Dreaded mystery noise - help please!!!
Quoted: 10 Post(s)
I'm hoping one of the good people on here will give me some ideas of how to proceed with rooting out the problem.....
The noise:
A "tick" sound when pedalling coming from bottom bracket area, one or two ticks with each revolution of the pedals.
Seems to happen when pressure is applied to the left pedal.
The noise gets slightly louder when more pedal pressure is applied and occurs in or out of the saddle.
Diagnosis attempts:
- Pedals - swapped for a spare set, threads greased and reattached.
- Botton Bracket - Press fit bearing repacked with grease whilst in situ. Wheels MF BB is less than one year old.
- Seatpost/Saddle - both swapped from other bike to test. Orignal seatpost and saddle contact points greased and reattached.
- Water bottle cage nuts - Removed, cleaned, regreased, reattached.
- QR skewers and frame dropouts - Removed, cleaned, regreased, reattached.
- Chainring bolts - Removed, cleaned, regreased, reattached.
- Rear derailleur hanger - Removed, cleaned, regreased, reattached.
- Mudguard fixing bolts - Removed, cleaned, regreased, reattached.
- Frame - checked for hairline cracks - cannot find any evidence of cracks.
- Cleats - replaced, bolts greased.
- Headset checked for play
I think that about covers everthing I've tried so far.
Can anybody suggest anything else I might've missed that would potentially be responsible for a sound as described please?
Thanks in advance.
The noise:
Diagnosis attempts:
Thanks in advance.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
What are you wearing (that might make a noise)? Could be the zip on your jersey, jacket, or gillet. Even a shoelace.
Quoted: 6193 Post(s)
Liked 4,808 Times
Do you feel it too? or just hear it? Once I had a tick sound that seemed to come from somewhere down there in the crank area. Exclusively heard only when I put some effort into pedaling. Months later, I realized it was the metal tag on the zipper of my seat bag hitting the back stay.
Quoted: 10 Post(s)
The left crank is hollow, with a grey spacer directly between it and the frame/BB.
There didn't appear to be any obvious way to detach the crank arm from the spindle.
There certainly wasn't any play in it.
I did take a picture to illustrate, but I haven't posted on the forum enough yet to be able to upload pictures.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
Could be a bearing. I had one making noise and fixed it by removing it, popping out both seals, cleaning it thoroughly and regreasing. Saved about $45. Simply adding grease in situ didn't do it.
And here I thought I'd get through the day without using any Latin phrases.
Likes For andrewclaus:
Quoted: 10 Post(s)
Quoted: 10 Post(s)
Quoted: 10 Post(s)
Granted not as easy to clean whilst still in the bike, but the manufacturer advise the bearings can be serviced without removal.
If I wanted to remove and replace them, then I'd have to buy the bearing extractor and associated tool from WM - a cost I'm trying to avoid at this point.
Quoted: 675 Post(s)
Liked 741 Times
I could feel a 'catch' in mine on the bike, and couldn't get it cleaned out well enough on the bike. I made the tools--an extractor from a piece of EMT sawed in quarters (a small headset tool), and a press from sockets and all-thread.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Such a click on one of my bikes turned out to be a micro crack in the crank arm. I realised this as my body rudely met the road when it finally cracked completely.
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,032 Times
-Matt
Likes For MattTheHat:
Quoted: 762 Post(s)
Liked 4,032 Times
Velcro shoes rule out the show laces. Well, my "friend's" shoes had velcro, but also had laces.
-Matt
-Matt
Quoted: 254 Post(s)
Liked 182 Times
The crank arm and spindle were attached as one when I removed the to access the BB bearings.
In any case, it sounds like you have confirmed that the crank arms are tight, though not feeling any play by hand is different from “doesn’t move under high pedaling force”.
Front derailleur cable ends can also be a culprit, hitting the crank arm as it goes by each time, maybe only when you’re on one of the chainrings and not the other. For me it was the smaller ring.
Quoted: 10 Post(s)
So when you say “left”, do you mean the side where the chain is (ie drive side)? That’s usually the side that is permanently attached to a hollow spindle, but I assumed you meant the one on the rider’s left when pedaling, which is the nondrive side and usually is the one that detached from the spindle.
Left side (riders left) is non drive side, crank attached to the hollow spindle. Drive side is a single chain ring (no front derailleur) which slots over the spindle and is tightened with 8mm Allen key.
I recently had some creaking that was from the freehub, even if it sounded like the crank. A few drops of oil and it went away.
Quoted: 10 Post(s)
I've had freehub issues on other bikes and the sound was more of a "clunk".
The hubs were serviced (as was the whole bike) back in February by my LBS which is why I've not touched them yet.
Quoted: 10 Post(s)
UPDATE:
I've been commuting to work as normal on my bike this week, and the noise has progressivley got worse.
The single "tick" has now progressed to multiple "ticks" and I can feel it through both pedals when minimal pressure is applied.
So, I'm at the point where I'm thinking if the bottom bracket needs to be looked at in greater detail, then I'm going to have take the bike in to my LBS as I have no tools to remove the bearings or the PF shell.
Before I do that though, I would like to investigate the rear hub as a potential cause - as this is the only obvious area I've not checked yet.
Which leads me on to my next set of questions
Cassette removal - the bike has and SRAM XG 1150 11 speed cassette on it.
I only have a Shimano cassette removal tool (used on my other bikes) - will this tool likely fit the SRAM cassette?
As I understand it, SRAM 11 speed freehubs also have an XD driver attached to them - I've never worked with these either.
Are they easy to remove?
Are the bearings in the hub accessible as on "normal" bikes?
Thanks in advance
Thanks in advance
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times
Just for spits & giggles, get on the bike, clip in, but stay stationary and lean against a wall or something (a stabilizing friend might be handy here).
Then stand up on the pedals, applying full weight in different positions, but not spinning, and see if you can replicate the sound. If so, that may eliminate some possibilities, plus, the friend can also lean in closer and positively ID the source of the sound.
Blue Collar Cyclist
Bikes: Motobecane Gravel X1, Iron Horse Maverick 1.0
Quoted: 43 Post(s)
Liked 21 Times
Had the same "click" on my previous bike. It about drove me nuts trying to find the problem.
The fix:
Pull the bottom bracket cartridge, wrap the threads in a single layer of Teflon tape, re-install.
I did that, and then rode for three years with no ticking (now my kid is riding it).
The fix:
