ISO/WTB: complete vintage Campy BB, BSA, 117-119mm-ish
Hi all:
Searching for a friend.
Bike currently running a 115mm vintage Campy spindle - but just slightly too close on DS, and inner chainring interferes with chainstay under load.
Really don't need to go out much - reckon 117-119mm, maybe 120mm at most would do it?
Seeking BSA complete vintage Campagnolo BB to meet above spec.
PM me - or email is even better - if you might have something to solve this need!
Cheers,
@mikemowbz
Cheers,
@mikemowbz
Quoted: 787 Post(s)
Liked 522 Times
You may be able to just add a spacer to your existing BB. From St. Sheldon:
"Bottom Bracket Spacer
If you need to increase the chainline (move the chainring to the right) you can usually add a spacer washer between the right-side bottom bracket mounting ring (or cup) and the bottom bracket shell of the frame. The usual spacer for this is a Sturmey-Archer sprocket spacer. Metal spacers without internal lugs used with Shimano cassettes also will work. These fit all threaded bottom brackets except Italian size. Sorry, I don't know of any source for a spacer that will fit an Italian (36 mm) bottom bracket. Adding a spacer on the right side will move the left bottom bracket cup or mounting ring inward -- a lockring might not then engage enough threads, so check before you commit to this."
If you need Campy, a pre-CPSC Record triple English BB would have a 117mm spindle, though that is a difficult to find and pricey unit. I may have a ~118mm Velo Orange English BB in my stash. I can check tonight.
Old fart
Quoted: 3597 Post(s)
Liked 3,421 Times
What crank from what production year are you intending to use with this bottom bracket?
https://www.os2.dhs.org/~john/campy-BB-specs.pdf
The crank is a Gran Sport (Nuovo Gran Sport?) from the 1980s - offhand, I believe the 'proper' BB length is a 120mm according to original spec - info in that article appears to confirm.
I don't know the exact year of production - didn't note the date code - but could do. Pretty confident it's 1980s production GS, both from appearance and provenance (owner of the bike/crank had it custom built ca. 1983 give or take a year, with this crank on - but BB has been changed at some point, now has Specialized cups and a 115mm Campy spindle).
Spacer may be a solution here - BB is BSA, and I should have those Shimano spacers handy, and likely able to get the Sturmey easily enough.
VO BB would be JIS taper, correct? Friend is quite adamant that he wants a 'proper' vintage Campy taper...
Appreciate the info and suggestions.
Bikes: 48 Alleluia, 52 Blondin, 57 Cattaneo, 68 CNC, 55 Dujay, 46 Herse, 76 Singer, 48 LeGreves, 55 Metropole, 62 Holdsworth Cyclone, 49 Carpenter, 55 Condor, 65 Masi Special, 81 Sequoia, 76 Eisentraut, 72 Proteus, 60 Paramount, 77 Trek TX700, 82 Ross
Quoted: 79 Post(s)
Liked 137 Times
There's no Road Double bb spindle with a length of more than 115.5 mm. You would have to go to a triple spindle, which are getting a bit expensive and hard to find. A spacer behind the fixed cup would be the best solution if about 2 mm is sufficient, otherwise you start to run out of adjustable cup thread available for the lock ring. Going to a rifled Campy adjustable cup would give you another mm or so of thread compared to your Specialized cup.
In a pinch, I've used brass shim on the tapers to get another few mm of chainring clearance, and it actually works quite well if you're careful.
I have spare Campy double bb sets in most configurations (no triple spindles though - I need them all) and may have something that would work. I'm in Vancouver, so you're welcome to drop by.
I would think your GS double crank should work with any post-CPSC ("New Style") Road Double bb. The 115 spindle is post-CPSC Italian, although you don't say whether it is Gran Sport or Record (both for thin cups) or Nuovo Record (rifled cups). I'm guessing it's NR, as I think this spindle would fit a 68mm bottom bracket shell when used with Specialized cups (a bit thinner than the rifled NR cups). The fact that you have insufficient chainring-to-stay clearance when using an Italian post-CPSC spindle may indicate that the crank tapers are quite worn.
I have not actually seen the spindle in question - relying on info from the mechanic who disassembled recently, whom I know well but who would not likely be able to tell me if GS, NR, etc.
I think my friend with the cranks/bike in question would be keen to replace with a complete Campy bb unit - and I think an arrangement with a standard double BB and spacer that gained 2mm clearance from the stay relative to current would do the trick.
I would be happy to drop by and see what you've got (and to talk the problem out with someone obviously much more well-versed than I in these things). Sending a PM now.
