Derailleur question
Derailleur question
Old 07-17-19, 06:17 AM
genxrev
Bikes: Framed Minnesota 2.0, RADwagon ebike, Giant simple 3 cruiser (plus 2 Harleys)
Derailleur question
Good morning friends,
I’d like to be able to say I was drunk, or distracted by a butterfly, but really it was just a stupid mistake.
I meant ant to tighten my brake cable, and instead loosened and readjusted my rear derailleur cable.
I’ll pause while you all laugh and prepare your mocking replies, God knows I’ve earned them.
Now it won’t shift into the two highest gears. Before I go mucking it up worse, what should I do? I have adjusted dozens of derailleurs, but I’ve never run into this problem, albeit sadly of my own making.
Mark
genxrev is offline
Old 07-17-19, 06:49 AM
andrewclaus
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times in 429 Posts
Just loosen the cable (screw in the barrel adjuster) until it shifts correctly. If you go too far and need to tighten it, first shift into high to relieve tension in the cable so you don't strip the barrel adjust threads, and to make it easier.
Start with one turn, repeat, then when it gets close use half and quarter turns. Often the final adjustment is a quarter turn.
There's probably a second barrel adjuster at the derailleur.
andrewclaus is offline
Old 07-17-19, 06:54 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,095 Times in 741 Posts
Was your shift lever in the highest gear (smallest cog) position when you reattached the shift cable? I'd start from scratch at this point. Remove the shift cable, shift the shift lever to the highest gear position, reattach the cable with no slack and readjust shifting until it indexes properly using the barrel adjuster(s).
HillRider is offline
Old 07-17-19, 07:54 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
Do as HillRider suggests, thenfollow this procedure: https://www.parktool.com/blog/repair...eur-adjustment
dsbrantjr is offline
Old 07-17-19, 09:15 AM
genxrev
Thanks, I truly appreciate the advice. I was thinking of how to do more of a reset. I see a reply about that below. I like to leave the barrel adjustments for emergencies or short term fixes.
genxrev is offline
genxrev
This is what I was looking for. Thanks a ton!
genxrev is offline
curttard
Bicycle Mechanics
3
05-28-18 04:07 PM
ShartRate
Bicycle Mechanics
3
02-24-13 07:00 PM
goldfinch
Bicycle Mechanics
14
01-02-13 09:57 AM
dhoyt
Bicycle Mechanics
9
03-20-11 10:03 AM
adrn
Recumbent
2
03-08-11 05:03 PM
