Headset compatibility for new fork
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Hi!
I have a 2018 giant tcx advanced sx frame and recently bought a new fork for it after detecting some cracking on the carbon fork I had.
This is the new fork:
https://www.ragleybikes.com/products/trig-carbon-gravel-bike-fork
Of note the Integrated crown race for 1.5” 36 degree contact angle bearing.
I feel a bit lost because the bike had a giant overdrive 2 headset on it. I bought an overdrive 1 thinking that was the normal headset and it doesn't seem to fit. Guessing it's not really for a tapered headset.
Can anyone help me find the correct headset for it? Is this what I'm looking for? Thanks so much for your help!
Fsa number 42 orbit C40
https://www.ebay.com/itm/203095473778?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=8r6DL7rLRq2&sssrc=4429486&ssuid=f0dEC0t8RzS&var=&widget_ver=artemis&media=COPY
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
bump...ity bump bump
anyone?
anyone?
Quoted: 4210 Post(s)
Liked 3,878 Times
When I worked in a Giant dealer shop (2003-2010) we were frustrated by a few of their headsets. Odd and proprietary fits. I never got fully fluent in their specs. But this was when I was turning away from trying to memorize the ever changing "standards"... Andy
AndrewRStewart
AndrewRStewart
Quoted: 839 Post(s)
Liked 1,064 Times
As noted, the fork linked to uses a 1.5"/36 degree bearing and the Giant seems to use a 45-degree? bearing. It may be as easy as just trading the bottom bearing but that is just a big maybe. Probably best to visit a Giant dealer with the bike and fork and see if they can sort it out.
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Bearing specs: ACB 1.5" 36° x 45° MR127
It's an Fsa bearing
Fingers crossed. Should know after work on monday.
Likes For ridethecliche:
Quoted: 839 Post(s)
Liked 1,064 Times
Time to take it to the Giant dealership with the bike and fork and the original and new bottom bearings and they can probably figure it out. Buy the bearing from them so they can get paid for their expertise and sell the other bearings you bought on Ebay or ? Take this as a learning experience to double check that what you have will work with new and different parts which is getting more and more the norm with all the different standards and proprietary parts these days.
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
I'm honestly wondering if theres a crown race adapter or such that I can use with the frame to get it to work.
Quoted: 839 Post(s)
Liked 1,064 Times
I certainly would expect them to give it a try as you already bought the bike and the original fork cracked. You won't know until you ask.
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Ah yeah, this is true. However the fork that cracked is off an old frame that was warranteed. I just kept using it since it was fine and it was lighter. The original frame had a crack in a chainstay. The fork that came with this fork is fine and is now back on the bike. So it's functional for now. I guess I'm going to take a loss and sell the fork.
Liked 739 Times
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Email Cane Creek.. i've gotten decent help from them before... my Cannondale M600 project had them jumping but they only gave some info.. that info led me to the correct adapter parts to fit a 1 1/8" fork into an old school, limited production, 1.125 / 1.25" bike frame..
I'll report back with an update if there is one.
The solution I've seen involves using an adapter and just a straight 1 1/8 fork.
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
I honestly gave up...
I'm going to see if I can find a revolt fork that will work or just use something like the el jefe mounts to add mounting points for bottles or something to the fork.
