Threadless headset ; changed out stem now the headset will not tighten
Hi ,
As in the title , I changed out a stem on a bike with a threadless headset . But after doing so the headset wont tighten up . I assume the new stem is slightly shorter than the old one and so the total height of spacers and stem combined has decreased .I tighten the cap bolt as much as I can but still the spacers are not pressurised and can jiggle about freely .
Will putting a 3mm spacer in there sort this out ? I say 3mm as that is the smallest I can seem to come across wirth an online search .
Thanks for any help ,
J
J
Bikes: 2013 Cannondale Synapse 6 Tiagra + 2016 Cannondale CAAD 12 Dura Ace
Quoted: 231 Post(s)
You didn't tighten the stem all the way first did you?
I've gotten 1 1/8 spacers as small as 2mm, pretty sure I've seen as small as .5mm
Yo
Hi ,
J
J
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
None of us will be able to tell if a 3mm spacer will work because we can't see the bike.
But you definitely NEED a spacer, of some kind. And the top cap bolt does NOT get tightened all of the way, just enough to preload the bearings.
If the stem is flush with the top edge of the steerer tube, the top pre load cap cannot work as designed.
then you must put a spacer above it... stem bolts loose, around the steerer, until after the headset is right.
I have the stem at the bottom (40mm) then the two spacers above it (10mm) each . The top spacer is flush with the steerer so the pre load cap is not working . I was thinking a 3mm spacer but will this work sitting unsupported by any steerer tube on top of the 10mm stem below it ? Would not a better move be to remove the top 10mm spacer and pop in a 13mm or 12mm spacer if such a thing exists ?
Yes thats the problem .
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
Hi ,
J
J
Don in Austin
