Flashlight mounting techniques?
Bikes: Frankenstein 1980 (?) Takara 1x7
Quoted: 7 Post(s)
I got my cheapo Hong Kong knockoff LED torch in the mail today and it's pretty sweet, but the $2 bike mounting clip I ordered with it is a complete piece of junk. What's a good way to mount a flashlight securely to a flatbar? I'm looking for some solution that I can buy and/or put together without waiting for something to ship from an online store, if possible.
Arrogant Safety Nanny
Bikes: 2007 Trek 7.2 FX, 2008 Trek Madone 5.2
Do you have a link or a picture for the size of the flashlight?
Using an O-ring, Livestrong wristband, or similar device, and a rubber spacer between the bar and the light, should be a secure way to mount your light to a flat bar. You can experiment with different sizes of O-rings for a good fit.
Here's a picture of my cheap 9-LED 3xAAA battery dealextreme flashlight (the red one) mounted to my handlebar using a Dinotte taillight spare O-ring and an extra rubber spacer from a bike mount.
Schwinnasaur
I use this and it works well. https://batteryjunction.com/twofish-lockblocks.html
Schwinnasaur
I use this and it works well https://batteryjunction.com/twofish-lockblocks.html
Isaias
Bikes: Ridley X-Fire (carbon, white)
Quoted: 7 Post(s)
The LED torch in this picture is using a wrist bracelet like the Livestrong one:
Schwinnasaur
Healthy and active
Bikes: mid-60's Dunelt 10-speed, Specialized Allez Sport Tripple, Trek 7.2 FX
I used a welder and some scrap 1/8" strap iron to make this flashlight mount. The flashlight attached to the flat bar with hose clamps. A strip of thin rubber went between the flashlight and the flat bar. The curved bar was bent to fit the contour of the handlebar. a piece of thin rubber went between it and the handlebar. Another hose clamp held it on the handlebar. It is quite sturdy and the flashlight can be removed very quickly for use elsewhere.
crash survivor
Bikes: C-dale rush, Mountain cycle fury, Monocog 29er, Haro hard tail VX, Scattante R330
I use a pipe clamp 5 for $2.95 and an old reflector mount $free. They have them big enough for a mag light if you wanted to.
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
You could use a TwoFish Lockblock to mount a flashlight to virtually any bike. They use Velcro straps to secure the light to your handlebars, seatpost, helmet or whatever. Cost about $7 at the Fenix store, but probably available at other outlets as well.
https://www.fenix-store.com/index.php?cPath=25_66
Bikes: 08 Novara Safari; 06 Schwinn Super Sport DBX
u
n
DancesWithSUVs
Quoted: 7 Post(s)
Had a friend who used to use these for his front and rear lights:
https://www.niteize.com/productdetail...&product_id=79
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
Quoted: 7 Post(s)
I went to two hardware stores and somehow couldn't find a suitable O-ring at either one, so I caved and bought a 3-pack of LockBlocks from the Fenix store. It's probably better than way anyway, because it will be simpler to remove the lights when I lock up. I did a test run with a wad of rubber bands in place of a proper O-ring and it was a bit of a hassle.
Perineal Pressurized
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
Schwinnasaur
TwoFish blocks work well. Here is a better deal on them https://batteryjunction.com/twofish-lockblocks.html
Scott
Bikes: Too Many
EMT conduit hangers work great and there cheap. They overlap to provide sizing to anything round from about 5/8 inch up to just over 2 inches in diameter. You can bolt them back-to-back with a short 1/4-20 bolt, nut, and washer. Here is a photo of one clamped to my DIY dynamo headlight with Luxeon optics and LED mounted in a 1 inch PVC pipe coupler. I used an old plastic blinkie clamp to attach the conduit hanger to the handlebar.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
I made the equivalent of a lockblock with a tiny scrap of wood and a drill bit (forstner bit), and use that and a couple of stout rubber bands (they come free on my mail delivery) to mount a flashlight when needed. Total cost was 5 minutes of time.
Work: the 8 hours that separates bike rides.
Used an old tube cut and tied end-to-end with fishermans knot to make a giant rubber band. With a little creative wrapping (sort of like the rubber mini-maglite holder shown above) you can hold a flashlight really tight and also ensure rubber between the handlebar and the flashlight.
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 540 Times
These are nice, but spendy: Scroll down to bottom of page
https://www.velo-orange.com/batterylights.html
Soul filled with grease
Bikes: Early Surly XCheck;1960 Schwinn Speedster;1996 Giant CroMo Camper;1986 Fuji
Old thread, but here's what I did last night with an old tube and a new Task Force light. The light
never moved on my test ride. Re-cycle, Re-use, go ride.
-put flashlight through hole in tube
-wrap around bar and light
-put the other end of tube [with hole] over light
^^^ much simpler. The first inner tube mount I tried came out OK. I just tried it with a wider tube and was having trouble getting everything symmetrical.
aka Phil Jungels
I love the concuit ceiling clamps. Cheap, and works great. Easy to remove, and very sturdy. Available for any size bars, and any sized flashlight. Cover 'em with shrink wrap to make them scratch proof.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12860 Post(s)
Liked 7,775 Times
I like the tube action, mangosalsa. Maybe slightly more difficult mounting/removal than o-rings, but cheaper and more solid looking.
If anyone's looking for a light similar to the OP's with built-in rubber coating, check out your Home Depot for the Husky 9-LED. The coating also glows in the dark, which is more handy than I would've imagined.
