My Toes Are FREEZING!
Bikes: 2013 Giant Defy, 2013 Specialized S-Works Venge, 1993 Specialized Epic, 2012 Fezzari Fore CR3, 2015 Cipollini Bond
So I've tried everything... double and triple layering cotton socks, one layer of cotton sock then a wool sock, construction socks... I even today had a thick nike base, and then a thick Nike, high quality tube, and put toe covers over that and then put on the shoe...
I really hate using tin foil, but I may have to just do it it seems like it works a lil' better... I dunno, wind still creeps in... someone must have a full-proof system...
Achtung!
Bikes: 60.1, Marvel
Quoted: 515 Post(s)
Liked 268 Times
Have you looked at shoe covers?
Find Cycling Shoe Covers: The Best Cycling Clothing Accessories From Performance Bike
Shoe covers as opposed to just toe covers.
Expired Member
Quoted: 3670 Post(s)
Liked 5,422 Times
Have you tried the chemical toe warmers? They are cheap and will last longer than most folks would want to ride in the cold. Don't cram too much sock into your shoe, you need room for air pockets. I don't think cotton works well for cold, would stick with wool. Thick wool socks, chemical warmers and toe covers are good for me into the mid 20s. I'm not out below that!
Quoted: 41 Post(s)
Liked 8 Times
Toe covers will help. Also, look at Walmart or a sporting goods store for chemical toe warmers. One version of them has an adhesive side so the the warmer adheres to the bottom of your socks.
Thread Killer
Quoted: 3136 Post(s)
Liked 1,704 Times
If your shoes aren't windproof, you've got a major problem right there. You should get some proper winter cycling shoes if you can afford them, otherwise, at least a windproof (e.g. GoreTex), fleeced winter overshoe. Neoprene booties aren't bad, either, but then you've got to get that warm air insulating with a good sock and insole.
Speaking of insoles, that's an oft overlooked area, but I've had good success in improving them, especially in non-winter shoes which have the sole open to the outside, either via cleat bolt holes or vents. Those will need to be blocked and insulated.
Bikes: Trek 1.1, Nashbar Carbon105 , Specialized Rockhopper-SS, Aventon Aventure
Quoted: 28 Post(s)
Liked 7 Times
My set-up
1) Cut-out a pair of wool insoles from old pack boot liners replaced the foam insole.
2) Liner socks under heavy wool socks.
3) Toe covers
Very comfortable riding today with temps in the 20s
3) Toe covers
Quoted: 5779 Post(s)
Liked 2,576 Times
For extreme cold, I layer a thin sock, plastic baggie, then a thicker sock.
An old hikers trick is to rub a hot pepper paste on and between your toes before putting socks and shoes on. The pepper is supposed to stimulate circulation and help keep your toes warm.
IME the best remedy is shoes that are tight on your foot but loose at the toes themselves. People often put on extra socks than jam their foot into tight shoes, which is counter-productive because it restricts the blood circulation you need to keep toes warm. +In the winter you want to be sure you have plenty of wiggle room for your toes.
FB
Chain-L site
FB
Chain-L site
Thread Killer
Liked 1,704 Times
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
Cold Feet
Years of experience cycling in bitterly cold temps went into writing that little article.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 2432 Post(s)
Liked 638 Times
Duct tape over every hole and mesh on the shoe, toe warmers and thick wool socks. Good down to 32 degrees for me, which is about my limit.
You're not alone!!
I'm trying the chemical warmers cuz I've tried all else.
I have $200 Specialized shoes
I have $30 toe covers
I have $20 super socks
No matter what I do, the toes eventually freeze. (Maybe I'm ok for 30 minutes, maybe 45 but eventually.....the cold wins!)
I haven't visually seen them yet, but I hope the toe warmers are a much thinner sack than the hand warmers so they fit nicely in with the shoe & don't cram the toes.
Announcer
An old USAF trick is to wear nylons under medium socks. Learned that at northern tier bases.
I wear thin socks under medium woolies. Either way, you have to give your foot room to move.
And block the wind with something: shoe covers or gaffer tape.
When you stop at a light, swing your leg forward and back in as big an arc as you can. Looks silly, but it actually helps keep the blood in your toes.
There's also a rule to keep your core warm. If that gets cold, your body will protect that before your extremities.
I can go down to about 25 degree with just toe covers. Below that, I have winter shoes. And really, if it gets below that, I'm skiing or skating.
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
Seems like a market for heated pedals is being overlooked by parts manufacturers. Perhaps something where the pedals would be powered/heated by a generator like they used on old style bike headlights..?
Seriously though I have this problem too. I'm gonna try some of the suggestions in this thread.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Winter shoes. Simple solution. 1/2 size too big for thicker socks. I am a satisfied Northwave customer.
Before that, it was the neoprene booties, with optional extra layers such as plastic bags and/or lycra covers depending on temp.
Thread Killer
Liked 1,704 Times
You're not alone!!
Thread Killer
Liked 1,704 Times
Thread Killer
Liked 1,704 Times
My toes get cold, but I'm convinced at this point there's nothing I can do about it because the root cause is lack of circulation. This is your body's response to lowering core temps. So I just try to ignore it, a la rule #5 .
Quoted: 1814 Post(s)
Liked 923 Times
It sounds like you've tried everything that involves cramming your shoes full anyway.
I don't know why it would ever be a good idea to wear cotton socks for cycling...
Snark aside, I recently got some neoprene booties that are quite toasty.
Bikes: Basso Luguna, Fuji Nevada
Quoted: 4261 Post(s)
I just bought some Under Armor Undeniable socks and they are unbelievably warm. I have poor circulation and constantly have cold feet. I bought the Undeniable socks just for riding (over the calf) but bought more and have been wearing them every day now. They might not solve your problems but for me, they are warmer than wearing 2 pairs of athletic tube socks.
Quoted: 5888 Post(s)
Liked 3,471 Times
Cottton socks? Cotton socks? The OP is riding in cotton socks; the first rule of being outdoors in cold weather is ABC (anything but cotton). Ditch the socks and then move on to some of the other suggestions.
Liked 2,576 Times
One thing that many forget (and I forgot to mention earlier) is that keeping your legs warm helps keep your feet warm. Since that's were they feel the cold most, people focus their efforts at insulating their feet. But if they neglect to properly insulate their legs, they severely undermine their efforts. If you have cold feet, add an extra layer on your legs, insulated tights or whatever, but do it.
FB
Chain-L site
FB
Chain-L site
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,173 Times
I use neoprene booties - not the very thin ones but those that are medium weight. My shoes also don't have lots of ventilation either. When I ride in the 20s, my feet are fine. That might be because the rest of me is numb.
