Trek aluminum frame BB Question
I am interested in a vintage 26’er Trek MTB frame and want to build another bike. I am not an expert, but the close up of the BB doesn’t ring a bell - what looks like a tapered or conical BB. I am only familiar with threaded BB’s and cranks.
am I not seeing it correctly? Or is there a type of BB / crankset that matches this?
I hope the link works. If not - it’s an aluminum frame… and one side of the BB appears to be non-threaded. Your insight are appreciated. Thanks, again. Tom
(I’ll try to post the link again)… didn’t work
ps. Do I need to find a rear derailleur hanger for the frame? A steel derailleur hanger that bolts to the rear drop out? Similar to the Specialized aluminum frame I am working on at the moment.
https://www.ebay.com/itm/15545623561...oN10upGA%3D%3D
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
The description in the eBay ad says "English threaded BB". This is what I would expect from an older Trek MTB frame. I see a derailleur hanger in the pics.
Likes For Eric F:
Likes For Crankycrank:
Any thoughts about the 1-1/4” head tube and fitting a suspension fork?
I see more 1 1/8” forks and far fewer 1-1/4” forks. Do the 1 1/4” to 1 1/8 adapters affect fit quality or steering and handling? (I suspect not if installed correctly) but I don’t have knowledge to know better.
appreciate the help.
tom
tom
Quoted: 1821 Post(s)
Liked 1,696 Times
The head tube diameter is always going to be larger than the steer tube diameter. As well, the ad doesn't specify whether that is the inside or outside diameter of the head tube. If that is the inside diameter, the frame is designed for a 1 1/8" steer tube. If that is the outside diameter, the the frame likely needs a 1" steer tube
Likes For alcjphil:
Habitual User
Liked 8,099 Times
tom
tom
Likes For Eric F:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Likes For Saddle Tripper:
