Big Front Disc on a Gravel Bike?
Old 02-08-19, 04:51 AM
RicePudding
RicePudding's Avatar
Bikes: Giant Toughroad SLR GX 1 (2018), Giant Talon 2 (2010, RIP)
Quoted: 22 Post(s)
Been looking into whether or not it's worth running a larger front disc on the front of my Toughroad GX1. The bike is currently equipped with the stock 160mm front and back.
I just want a bit more confidence when on trails and rocky descents as well as improving modulation and was wondering if this would make much of a difference.
Has anyone got a 180mm on their gravel bike?
I know most CX riders prefer 140mm or 160mm to save a bit of weight.
RicePudding is offline
Old 02-08-19, 05:33 AM
srode1
Gravel Rocks
Bikes: Trek Domane and Crockett, BH G7, Niner RLT9, RLT9 RDO
Quoted: 124 Post(s)
Liked 38 Times in 29 Posts
Might be some advantage with Mechanical Discs - not needed with Hydraulic IMHO.
srode1 is offline
Old 02-08-19, 10:06 AM
86az135i
Bikes: 1996 Cannondale R900, 2016 Trek Boone, 2005 Giant Yukon
Quoted: 584 Post(s)
Liked 66 Times in 54 Posts
Probably not needed. But if you're experiencing pad fade, then maybe a little more thermal mass in terms of a larger rotor would help. Also going bigger then stock could stress your fork more since now you have more braking torque.
86az135i is offline
Old 02-08-19, 10:25 AM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
Also depends if your fork can support 180mm
Elvo is offline
Old 02-08-19, 10:36 AM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
^That^
Most road/CX forks are not rated for 180mm. And unless you're touring or weigh a great deal and are bombing down hills, there's no need for the rotor diameter. Odds are on a gravel tire, off-road, the wheel will lose traction before you run out of braking power with a 160mm rotor.
Marcus_Ti is offline
Old 02-08-19, 12:16 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
I'd go with 180 mm or larger if my bike supported it.
Always go with the biggest brakes your vehicle supports. It's the number 2 upgrade after tires.
But yes, most gravel bikes only support 160's.
TimothyH is offline
Old 02-08-19, 12:27 PM
San Rensho
Quoted: 383 Post(s)
Liked 133 Times in 91 Posts
Are you guys crazy. Anytime that that you are in anything slippery, like gravel, Sand, Grass oh, you never used front brake hard because it will immediately lock up and now you're down on the pavement or gravel.
You always use the rear brake As much as possible.Learn to ride a bicycle you don't know what you're doing. Go ahead and spend lots of money on new components because you think that that is what's going to make you a better bicyclist.It's knowing how to ride a bicycle and technique that makes you go fast.
San Rensho is offline
Old 02-08-19, 12:40 PM
86az135i
Quoted: 584 Post(s)
I didn't know OP was asking for biking lessons.
86az135i is offline
Likes For 86az135i:
Old 02-08-19, 12:45 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
I plan on going from 160mm to 180mm on the front. I'm 220 lbs. and I think the extra braking power + cooling would be useful. And it's cheap.
tyrion is offline
Old 02-08-19, 01:17 PM
RicePudding
Quoted: 22 Post(s)
Maybe I should put stabilisers on my gravel bike instead...
Old 02-08-19, 01:21 PM
RicePudding
Quoted: 22 Post(s)
Yeah I'm not sure why it's just been touted as expensive and crazy. I was just wondering what people thought of it and if anyone has done it to their Gravel bike. I know it's the norm with XC bikes but I wasn't sure if it's a bit overkill for gravel.
It would be cheap, the post to post adapter is £6 and I can get a Shimano SLX rotor for £12. Cheap as anything.
Old 02-08-19, 01:31 PM
tyrion
tyrion's Avatar
I think it depends on your weight and how much downhilling you do. You don't want it too easy to lock up the front wheel, but at my weight I don't think I'm close to that.
tyrion is offline
Old 02-08-19, 02:05 PM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
what fork?
redlude97 is offline
Old 02-08-19, 02:06 PM
86az135i
Quoted: 584 Post(s)
If you're already hydraulic I would just look at upgrading your pads. Stock resin pads generally aren't the greatest for large decents. See if that suits you before going to a larger rotor.
86az135i is offline
Old 02-08-19, 02:12 PM
tyrion
tyrion's Avatar
Originally Posted by redlude97
what fork?
It's a Breezer Radar with a rather clunky looking steel fork w/ IS mount. It "looks" strong enough.
tyrion is offline
Old 02-08-19, 02:14 PM
86az135i
Quoted: 584 Post(s)
Steel is weak. Everyone knows carbon fiber is the superior race lol.
86az135i is offline
Old 02-08-19, 03:03 PM
RicePudding
Quoted: 22 Post(s)
Thanks, I'll look into that, one of my pads is already showing a fair bit of wear so maybe a replacement upgrade would be better
Old 02-08-19, 07:45 PM
TimothyH
- Soli Deo Gloria -
This simply isn't correct.
I would encourage anyone who wants to learn proper braking technique on gravel to watch the Skills with Phil flat turn video.
-Tim-
TimothyH is offline
Old 02-08-19, 07:53 PM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
I think if I killed a white crowned sparrow like that, I would have a difficult time getting back on the bike. That was a real sad ending to the video.
I've thought about a 180 mm front disc, but I think the brake would become too grabby. (I put 160 mm ones on my mountain bike for that reason.)
Cyclist0108 is offline
Old 02-08-19, 08:08 PM
TimothyH
- Soli Deo Gloria -
I rode a Santa Cruz downhill bike with something like 208's and LOVED the brakes. I dream of having brakes like that on my gravel bike.
-tim-
TimothyH is offline
Old 02-08-19, 08:17 PM
Cyclist0108
Occam's Rotor
-tim-
My kid has that on his mountain bike (not a down-hill bike), and they are quad-piston. I had a hard time with it.
Old 02-08-19, 08:23 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
I have about 18,000 miles with a 180F/160R setup-- split almost evenly between mechanical (Shimano CX77,) hybrid (TRP HY/RD,) and hydro (Hope RX4.) I love it. I have no desire to change.
A bigger front rotor is not "more grabby," regardless of what kind of caliper is squeezing it. It just makes it so the lever feel is the same for both hands-- and the pads wear out at around the same rate.
I mean, try to find a car that has the same size brake rotors front and rear-- and as a bicycle does the bulk of the braking with the front, why shouldn't that rotor be bigger?
DrIsotope is offline
Old 02-08-19, 08:26 PM
Cyclist0108
Occam's Rotor
I think many of the forks out there say 160 mm maximum rotor diameter (eg: Enve CX, which is what I have). I would hate to find out the hard way why that might be.
Old 02-08-19, 08:40 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
In most cases it appears to be clearance-- the top edge of the rotor is usually about a millimeter away from the leg. But with full CF forks, there may be some other structural cause for concern. My fork is steel, and would easily clear a 203mm rotor.
Old 02-08-19, 10:37 PM
redlude97
same reason I run 160f/140r for gravel and cross. What made you feel the need to go to 180 though?
