Am I SOL with my pre-2009 Sturmey-Archer X-RK8 and vertical dropouts?
Canadian Chick
Bikes: Lots
Quoted: 5 Post(s)
Liked 6 Times
Apparently, the bike I am trying to put this on has the worst vertical dropouts in the world. No matter what I do I can't get this hub into a position where I can use the non-turn washers.
1) Is it possible to convert this older style ST hub to the newer style with the adjustable fulcrum lever?
2) I could come up with some ghetto solution, like using an 8mm wrench as a non-turn washer, but that is lame.
3) I have 10 mm torque arms from ebike build, maybe use shims with those??
4) I found non-turn washers with different angles, but I am not sure this will help, because the fulcrum lever is the problem. I want the axle to sit vertical but ST fulcrums from this era are either angled or horizontal example:
This is probably an obscure problem since this hubs haven't existed since 2009 but worth a try! I am considering selling the wheel I just built and buy something else, but I might end up with the same issue.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Is it that the axle diameter is a bit too big to rotate freely in the slot? SA rear axles are typically 10.3 mm and the drop outs are expecting 10 mm. You could file the dropout slightly - shouldn't take much.
Canadian Chick
Bikes: Lots
Quoted: 5 Post(s)
Liked 6 Times
Oh, are you saying file the drop so I can insert the axle flats horizontally? Hmm ya I can do that but then I'd need the horizontal washers. The only place they can go is if the tab is on the bottom.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
OK, I think I made some assumptions about your issue that resulted in an incorrect visualization. After some thought I think I've got the picture now. Forget about filing. Although that would align the fulcrum lever correctly, you'd still (as you pointed out) have to find appropriate anti-rotation washers. I think your only options are to either fabricate a new fulcrum or modify the one you have. The modification I'm thinking of is to rivet a thin piece of stainless over the axle hole, then drilling and filing a new axle hole with flats at the right angle for your dropouts. Making a new one may not take that much more time.
Good luck.
Good luck.
Canadian Chick
Bikes: Lots
Quoted: 5 Post(s)
Liked 6 Times
Good luck.
Good luck.
The dropouts are wide enough that the flats fit in there ok, so will have to test. Here's a pic:
Pre-2009 X-RK8 torque arm
When I get the vertical washers I will add them in. Sucks that like no one in Canada seems to sell Sturmey-archer! I always have to order from US or Europe.
Actually, the largest Canadian wholesaler, livetoplaysports, recently picked up Sturmey-Archer. They carry 5-speed and 8-speed hubs and parts. Have a look at the listings on their site.
Nearly every LBS in the lower mainland is a Live to Play Sports dealer. None of them stock Sturmey Archer parts. Just ask them to order what you need.
Canadian Chick
Bikes: Lots
Quoted: 5 Post(s)
Liked 6 Times
It's all good. I already ordered the shiz from UK. I am in Okanagan, the reason I don't go to most bike shops is the extreme overpricing compared to Europe. Shimano gets away with it due to monopoly. Really, that was pissing me off a lot recently. Like why should they dictate where I can buy something? Isn't that the definition of a cartel? Lol.
Likes For Aquakitty:
