Contaminated brake rotor
Old 05-14-23, 04:02 PM
bonsai171
Quoted: 750 Post(s)
Liked 90 Times in 70 Posts
Today I was cleaning my cassette with paint thinner, and accidentally got some on the rotor. Is this a contamination concern, and if so, how do I clean it?
Dave
bonsai171 is offline
Old 05-14-23, 04:03 PM
Atlas Shrugged
Quoted: 1248 Post(s)
Liked 1,323 Times in 674 Posts
Dave
Alcohol
Atlas Shrugged is online now
Likes For Atlas Shrugged:
Old 05-14-23, 04:30 PM
Ubie
Bikes: 2019 CO-OP DRT 1.2, 2001 Trek 2200, 2021 Cannondale Topstone 1 Alloy
Quoted: 36 Post(s)
Liked 100 Times in 49 Posts
Originally Posted by Atlas Shrugged
Alcohol
The cause of, and solution to, all of life's problems.
Ubie is offline
Likes For Ubie:
Old 05-14-23, 04:32 PM
spdntrxi
Bikes: not enough
Quoted: 189 Post(s)
Liked 86 Times in 52 Posts
isopropyl ....the other white meat
spdntrxi is offline
Likes For spdntrxi:
Old 05-14-23, 04:34 PM
Polaris OBark
ignominious poltroon
Polaris OBark's Avatar
Quoted: 2244 Post(s)
Liked 3,445 Times in 1,804 Posts
Clean as best you can with a dry paper towel, then isopropanol.
If you really need to clean your cassette, mineral spirits (maybe your paint thinner is this) will do the trick.
(Since I wax my chain, I never need to clean the cassette).
Polaris OBark is offline
Old 05-14-23, 06:00 PM
bonsai171
Quoted: 750 Post(s)
I have been thinking about switching to wax too, but get stuck in a downpour maybe once a year. Which wax are you using? Was thinking about Silca drip wax, I'm not ready to submerge my entire chain in wax, at least at Silca's prices.
Dave
Old 05-14-23, 06:22 PM
Polaris OBark
I just melt a $1.50 block of paraffin and swirl the chain around in it, but I am sure that the Silca drip would work fine. That is usually good for 10 or so rounds of application (often several chains at once).
Old 05-15-23, 03:48 AM
Fentuz
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 272 Post(s)
Liked 243 Times in 179 Posts
What do you use as paint thinner? if it was to clean/degrease the cassette, then, just rinse the disc/rotor with fresh water and do some rear braking and you should be fine.
Fentuz is offline
Old 05-15-23, 06:04 AM
bonsai171
Quoted: 750 Post(s)
Thanks for the tip on parafin wax, hadn't thought of that. I've heard of people melting the wax in a small crockpot, what do you use? Ideally I'd like to find something a little smaller, but I won't worry to much if it costs a dollar or so at a local goodwill. Just got to find somewhere to put it!
Dave
Old 05-15-23, 06:16 AM
soonerrebel
Quoted: 11 Post(s)
Liked 17 Times in 8 Posts
Dave
I've had LIMITED success with alcohol, sanding and other methods but THIS has worked every time!
soonerrebel is offline
Old 05-15-23, 07:03 AM
bonsai171
Quoted: 750 Post(s)
I used odorless mineral spirits from Walmart. Been using the same bottle for the last 5 years. It lasts forever. Maybe tonight I'll have time to put the bike back together. The rotor was really dirty when I clean it with IPA last night too.
Dave
Old 05-15-23, 07:47 AM
Fentuz
Quoted: 272 Post(s)
Dave
So mineral spirit/white spirit should be fine, rince with water and proceed with a few hard brakes and it will be fine.
I tend to "de mud" my bike, clean the cassette/chain/pullet with white spirit, wash everything with soappy water and rinse. once dried and relubbed, I run the brakes a few time to clean the surface of both rotors ad pads... then, in storage until next adventure.
Fentuz is offline
