Run tube on tubeless tire
Hi, so, I am running tube and right now my tires are used so I am going to buy new. The shops nearby have majority tubeless tires at the moment as tubular tires are not in stock due to Covid-19 shipping issue. I am not converting my rim to tubless as I don't find it necessary to switch because I have not got a single pucnture since 2 years, so pointless to make so much investment on tubeless. I want to know if it is OK to buy these tubeless tires like Maxxis Ikon or Continental Crossking and run tubes in them? Will this affect something or whatever? I know we can run tubes on tubeless tires but till I want to know if I can do that in very long term.
They will be fine. Pop in the tubes and ride as long as you can until you've patched the tubes more than a coupe of times, then use them as spare tubes.
Quoted: 18424 Post(s)
Liked 15,582 Times
Tubes don't always play well with tubleess tires. One time I had to put a tube in a tubeless tire because I punctured and my sealant was dried up. (Operator neglect early in the season.) I could not get the tire to seat properly around the valve stem area. There just wasn't enough room for the tube. That resulted in a lump, which resulted in a slight wobble. Fortunately, it was not that far of a ride back to the car. Another time, with a different make and model of tire, putting a tube in worked fine.
Quoted: 1821 Post(s)
Liked 1,697 Times
Getting a tube into a tubeless tire can sometimes be difficult as has been pointed out. As well, the tubeless version of the same tire model will always be heavier than the tube type version due to the extra material in the tire carcass needed to make the tire airtight. This can result in a poorer ride quality than if you simply bought the tube type version of the tire. Tubeless tires are also more expensive than conventional clinchers
Bikes: State Bicycle Co. Undefeated Track SS/FG, Lynskey Helix-Bronze
Quoted: 115 Post(s)
Liked 204 Times
You can also opt for clincher tires that are tubeless ready or tubeless compatible.
I’ve got Gravel King slicks on both bikes, 32s and 38s and are specified as tubeless compatible. The first initial rides on both bikes, I ran them as traditional clinchers. Since then, I’ve been running them tubeless.
Quoted: 696 Post(s)
Liked 910 Times
Liked 2,980 Times
tubeless ready is what you'd ideally want if you cannot find the tire you're seeking.
-Oh Hey!
-Oh Hey!
Likes For jadocs:
Liked 15,582 Times
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
"tubular" is a tire that has an integrated tube and has to be glued onto the rim. these are rather rare these days unless you're on a high-end race bike or something vintage. the alternative and much more common tire is a "clincher." tubeless tires are generally (always) clincher tires that are designed to be used with a tubeless-ready rim to seal up without a tube, but you can almost always stick a tube in a tubeless tire/rim.
Likes For mack_turtle:
Quoted: 115 Post(s)
Liked 204 Times
I have the GK 32s on the Lynskey Helix and I honestly couldn't tell a difference when I switched them to tubeless. I'm sure it has more to do with the Ti construction of the Helix because on the SBC 6061, with the GK 38s is where I noticed an improvement once I went tubeless. With the 38s set up tubeless (50 psi F, 55 psi R), the 6061 became even more comfortable and a noticeable reduction of road noise as well.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Likes For Rolla:
