Choosing a Rear Deraileur
Quoted: 8 Post(s)
Hi I purchased a used Kona Blast. It is an 8 speed with 3 at the front for a total of 24 gears. The original deraileur was a Shimano STX-RC which i believe was long cage. Original bike specs , 30T , 11T rear and 42T, 22T on the front, max capacity of 39. I changed the rear wheel only and the back cassette so the new specs are 32T,11T on the rear giving a max capacity of 41. I am looking for a replacement deraileur, I just want to confirm that this one would be suitable:
Shimano Claris RD-R2000 Rear Derailleur GS
Min cog size : 11T
Max cog size : 32T (SS), 34T (GS)
Max front difference : 16T (SS), GS 20T
Capacity : 37T (SS), 43T (GS)
Specifications:
GS Cage:
Cage: GS
Max Front Difference: 20T
Maximum Cog: 34T
Minimum Cog: 11T
Primary Color: Grey
RD Capacity: 43T
Speed: 8
Thanks for your help.
Julian
Min cog size : 11T
Specifications:
GS Cage:
Cage: GS
Maximum Cog: 34T
Minimum Cog: 11T
Primary Color: Grey
RD Capacity: 43T
Speed: 8
Julian
Quoted: 857 Post(s)
Liked 1,090 Times
Yes, that will work. Here is a chart that will show some others that will also work if you're interested. Bicycle Cassettes & Drivetrains - Google Sheets To eliminate any that won't work, check the pull ratios first. (Look right on the top column for "pull ratio".) You need a 1.7 ratio derailleur. STX-RC is listed in row 286 for reference.
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 882 Post(s)
Liked 1,232 Times
Julian,
Are you looking to change the existing rear derailleur due to the Total Capacity being 2T too low?
Shimano is quite conservative with their Max rear cog limit and their Total Capacity limit.
Look this one up
RD8050 with 50/34 front and 11-36 rear. Many have gone as far as 11-40 rear.
Yep.... way over spec for both Cog and Capacity. I've got 4-5000 miles on that 11-36 setup.
For the sake of being 2T over the capacity, I'd give test it on the bench and see how it changes.
DO BE SURE your chain is the correct length. If it was cut short to begin with, the 2T could aggravate the problem.
Welcome to Bike Forums
Barry
Look this one up
Barry
Really Old Senior Member
IF you existing RDER works, keep it.
Size the chain for BIG:BIG.
Worst case is you have a tiny bit of chain sag when using the smallest ring:cog.
That's a really dumb combination to use.
Likes For Bill Kapaun:
Quoted: 8 Post(s)
More information
Thanks for the feedback.
The original derailleur on the bike is the Deore RD-M510. In the spreadsheet it is listed as 9 speed. However the original cassette is an 8 speed, so that is somewhat confusing to me. Why is this? I am new to this, first bike rebuild. I am okay keeping the original derailleur, it is just that i have some newer rims with a cassette already on it that has and extra 2T on the largest rear cog compared to the original cassette. Both original and new cassettes are 8 speed. I guess I could move the cassette from the original rim, to the new rim. It seems the original Deore RD-M510 could handle the extra 2T according to the specs ? Also I thought having a newer derailleur would be better for performance ? The Claris seemed to fit well.
Quoted: 8 Post(s)
Clark W. Griswold
Quoted: 4445 Post(s)
Liked 4,101 Times
A new derailleur especially a downgraded one is not always better, my 94ish M737 rear derailleur will probably outlast the bike it is on and like I said it is running 9 speed. If they made it for 11 speed I would be all over it in a heartbeat. It is a very well built derailleur that I think looks decent but some people disliked the looks but in the end the performance is flawless and it is hard to kill one. I have tried certainly and I got it used and it just keeps going and going. Deore can also last quite a while. I have seen some old deer head stuff that is still going strong after almost 40 years.
Basically you are using your smallest ring at the front and your smallest cog at the rear which would be a very easy gear at the front and a very hard gear at the back it is called cross chaining when the chain is at the extremes in either direction but in that case it is quite an odd combination to be in.
Now stand 5-8 feet or so behind the bike and "sight" down the chain like a rifle. (it helps if you can have someone hold the bike vertical)
You'll see it runs at a very extreme angle. Bad enough that even a newbie would realize "it can't be good" for longevity of the chain.
Just Pedaling
Bikes: YEP!
Quoted: 346 Post(s)
Liked 554 Times
Likes For SpedFast:
Bikes: Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 177 Post(s)
Liked 105 Times
Gonna be a HUGE help in keeping a couple of vintage bikes running!
Cheers, Mike
Cheers, Mike
Likes For PromptCritical:
Quoted: 857 Post(s)
Liked 1,090 Times
There are a few details left out from some items on the chart but in this case 8 and 9 speed are irrelevant for your old derailleur and the Claris. They can be used for both. Many Shimano derailleurs can be used for various numbers of speed combos and groupsets. It can get a little confusing but just ask here when in doubt.
LR÷P=HR
Quoted: 882 Post(s)
Liked 1,232 Times
If the “pull ratio” matches on both shifter and derailleur, an 8 speed shifter can be used with a 9 speed derailleur and an 8 speed cassette.
The “bad combination” comment earlier did not refer to your parts, but referred to the way you might use them.
it was referring to cross chaining. << clickable link.
Hope that helps
Barry
Quoted: 395 Post(s)
Liked 895 Times
Seems like the original setup was fine, and you probably don’t need a new derailleur. You may need a new chain if you’re installing a new cassette, and the chain is worn. As for using the small/small gear combo, that is called cross chaining and should be avoided on any bike.
SE Wis
Quoted: 2752 Post(s)
Liked 3,412 Times
that Deore will index &shift 6-9 speed mountain and 6-10 road (except 4700 Tiagra & some older DuraAce) shifters. Better unit than the Claris
Likes For dedhed:
Quoted: 177 Post(s)
Liked 105 Times
Julian
Julian
Cheers, Mike
Cheers, Mike
Quoted: 177 Post(s)
Liked 105 Times
It's not a problem, as I converted to a friction shifter using a Paul Comp thumbie and Campy lever, but I'm curious as to what I'm missing.
Cheers, Mike
Cheers, Mike
Quoted: 857 Post(s)
Liked 1,090 Times
I've converted both of our tandems (one now retired) to flat bars due to my arthritis. Switching to a trigger shifter for the rear derailleur was easy. However, I've never found a derailleur/shifter combination for the front (triple crankset) that works.
Quoted: 177 Post(s)
Liked 105 Times
I'm going to keep it, but I'm still curious........(I'm a recovering engineer, but my friends say the recovering isn't going well).
Cheers, Mike
Cheers, Mike
Quoted: 395 Post(s)
Liked 895 Times
Quoted: 177 Post(s)
Liked 105 Times
Yeah, and I have a box full of them (for the front DR - the rear was easy) that didn't work. No idea why. Free to a good home (or a bad one).
Cheers, Mike
Cheers, Mike
Quoted: 395 Post(s)
Liked 895 Times
I’ll take them off your hands if you must get rid of them though!
Quoted: 177 Post(s)
Liked 105 Times
I sure thought I was, but buying individual parts instead of a groupset, is problematic since there are so many variations.
Cheers, Mike
Cheers, Mike
