Quality Gravel Tire for high and low pressure excursions
Bikes: 2017 GT Grade Carbon Sram Force, 2014 Globe Roll 8 (w riser bars), 2015 All City Space Horse (cantilever)
Quoted: 37 Post(s)
Howdy folks, I'm building myself up a new gravel bike and am trying to decide on tires. On my current bike I've got tubeless Clement Strada USH's wrapped around Stan's Radler wheels and they've been fantastic- able to run both stiff pressures when on the road and lower pressures when off. I've been a little confused tho bc Clement recommends 40-60psi for these and yet I've had no qualms regularly running them at 80 when I'm on tarmac. Is it typical for many gravel tire companies to downplay the psi recommendation when in actuality they can be run much higher? I kinda had my heart set on some Panaracer Gravel King SK's since they're such a hot ticket right now, but then I read they too have a recommended max of 60 when tubeless. Anybody out there who owns any care to weigh in?
Also looking at a few other familiar names in this category ie Ritchey Alpine JB, Schwalbe G-One Allround if anyone thinks any of these or any others not mentioned are best suited for duel high/low pressure performance. Thanks!
Quoted: 1218 Post(s)
Liked 298 Times
there is a new tire coming to the market from Maxxis which would play closer to Gravelking slicks, G'one, and Compass. yeah Maxxis already has Refuse, but they are going lighter with the "Maxxis 700x40 Velocita AR all-road gravel bike tire"
Why would you run Strada USH at 80 PSI? why run any tire at super high PSI?
Quoted: 1216 Post(s)
Liked 186 Times
The PSI recommendation is because the bead on tubeless tires does not have the same support from the tube/tire interface and as the pressure gets higher the bead is more likely to blow off. There needs to be a large enough margin of error to keep the bead in place during very hard riding in different temperature conditions as well as variance in rim BSD and bead shelf. I'd never run a tubeless tire above the recommendation from the manufacturer. I have enough faith that at the very least they're capable of doing the math to figure out a good theoretical safety point if not actually pulling and testing tires from production.
There's no reason to have such vast swings in pressure, you're not gaining anything other than unnecessarily stressing the tire, rim and spokes.
Barrettscv
27
02-13-17 03:29 PM
garciawork
21
04-15-16 03:05 AM
TimothyH
20
01-18-16 08:29 AM
DirtRoadRunner
30
12-28-15 08:05 PM
