Bike mirrors vs. presbyopia
I'm on something of a safety binge these days. I'm about to pull the trigger on some fore and aft lights, and now I'm looking for a mirror. Unfortunately, I think my choices will be limited by the fact that I have presbyopia. Even with progressive lenses, my close-range vision is positioned down toward the bottom of my frames. So I'm thinking that rules out a helmet-mounted or glasses-mounted mirror...right?
If I AM limited to handlebar-mounted mirrors, what do you recommend? I have a hybrid with contoured hand grips, so I imagine I'd be installing a fixed bar-end mirror. (The strap-on kind look incredibly jiggly and useless anyway....)
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
I wear progressive lenses in my regular glasses and bifocals in my sports/cycling glasses. I also use a helmet mounted or glasses attached mirror for every ride. No issues whatsoever and the quick check to the rear with helmet or glasses mirror, IMO, is safer then using a bar mounted mirror. Best of luck and I applaud your decision to use a mirror.
Bob
Bob
Quoted: 659 Post(s)
Liked 7 Times
What is sometimes an issue is the degree to which one of your eyes is dominant. With a helmet or eyeglass-mounted mirror it's typically only visible by your left eye. If you have strong right-eye dominance you might have trouble concentrating on the image in the mirror seen only by your left eye. Easiest way to check is just to try one out. Bike shops should be willing to let you test one of their mirrors to see how well it works for you.
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
No, near-sightedness and mirrors don't work that way.
If it did, we could use mirrors instead of lenses. Want proof? You need your glasses to see yourself in the bathroom mirror, right?
There are fans here of helmet/glasses mount mirrors, and those of us who prefer bar mounts. It's really a personal preference matter.
All bar-mount mirrors are subject to some vibration. This does not make them useless in traffic.
Just because I can't read the license plate of the car approaching from behind doesn't mean I can't see the car. Maybe I can't tell if it's a Hyundai or a Toyota (Who can anyway without reading the nameplate?) but I can see that I don't want to move over for a left turn in front of it.
Now, I wouldn't want to shave in a bar-mount mirror, but I don't shave in traffic anyway. Close shaves BY traffic excluded, of course.
Quoted: 69 Post(s)
I use the Mirrycle: Amazon.com : Mirrycle Mountian Mirrcycle : Bike Mirrors : Sports & Outdoors. It is incredibly stable. The image doesn't bounce around, and the mirror itself doesn't move when I go over bumps and so forth. I really like. I've tried several other kinds of bar-mounted mirrors, but this is the only one that has really worked for me.
Presbyopia? Oh you mean you are getting Older.. the stick on the inside of your glasses mirror may be difficult to shift focus that close..
Handle bar fitted ones may still be fine .. this is a generous sized helmet mount EVT | Safe Zone Helmet Mirror
I live in a Small Town so I just stop and look , or look over my shoulder and stick out my Arm
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
My correction is -11 which, if you don't know, makes me extremely nearsighted. I also wear progressive glasses. The helmet mirror works fine. I recommend Take-A-Look mirrors.
Quoted: 4806 Post(s)
Liked 3,932 Times
As other have said, you don't focus on the mirror. You focus on the object you are looking at, 30 feet away.
That said, I do not like progressive lenses for helmet/eyeglass mirrors because those lenses (at least the pair I tried) focus clearly at the center of the lens but poorly at the edges. I now use bifocals which are sharp to the edges and give me an excellent view behind with a helmet mirror.
Ben
Ben
Quoted: 1364 Post(s)
Liked 1,678 Times
I also wear a glasses mounted mirror with tri-focals. I've tried progressives and hated the lack of distance peripheral vision (at least in my case) which made me feel unsafe in traffic whether on bike or in car. In addition to the glasses mirror, I also have handlebar mirrors. Your glove mirror, while clever, is right in my glove-back snot-zone. But I may give it a try...I like it. Try the take-a-a-look-mirror. It's not jiggly in my experience.
Tractorlegs
Bikes: Schwinn Meridian Single-Speed Tricycle
Quoted: 119 Post(s)
Liked 60 Times
Trikeman
Trikeman
aka Phil Jungels
The Mountain Myrricle is an absolutely fabulous rear view mirror. Great picture, steady as a rock, completely adjustable. I won't ride without one ...
Quoted: 392 Post(s)
Liked 49 Times
The arm is metal which is durable and can be bent to different shapes. The mirror is a quality and glass. The various plastic helmet mirrors I've tried always break after a few months.
Quoted: 7351 Post(s)
Liked 2,478 Times
I am right-eye dominant, and I have no trouble with my eyeglass mirror mounted near my left eye.
Quoted: 659 Post(s)
Liked 7 Times
Depends on the degree of the dominance since some people do have that problem with a glasses or helmet-mounted mirror. Easy enough to test by trying one of the mirrors (or just holding any small mirror in that position) before buying.
meh
Quoted: 1111 Post(s)
Liked 1,013 Times
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
You misunderstand how mirrors work. You're not looking at the mirror, you're looking at stuff THOUGH the mirror.
If you are looking at something 20 feet behind you in a mirror 2 inches from your head, your eye needs to focus at a point 20 feet, 2 inches away.
My favorite is the Cycleaware Reflex. I used to use a Take-A-Look, but I had an accident and wound up having the mirror's stiff wire and sharp-ish edge of the mirror ground into my face, requiring 18 stitches to close. The Cycleaware does not have sharp edges or stiff wire to ram into your face or eye.
Work: the 8 hours that separates bike rides.
