Front cables cast shadows with light
Handlebar type: Northroad upright. The brake and derailleur cables are in the path of my light and cast distracting shadows on the pavement. Anyone else have this problem? Any solution?
Quoted: 1438 Post(s)
Liked 1,092 Times
Move the light; there are attachments which allow mounting lights on the fork blades or to the front axle, if moving it along the bar is impractical. Or mount it on your helmet and it will point where you are looking; great for letting drivers know that you are there.
My light is the Bright Eyes 1200-lumen. I'd like to leave it on the handlebar to be able to adjust the brightness, especially for oncoming cars. I have a sense that 1200 lumens is too bright for them so I either angle the light down or dim it for them.
Is it possible that mounting the light higher would help? Is there some mounting device that would raise it up, say 3"?
Liked 1,092 Times
Yes there are, like this one: https://www.amazon.com/Topeak-600010.../dp/B000FIAVN8 Check out the other items which show up on its page.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
I ride that way in the dark usually twice a week. Often quite a few hours. Be doing over a century half in the dark for a few years. I have the shadows you mentioned. It's not a problem for me.
Also, the bike that has gray DA cables reflects a little back to the bike, it makes it easier to see the bottle cages in the dark. Silver bottle cages are easier to see than black, in the dark.
LET'S ROLL
Used to have the same generic Magic Shine light.
Here I mounted by the head tube:
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Quoted: 18374 Post(s)
Liked 4,509 Times
My Nightsun headlight used to have a remote dimmer, although I don't think that is as common anymore. Anyway, it would allow placing the lamp anywhere, then dimming at the handlebars.
For drop bars, Campagnolo has used aero routing in their shifters for quite some time. New Shimano shifters also use aero cable routing.
For your Northroad upright bars, you could get reverse aero brake levers similar to these.
https://www.niagaracycle.com/categor...ever-set-black
They'll either route the brake cables along the bars or inside the bars, and thus a lot more out of the way.
You may also be able to use aero road brake levers on your bars, although perhaps with somewhat different bar shapes. Butterfly bars? Moustache bars? Again, hidden cables along the bars.
Another option might be black brake cable housing, or better yet flat black housing. Unfortunately, I don't know if anybody is making flat black, but you could take gloss black and spray paint it.
Quoted: 980 Post(s)
Liked 582 Times
Steve
Quoted: 980 Post(s)
Liked 582 Times
Some lights have opening on their undersides and may not be water-resistant when mounted upside-down. Also, some lights have "shaped" beam patterns that illuminate best when they are in the upright position. Just saying...
Steve
Steve
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I've done that also, looks and works better than over the bars IMO. I just like it out of the way, under the stem.
Fork Crown headlight mount, here, no problems...
light mount on top edge of front basket?
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, Circe Morpheus, 2021 Rose Backroad, 2017 Devinci Hatchet
Quoted: 181 Post(s)
Liked 14 Times
Would you be able to shorten the cables a bit or carefully use some zip-ties to move them out of the way?
Lot's of good ideas here, THANKS! I think an extension that rises above the bar is the best solution because at some point I'll also have a bag on the handlebar and that will create a new problem with the headlight.
Metaluna
22
10-22-17 09:26 AM
DTownDave22
14
04-01-15 10:24 PM
