Using pre existing 27" cantilever mounts for 700c
Old 02-28-24, 07:08 PM
santa fe 2926
Bikes: 1985 Roberts SLX, Mercian 531, 1984 Torpado SLX,1981/82 Peugeot PSV-10, 1978 Charlie Roberts full touring, 1970 Charlie Roberts 531 road.
Quoted: 79 Post(s)
Liked 164 Times in 61 Posts
Any body have a thought on converting a 27 to 700c using the already existing mafac cantilevers? I think that my 1988 Roberts touring was 27 originally, but have been running 700 for as long as I can remember. On my 1970 Charlie Roberts, from eBay.CA , 5 years ago, the center pulls, had no issue going from 27 1/2 to 700c, was worried I might need a drop bolt, but no problems. It’s a really amazing bike, but having had the 27 pasela’s would love to go Veloflex 32’s are Compass 35-38’s
santa fe 2926 is online now
Old 02-28-24, 07:33 PM
Piff
Piff's Avatar
Quoted: 801 Post(s)
Liked 754 Times in 411 Posts
Lots of relevant info here: https://www.bikeforums.net/classic-v...st-merz-2.html
Piff is offline
Likes For Piff:
Old 02-28-24, 08:40 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,932 Times in 2,557 Posts
Try it. You will have to angle the pads down. Watch them carefully as they break in. Will probably need an adjustment once or twice over the life of the pad as it wears. The thin replaceable pads probably will not serve well. I'd expect the top edge to wear to the metal pad holder quite fast. The much deeper one piece disposable unit should work a lot better. And as the pad wears it will try to slip down off the rim with hard braking. Don't let this happen! The pad will be in your spokes! Keep the pad as high as possible on the rim. (Unlike regular calipers where too high means possibly touching the tire and slashing the cord as pad wears.)
700c rims are 4mm lower than 27". I had my Mooney built with the cantis set half way between. I've always had 700c and I have the pad issues I described above to a small level. Totally within reason. (I had no idea which way the market was going to go in 1978. Nor if 700c tires could even be found in the out of the way places my life might take me.)
79pmooney is offline
Likes For 79pmooney:
Old 02-29-24, 12:11 PM
shoota
shoota's Avatar
Quoted: 1873 Post(s)
Liked 692 Times in 468 Posts
Serious question, have you tried searching this forum yet? There are dozens of threads on this topic.
2019 Salsa Warbird
shoota is offline
Likes For shoota:
Old 02-29-24, 12:36 PM
Piff
Piff's Avatar
Quoted: 801 Post(s)
santa fe 2926 Follow this link https://www.google.com/search?client...bikeforums.net
Piff is offline
Likes For Piff:
Old 02-29-24, 12:43 PM
Arrowana
Bike Sorceress
Arrowana's Avatar
Bikes: Yes
Quoted: 62 Post(s)
Liked 116 Times in 66 Posts
One factor that hasn't been brought up yet is rim width. If the 700c rim is the same width or narrower than the 27" rim, you have better odds of it working. If the 700c rim is wider, then you may find the canti studs are spaced too close together to make it work.
Arrowana is offline
Likes For Arrowana:
