike.
Palmer
Quoted: 1659 Post(s)
Liked 1,806 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
Here is a gear calculator that I find useful, it gives both graphical and numeric information; internal gear hub ratios are built in: https://www.kstoerz.com/gearcalc/compare/
