49 cm for 5'7"
Bikes: Surly LHT, Steamroller (Work in Progress)
Quoted: 9 Post(s)
49 cm for 5'7"
I bought a Surly Steamroller off craigslist. I am 5'7" and I think it is a bit too small for me (49 cm) but I have been riding a 58 cm Long Haul Trucker for 4 years now without incident. I rigger that ride up by dropping the seat down as far as possible and switching out the drops for bull horns.
I wonder what things (such as steam, handlebar, etc.) I may want to look into getting to have this frame fit me better.
Thanks.
Thanks.
Quoted: 18382 Post(s)
Liked 4,515 Times
That is a pretty good range of bikes sizes.
I suppose the first question is how much bar drop do you wish to have? I could imagine building a speedy bike with a fairly long stem, and the same bullhorn bars you have on your other bike.
You might need to set the seat forward slightly to make it comfortable, although the seattube angle may already be steeper than your other bike.
just another gosling
Quoted: 3895 Post(s)
Liked 1,945 Times
I doubt you'll every be really comfortable on it for long rides.
Results matter
Results matter
Quoted: 9 Post(s)
Quoted: 9 Post(s)
Steam roller not something I'd choose for a long ride, anyhow..
maybe bullhorn bars with reverse brake levers in the end, up angled stem ..
Fit the drop bars on the LHT, short stem.
lht
lht
Liked 1,945 Times
Because the geometry is not optimal. I'm 5'6" and am reasonably comfortable on bikes 50cm-54cm. However the least comfortable is the 50. Easier to get comfortable on a too big frame than a too small one. That said, modern racers are using frames which are really much too small because they're lighter and stiffer. But they're getting paid to suffer. You're not.
Results matter
Results matter
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Thanks.
Thanks.
Liked 4,515 Times
Perhaps that is the only advantage of a really small frame, you can get the bars quite low, in theory for a more aerodynamic posture.
But it was attractively priced .. Hawaii is an expensive place ...
but the distances are not far , except going around the island more than once.
Quoted: 9 Post(s)
Appreciate all your comments.
The price was a big factor - it was $200 for the whole shebang. The rear wheel is not in the best shape, but all the other components were solid and the frame itself is is in excellent condition. I did test ride it, and it did not feel too small. I suppose that may be because I am used to such a large frame frame (nearly 9 cm bigger), but I didn't feel uncomfortable.
The used cycle scene is a graveyard here and most of the posts are for TT bikes or crappy Pure Cycle pre-builds. I suppose my happiness with my LHT made me bias towards the Surly brand as a whole too, so I pulled the trigger on this bike knowing it wasn't a perfect fit.
As I said in my initial comments. I don't expect to be riding more than 5 miles each way on this. It is purely for getting me to and from school. I will mess around with both bullhorns and drops and see which feels better.
Liked 1,945 Times
Results matter
Results matter
Quoted: 5 Post(s)
I'm 5'9 and a guy at one of the LBS around my area tried putting me on a 48cm bike. Needless to say, that was my last visit there. Got a real fit after, and I'm comfortable on a 54.
